Zitat von yuhu
Beitrag anzeigen
with libebus I obtained always:
root@ubuntunb:~/libebus# ./test_commands
Commands: 11
found at index: -1
terminate called after throwing an instance of 'std::bad_alloc'
what(): std::bad_alloc
Annullato (core dump creato)
with:
root@ubuntunb:~/ebusd# tools/csv ../libebus/test/.
2014-05-06 19:43:26.115 [NOT] ../libebus/test/./command.csv
2014-05-06 19:43:26.115 [NOT] ../libebus/test/./command.csv success
root@ubuntunb:~/ebusd# more ../libebus/test/command.csv
# type;class;cmd;comment;msg type;ZZ;PBSB;NN;D1D2D3;elements;sub;part;position; datatype;factor;unit;valid;comment;sub;part;positi on;datatype;factor;unit;vali
d;comment;sub;part;position;datatype;factor;unit;v alid;comment;sub;part;position;datatype;factor;uni t;valid;comment
cyc;vr903_1;RoomTempAct;Raumisttemperatur;MS;1C;B5 09;3;0D0000;2;temp;sd;1,2;d2c;1.0;°C;-;Temperatur;sensor;sd;3;uch;-;-;-;Fühuh;;;;;;;;;;;;;;;;
so for you is a bug in ebusd decode function? so how to explain to ebusd team about the bug?
