Wäre es sinnvoll das WG mal neu zu starten?
VG
VG
root@wiregate685:~# aplay -l **** List of PLAYBACK Hardware Devices **** ALSA lib conf.c:1589:(snd_config_load1) _toplevel_:42:11:Unexpected char ALSA lib conf.c:2850:(snd_config_hook_load) /etc/asound.conf may be old or corrupted: consider to remove or fix it ALSA lib conf.c:2714:(snd_config_hooks_call) function snd_config_hook_load returned error: Das Argument ist ung�ltig ALSA lib conf.c:3079:(snd_config_update_r) hooks failed, removing configuration aplay: device_list:216: control open (0): Das Argument ist ung�ltig ALSA lib conf.c:1589:(snd_config_load1) _toplevel_:42:11:Unexpected char ALSA lib conf.c:2850:(snd_config_hook_load) /etc/asound.conf may be old or corrupted: consider to remove or fix it ALSA lib conf.c:2714:(snd_config_hooks_call) function snd_config_hook_load returned error: Das Argument ist ung�ltig ALSA lib conf.c:3079:(snd_config_update_r) hooks failed, removing configuration aplay: device_list:216: control open (1): Das Argument ist ung�ltig root@wiregate685:~# root@wiregate685:~# alsamixer ALSA lib conf.c:1589:(snd_config_load1) _toplevel_:42:11:Unexpected char ALSA lib conf.c:2850:(snd_config_hook_load) /etc/asound.conf may be old or corrupted: consider to remove or fix it ALSA lib conf.c:2714:(snd_config_hooks_call) function snd_config_hook_load returned error: Invalid argument ALSA lib conf.c:3079:(snd_config_update_r) hooks failed, removing configuration alsamixer: function snd_ctl_open failed for default: Invalid argument root@wiregate685:~#
