Homeserver 2 und Experte 4.0
    Zitat von onkelm Beitrag anzeigen
    CPU: You can upgrade the CPU to a maximum P3 or Celeron with 1100 Mhz - thats supported by the board. Socket is called 370.
    I thought the motherboard was an EPIA 500 with a VIA chipset. Maybe we are not talking about the same stuff ?
    I'm puzzled about the description, I've a HS2 NET booting from flash. Sometimes, I see descriptions about HS2 NET booting from CD. Could that make the difference.
    All this works like a charm since a year ago on my HS 2.0 Net
    Would you be so kind to provide a list of references and supplier, please ?
    I guess no one is selling a kit ?
      yeah there is a difference.
      HS2.0 Net is a mid large case, beige colour booting from cd with a Motherboard from ECS (Elitegroup) and with a VIA Cyrix III CPU 667Mhz - thats the one I have.
      HS2 Net is a very small black colour desktop case and booting from flash. For this one, you have to check with others for CPU and memory.
      I gave you the key words - just search via google - the flash module will work in yours most probably too.
      And if you have the HS2 Net, I guess you just have to change the flash module - to have enough memory.
        Ergänzungen zum "Pimp my HS" Schritt 2/ BIOS-Einstellungen
        Zitat von MarcusF Beitrag anzeigen
        Die Suchfunktion, Dein Freund und Helfer:
        https://knx-user-forum.de/knx-eib-fo...ver-umbau.html
        Ich habe noch folgende Ergänzungen zu Schritt 1+2 von o.g. Dokument (Betreffen HS 2 Net, NICHT: 2.0 net !)- BIOS-Einstellungen
        Schritt 1:
        Erstellen des USB-Bootsticks: cmd muss als Administrator aufgerufen werden (Alle Programme/ Zubehör/Eingabeaufforderung)
        ansonsten Abbruch mit Fehler: " ... Did not successfully update MBR"
        Schritt 2:
        "Entf" zum Aufrufen des BIOS (Nicht F2 !)
        1. Integr. periph.: USB-Keyboard: Enable
        2. Adv. Bios features: First BD: USB-FD, Second BD: HDD-0 (=Flash)
        3. Super IO Device: Seriell Port 1: 3F8/IRQ4
        4. Power Management: AC Loss Auto restart: On
        F10 zum Speichern und Neusatart
        Nach Neustart kommt (zumindest bei mir) folgende Meldung:
        PCI Devices werden gelistet:
        Veryifying DMI Pool Data
        F1...Dos
        F2...Dos
        F3...Dos
        F4...Dos
        Default: F2
        ->F1 drücken, dann fährt HS korrekt hoch !
        Viel Erfolg
        Andreas
          prima, dass Euch meine Anleitung nun hilft (1000 downloads..)
          Mein kleines Ego würde sich über eine Bewertung meiner Anleitung freuen.
          Was den Speicher angeht: 266 Mhz Speicher läuft, 133 Mhz reichen.
          Einfach mal schauen, was in der Bastelkiste noch liegt.
          Gruß Jürgen
            Guuude,
            jetzt muß ich nochmal nachfragen:
            Bei Euch läuft der HS 2 (also der kleine schwarze) mit dem aktuellen Experten 4.0 ?
            Gruß OnkelM
              Ja, läuft ohne Probleme.
              Ich weiß nicht immer wovon ich rede, aber ich weiß, dass ich Recht habe. (Muhammad Ali)
                Hallo Scholli,
                wie hast du die Bootcd erzeugt?
                Gruß Marko
                  Der schwarze hat Keine CD!
                    Das war auch ein genialer Schachzug, einen Homeserver 2.0 Net und einen Homeserver 2 Net zu bauen, damit sich keiner mehr auskennt. Es gibt ja so wenige unterschiedliche Ziffern, da muss man schon sparen...
                    Marcus
                      Die einen nennen es genial, andere idiotisch....
                        War vermutlich eine Idee aus dem Marketing. Die haben bei uns auch gern solche Geistesblitze
                        Marcus
                          Hello,
                          I've asked Gira if they sell flash and memory.
                          If not, to specify the references. No reply yet.
                          Someone willing to post the updated part number for flash and memory ?
                            There is no number. They will not sell it.
                              Too bad.
                              I thought, if they do maintenance, they must have spare parts ... which doesn't imply they sell it.
                              So I'll wait for a brave heart to help me.
                                Hello,
                                I think, the 3 Euro Pollin Flash is a very good offer!
                                If GIRA would sell it, you´ve to pay 100 Euro +.....
                                Regarding RAM, I would search in EB@Y, it´s old stuff and should be cheap...
                                Regrads
                                Juergen
