Did you try passive mode?
10 x Beep
I've tried so many things...Zitat von MatthiasS Beitrag anzeigenDid you try passive mode?
I'll do it again
OKZitat von MatthiasS Beitrag anzeigenCycle 2 does not mean minutes, it means every second time = 30 minutes
How long should I wait before seeing some result ?
The doc says: after re-boot, but .... how long ?
Yes. No go.Zitat von MatthiasS Beitrag anzeigenDid you try passive mode?
To make sure, I force the KO FTP-Status to an irrelevant value (i.e. 9) after a while it is reset to 2. So 2 is the real status, and means "nicht speicher".
Doesn't help much.
Also, someone hinted for a hardware problem.
For me, it is hard to believe, nevertheless I swapped the memory bar.
Could it be the flash ? only for FTP ??? Mmmm
One fact still puzzles me: my problem appeared around the same time as I did the Pimp procedure. Maybe coïncidence.
Did I forget to check something ?
Troubleshooting procedure wrong ?
Any hint is welcome.
Those 10 beeps are driving me mad.
I don't believe in hardware problems. Debug says "FTP error. Doesn't help much, but it is a clear hint.
Did you try a different path? Did you try "\" for example?Gruß MatthiasEIB übersetzt meine Frau mit "Ehepaar Ist Beschäftigt"
- PN nur für PERSÖNLICHES!
Right !Zitat von MatthiasS Beitrag anzeigenDebug says "FTP error. Doesn't help much, but it is a clear hint.
No, not yet, but I was thinking along those lines, especially a NAS access rights problem, or another subtle change introduced by a NAS firmware upgrade (it's not the first time they mess around).Zitat von MatthiasS Beitrag anzeigenDid you try a different path? Did you try "\" for example?
So, I'm setting-up another ftp server.
Is there any way to force a save of the Remanentspeicher ? besides waiting 30 min ?
Thank you for your help, bringing hope back again.
You can change to "everytime/jedesmal" = every 15 minutes
or
- Abhängig von der Einstellung des "Speicherzyklus" ca. alle 15 Minuten, wenn "Jedesmal" angehakt ist, oder des benutzerdefinerten Vielfachen (Eintrag im Feld "Benutzerdefiniert") von 15 Minuten, wenn "Jedesmal" NICHT angehakt ist.
- Je nach Einstellung der Ringspeicher erfolgen zusätzliche Sicherungen.
- Direkt VOR (before) dem Herunterfahren des HS/FS, wenn dieser über den Experten über den Punkt "Übertragen -> Nur Neustart" neu gestartet wird (only Restart).
- Direkt VOR dem Herunterfahren des HS/FS, wenn dieser neu programmiert wird
- Direkt NACH (after start with new project) dem Hochfahren des HS/FS, wenn dieser neu programmiert wurde. Es wird eine neue Projekt-ID verwendet.
I've setup another FTP server on a good old W2K.Zitat von MatthiasS Beitrag anzeigenDid you try a different path?
Manually uploading files works fine.
Nothing comes from the HS.
This brings me back to the HS.
Let's forget about the Remanentspeicher for a while.
A simple FTP doesn't work either, might be easyer to debug.
Can someone provide me with the most simplistic setup for a FTP transfer ?
The one that couldn't fail ?
I'm beginning to suspect everything.
ûûh !Zitat von MarkusS Beitrag anzeigenWhat about Wireshark on this W2K?
Didn't think about it yet.
I am/was convinced about a configuration problem, bad syntax, bad FTP path, missing "/" etc... the classical errors from dummies ...
But you are right, I have to take it more seriously, which implies an adequate setup for sniffing.
OKZitat von MarkusS Beitrag anzeigenFor me, this works like a charm ...
It must be me then ....
I've made a small setup with a hub inorder to sniff , the HS and a PC running Wireshark.
I filter on port 20 & 21
I see communication between the W2K FTP srv and the HS.
I see plenty of black lines "TCP DUP ACK" mmmm, looks no good.
I hope it's not a side effect of the test setup.
No real clue about your problem, but some additional hints:
- There's no need to setup "Netzwerk -> FTP" if you only want to backup your remanent memory. For this, simply use the settings at "Netzwerk -> Remanentspeicher" and activate only the first tab "FTP-Backup 1". You seem to have to setups to different paths /Ftp/HS/ and /HS/ (Tab "FTP-Backup 1" and "FTP-Backup 2"). This might confuse some things, too.
- Use passive FTP for "Netzwerk -> Remantspeicher", it's not activated on your screenshot (there is a similar setting, not only the setting at "Netzwerk -> FTP").
Regards,
Hartmut
