I've an understanding problem about recalling a list from a button in the Visu.
I've several of those buttons in the Visu which call related lists, it works fine.
Now I realize it doesn't work from another client PC.
NB: the archive itself is OK (see Puits-Archive.JPG)
I can call the list by explicitely specifying the URL like: http:10.0.1.249/hslist?lst=puits&user=warichet&pw=xxxxx
Associated with a button, I've defined the "Telegramme senden" (see Puits-Telegramme.JPG) by specifying my own IP address, obviously, this will not work from another client.
How should I define this "Telegramme senden" in such a way it is generic, i.e. works from any PC ?
I've tried to put the IP address of the HS (10.0.1.249) but this doesn't work (sender and receiver are the same).
Thank you for any hint.
: put the records in the Ringspeicher. Then you may display the records inside the Visu using 14-byte Textelements.
