Hello,
I have a question about sending IP telegrams from a homeserver to an
Extron audio matrix switch.
For the communication between the audio matrix switch and the
Homeserver we need to send a string (ASCII) command to an IP address
with port 23 like TELNET commands. The problem is that the homeserver
needs to send this String command many times before the Extron audio
matrix switch reacts to this command.
I already asked this question to Extron but they say that when it
works with external TELNET programs like Hyperterminal that it has to
work with other programs as well.
I am sending the IP telegram as a String tekst with a carriage return
at the end.
Does someone knows a solution for this problem?
Is there a way around in the Homeserver to communicate with a TELNET
device?
I hope someone can help me out.
Best regards,
Jeroen Verbocht
at the end.
device?
Best regards,
Jeroen Verbocht
