HAGER DOMOVEA 3.5.0.0 steht zum Download bereit
    Wer traut sich?
    Du evtl.??
    Viele Grüße,
    Fabian
      Ich spiele das Update gerade auf den Server...
      Warum habt ihr Angst davor?
        Wer einen Domovea hat, der ist eh leidensfähig..also was solls?
          Bin ich der einzige, der noch nie Probleme damit hatte?!
            Du und die Tester bei hager.
              Bei mir läuft seit 21.9 die 3.5. Auf dem ersten Blick funktioniert das Update.
                Wenn du meinst...
                  Ein Servus in die Runde,
                  was sind den die Neuheiten bei der Version 3.5?
                  Hab auf der Homepage nichts rausbekommen...
                  Gruß Florian
                    V3.5.0.0 New functions
                    • TXA100 project automatic import
                    • Compatibility with new ATC thermostat
                    • Compatibility new easy weather station
                    Bug fix Client
                    • Measures o In some configuration the energy synthesis is not displayed on the dashboard o Bad display of the red zone for electrical production device o Changing parameters of the devices are not spread to energy synthesis o The energy synthesis is displayed on the dashboard even if no energy device is present in the database o The creation of a measure on a device doesn't automatically update the energy synthesis o In personalized mode, it should not be possible to align less than 7 days • Sequences o The % variable isn't available to set the shutter inclination o Bad time display of next sequences on the dashboard widget when using ephemeris • Camera o The camera picture is cut when reducing the window to the minimum size
                    Client domovea touch panel • Some groups are unavailable via right side navigation panel if the database has more than one groups page • Freeze between two pages of devices when sliding slowly
                    Web configuration tool • Problem when recording a program with more than 100 events • Impossible to set a value >9% for generic device with the DPT '1 byte unsigned Percent'
                    General • In some case the update process on the client doesn’t succeed and allow a client with a version x to be connected to a server with a version x+1 • Wrong values on ventilation device when rebooting the server
                      So erledigt, funktioniert wie immer alles einwandfrei :-)
                        Hallo zusammen
                        Ich habe gestern versucht die neue Version 3.5.0.0 auf den TJA450 einzuspielen.
                        Leider bleibt der Server nach dem Update nach ein paar Stunden hängen. Nur mit einem Reboot (switch off) und dem downgrade auf V. 3.4.0.6 konnte ich den Domovea Server wieder in Betrieb nehmen.
                        Der Hager Domovea Support versucht den Fehler zu reproduzieren.
                        Auf welcher Plattform konntet ihr die neue Version erfolgreich installieren?
                          Bei mir das selbe... gestern das Update gemacht und heute keine Verbindung mehr. switch off bringt nichts, downgrade habe ich noch nicht versucht.
                            Sehr fein... :-)))
                              Also bei mir läuft es seit ein paar Tagen stabil, Oberfläche Tablet " Windows10", sämtliche IOS Produkte auch ohne Probleme.
