Wer traut sich?
HAGER DOMOVEA 3.5.0.0 steht zum Download bereit
Zitat von Marc83 Beitrag anzeigenBin ich der einzige, der noch nie Probleme damit hatte?!
Du und die Tester bei hager.
V3.5.0.0 New functions
• TXA100 project automatic import
• Compatibility with new ATC thermostat
• Compatibility new easy weather station
Bug fix Client
• Measures o In some configuration the energy synthesis is not displayed on the dashboard o Bad display of the red zone for electrical production device o Changing parameters of the devices are not spread to energy synthesis o The energy synthesis is displayed on the dashboard even if no energy device is present in the database o The creation of a measure on a device doesn't automatically update the energy synthesis o In personalized mode, it should not be possible to align less than 7 days • Sequences o The % variable isn't available to set the shutter inclination o Bad time display of next sequences on the dashboard widget when using ephemeris • Camera o The camera picture is cut when reducing the window to the minimum size
Client domovea touch panel • Some groups are unavailable via right side navigation panel if the database has more than one groups page • Freeze between two pages of devices when sliding slowly
Web configuration tool • Problem when recording a program with more than 100 events • Impossible to set a value >9% for generic device with the DPT '1 byte unsigned Percent'
General • In some case the update process on the client doesn’t succeed and allow a client with a version x to be connected to a server with a version x+1 • Wrong values on ventilation device when rebooting the server
Hallo zusammen
Ich habe gestern versucht die neue Version 3.5.0.0 auf den TJA450 einzuspielen.
Leider bleibt der Server nach dem Update nach ein paar Stunden hängen. Nur mit einem Reboot (switch off) und dem downgrade auf V. 3.4.0.6 konnte ich den Domovea Server wieder in Betrieb nehmen.
Der Hager Domovea Support versucht den Fehler zu reproduzieren.
Auf welcher Plattform konntet ihr die neue Version erfolgreich installieren?
Sehr fein... :-)))Smart Building Design GmbH (everything) - www.smart-building-design.com
