callidomus.core kill
2016-10-16 21:43:21 DEBUG _init Item core.timestamp = 201610142229.0 via Logic None None
2016-10-16 21:43:21 ERROR Main Exception: 'utf-8' codec can't decode byte 0xe4 in position 164: invalid continuation byte
Traceback (most recent call last):
File "/mfs/core/lib/logic.py", line 111, in generate_bytecode
code = open(self.filename, encoding='utf_8_sig').read()
File "/usr/local/lib/python3.5/codecs.py", line 321, in decode
(result, consumed) = self._buffer_decode(data, self.errors, final)
File "/usr/local/lib/python3.5/encodings/utf_8_sig.py", line 69, in _buffer_decode
return codecs.utf_8_decode(input, errors, final)
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xe4 in position 164: invalid continuation byte
2016-10-16 21:43:21 DEBUG _init Item core.start = 2016-10-16 21:43:21.322825+02:00 via Logic None None
2016-10-16 21:43:21 DEBUG Main Logic: test
