LBS19000605 Synology
    Klar :-)
    [root@edomi ~]# snmpwalk -v2c -c public  10.0.40.11 .1.3.6.1.4.1.6574.4
    SNMPv2-SMI::enterprises.6574.4.1.1.0 = STRING: "Smart-UPS 750"
    SNMPv2-SMI::enterprises.6574.4.1.2.0 = STRING: "American Power Conversion "
    SNMPv2-SMI::enterprises.6574.4.1.3.0 = STRING: "3S1602X09124  "
    SNMPv2-SMI::enterprises.6574.4.1.4.0 = STRING: "ups"
    SNMPv2-SMI::enterprises.6574.4.2.1.0 = STRING: "OL"
    SNMPv2-SMI::enterprises.6574.4.2.5.0 = STRING: "Smart-UPS 750"
    SNMPv2-SMI::enterprises.6574.4.2.6.1.0 = STRING: "American Power Conversion "
    SNMPv2-SMI::enterprises.6574.4.2.6.2.0 = STRING: "2016/01/14"
    SNMPv2-SMI::enterprises.6574.4.2.7.0 = STRING: "3S1602X09124  "
    SNMPv2-SMI::enterprises.6574.4.2.8.0 = STRING: "051d"
    SNMPv2-SMI::enterprises.6574.4.2.9.0 = STRING: "0003"
    SNMPv2-SMI::enterprises.6574.4.2.10.1.0 = STRING: "UPS 09.3 / ID=18"
    SNMPv2-SMI::enterprises.6574.4.2.14.3.0 = INTEGER: 20
    SNMPv2-SMI::enterprises.6574.4.2.15.2.0 = INTEGER: -1
    SNMPv2-SMI::enterprises.6574.4.2.15.3.0 = INTEGER: -1
    SNMPv2-SMI::enterprises.6574.4.2.22.0 = STRING: "enabled"
    SNMPv2-SMI::enterprises.6574.4.3.1.1.0 = Opaque: Float: 100.000000
    SNMPv2-SMI::enterprises.6574.4.3.1.2.0 = Opaque: Float: 10.000000
    SNMPv2-SMI::enterprises.6574.4.3.1.4.0 = Opaque: Float: 50.000000
    SNMPv2-SMI::enterprises.6574.4.3.2.1.0 = Opaque: Float: 27.000000
    SNMPv2-SMI::enterprises.6574.4.3.2.2.0 = Opaque: Float: 24.000000
    SNMPv2-SMI::enterprises.6574.4.3.6.1.0 = INTEGER: 6900
    SNMPv2-SMI::enterprises.6574.4.3.6.2.0 = INTEGER: 120
    SNMPv2-SMI::enterprises.6574.4.3.12.0 = STRING: "PbAc"
    SNMPv2-SMI::enterprises.6574.4.7.1.0 = STRING: "usbhid-ups"
    SNMPv2-SMI::enterprises.6574.4.7.2.0 = STRING: "DSM6-1-14872-161104"
    SNMPv2-SMI::enterprises.6574.4.7.3.0 = STRING: "APC HID 0.95"
    SNMPv2-SMI::enterprises.6574.4.7.4.0 = STRING: "0.38"
    SNMPv2-SMI::enterprises.6574.4.7.5.0 = INTEGER: 5
    SNMPv2-SMI::enterprises.6574.4.7.6.0 = STRING: "auto"
    SNMPv2-SMI::enterprises.6574.4.7.7.0 = INTEGER: 30
    Danke und LG, Dariusz
      Ich vermute das sind weitere Informationen die der LBS auslesen könnte ?
        Die Fehlermeldungen sind mir vorhin nicht aufgefallen und dann hat wollte mein PC nach einem Update nicht mehr starten.
        Dann spar ich mir mal die Mühe, oder brauchst du von meiner USV auch die Infos?
          sehr auskunftsfreudig ist das Ding ja nicht:
          Device model:
          Device manufacturer:
          Device serial number:
          Device type (ups, pdu, scd, psu):
          UPS status:
          UPS model:
          UPS manufacturer:
          UPS manufacturing date:
          UPS serial number:
          Vendor ID for USB devices:
          Product ID for USB devices:
          UPS firmware:
          Interval to wait after shutdown with delay command (seconds):
          Time before the load will be rebooted (seconds):
          Time before the load will be shutdown (seconds):
          UPS beeper status (enabled, disabled or muted):
          Battery charge:
          Remaining battery level when UPS switches to LB (percent):
          Battery level when UPS switches to Warning state (percent):
          The magnitude of the present battery voltage:
          Nominal battery voltage:
          Battery runtime (seconds):
          Remaining battery runtime when UPS switches to LB (seconds):
          Battery chemistry:
          Driver name:
          Driver version (NUT release):
          Driver version data:
          Internal driver version (if tracked separately):
          Poll interval setup in configuration file:
          Port setup in configuration file:
          Poll frequency:
          Ich hab Dir mal die vorhandenen Werte kommentiert. Ist da was dabei, das interessant ist?
            Klaus007 Ich befürchte mal, das deine USV ähnlich auskunftsfreudig ist, wie die von coliflower. Da wird einfach nicht mehr kommen. Hauptsache die Restlaufzeit kommt. Wenn die einen Wert unterschreitet, fahre ich EDOMI runter.
              Ich werde es mir anschauen was Sinn macht zu monitoren - die Unterschreitung der Restlaufzeit macht sicher am meisten Sinn um EDOMI runter zu fahren (die DS214+ macht das ja eh automatisch) ...
              Ich habe auch noch den 605er LBS installiert - hier die Werte die ankommen … scheint zu funktionieren :-)
              Der Ausgang A1 versteht das „ä“ nicht ;-)
              DANKE !
                Dann solltest Du den LBS UTF8 formatiert speichern Das Synology die eigenen Datenpunkte immer richtig ausgibt, davon bin ich mal ausgegangen. BTW besteht Interesse für einen LBS der den Raspi überwacht?
                  Für mich reichen die vorhanden Werte, danke.
                    Ich habe nichts entdeckt das noch interessant wäre …
                    Ich habe auch keinen Raspi ...
                    Kann man den HP-1820-24G überwachen ?
                    Ich werde mal bei Gelegenheit den PRTG Server starten und schauen womit ich mich damals so gespielt habe … Auf jeden fall war es möglich alle IPs zu „tracken“ …
                      Ja kann man. Da sollte man aber vorher checken, was man braucht. Da gibt es ein paar 1000 Datenpunkte Da hat jeder Port ca 20. Einige Switche lassen sich auch darüber bedienen (Ports abschalte etc.) Das sollten wir aber getrennt abhandeln. Kannst ja mal anläuten
                        Naja, da muss man überlegen.
                        Nicht das die Synology Runterfahrzeit vor der in Edomi liegt. Sollte aufjedefall ein höherer wert seit.
                          Und vor allem das der switch dazwischen auch an der USV hängt
                            Ja kann man. Da sollte man aber vorher checken, was man braucht. Da gibt es ein paar 1000 Datenpunkte Da hat jeder Port ca 20 ... Kannst ja mal anläuten
                            Wenn es dir mal fad werden sollte, könnten wir mal darüber schauen … Vielleicht macht es Sinn pro Port ein einen LBS zu verwenden (denselben) und einen weiteren LBS für die „allgemeinen“ Sachen ? Aber wie du sagtest - separat :-)
                            Hier habe ich noch ein paar Bilder was die Syno noch könnte - falls überhaupt interessant (vielleicht die LANs) ...
                              Glaub mir, auch PRTG zeigt nur einen Bruchteil an. Das ist etwas komplexer....
                                Ich hab das Edomi runterfahren auch mal mit dem Error Ausgang des USV LBS verbunden.
                                So das die Logik nur getriggert wird wenn der Baustein keine Fehler ausgibt.
                                Der switch hängt auch an der USV
                                Kann man das so machen ?
