| 2021-04-05 16:33:35 | 379643 | 2608 | Debug | RoborockMe:: ip = 192.168.10.31; token = 123456789; SequenceID: 0 |
| 2021-04-05 16:33:55 | 397437 | 2608 | Debug | roborocMe:: ok |
| 2021-04-05 16:33:55 | 397720 | 2608 | Info | Roboter reagiert nicht. |
| 2021-04-05 16:33:55 | 407182 | 2608 | Debug | Ausführungszeit: 22.888426780701 [s] |
[TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
[TR="class: cke_show_border"]
[TD]2021-03-29 22:04:55[/TD]
[TD]248573[/TD]
[TD]8406[/TD]
[TD]Info[/TD]
[TD]Login erfolgreich![/TD]
[/TR]
[TD]249634[/TD]
[TD]8406[/TD]
[TD]Debug[/TD]
[TD]uid=....[/TD]
[/TR]
[TD]249815[/TD]
[TD]8406[/TD]
[TD]Debug[/TD]
[TD]ip: bzw. token : sind leer. Cloud->getDeviceStatus()[/TD]
[/TR]
[TD]451741[/TD]
[TD]8406[/TD]
[TD]Info[/TD]
[TD]DeviceStatus ok[LF][/TD]
[/TR]
[TD]452054[/TD]
[TD]8406[/TD]
[TD]Kritisch[/TD]
[TD]Roboter ist nicht Erreichbar![LF][/TD]
[/TR]
[TD]452364[/TD]
[TD]8406[/TD]
[TD]Debug[/TD]
[TD]CloudStateInformation:array(2) {[LF] [0]=>[LF] array(27) {[LF] ["did"]=>[LF] string(9) "39690001"[LF] ["token"]=>[LF] string(32) "31xxx73"[LF] ["longitude"]=>[LF] string(10) "0.00000000"[LF] ["latitude"]=>[LF] string(10) "0.00000000"[LF] ["name"]=>[LF] string(11) "Roborock S7"[LF] ["pid"]=>[LF] string(1) "0"[LF] ["localip"]=>[LF] string(13) "192.168.20.81"[LF] ["mac"]=>[LF] string(17) "Bxxx"[LF] ["ssid"]=>[LF] string(9) "ssidname"[LF] ["bssid"]=>[LF] string(17) "6Axxx"[LF] ["parent_id"]=>[LF] string(0) ""[LF] ["parent_model"]=>[LF] string(0) ""[LF] ["show_mode"]=>[LF] int(1)[LF] ["model"]=>[LF] string(19) "roborock.vacuum.a15"[LF] ["adminFlag"]=>[LF] int(1)[LF] ["shareFlag"]=>[LF] int(0)[LF] ["permitLevel"]=>[LF] int(16)[LF] ["isOnline"]=>[LF] bool(true)[LF] ["desc"]=>[LF] string(14) "Gerät online "[LF] ["extra"]=>[LF] array(4) {[LF] ["isSetPincode"]=>[LF] int(0)[LF] ["fw_version"]=>[LF] string(10) "4.1.2_0816"[LF] ["needVerifyCode"]=>[LF] int(0)[LF] ["isPasswordEncrypt"]=>[LF] int(0)[LF] }[LF] ["uid"]=>[LF] int(1578902190)[LF] ["pd_id"]=>[LF] int(70146)[LF] ["password"]=>[LF] string(0) ""[LF] ["p2p_id"]=>[LF] string(0) ""[LF] ["rssi"]=>[LF] int(0)[LF] ["family_id"]=>[LF] int(0)[LF] ["reset_flag"]=>[LF] int(0)[LF] }[LF] [1]=>[LF] array(27) {[LF] ["did"]=>[LF] string(19) "blt.4.106ljm6q4g000"[LF] ["token"]=>[LF] string(24) "44a75eeb0cedcb3b0a12a98c"[LF] ["longitude"]=>[LF] string(10) "0.00000000"[LF] ["latitude"]=>[LF] string(10) "0.00000000"[LF] ...[/TD]
[/TR]
[TD]452624[/TD]
[TD]8406[/TD]
[TD]Debug[/TD]
[TD]cloud->isAccessible:Y-E10=-E11=[/TD]
[/TR]
[TD]452724[/TD]
[TD]8406[/TD]
[TD]Kritisch[/TD]
[TD]IP/Token leer! Baustein muss richtig konfiguriert werden! Abbruch[/TD]
[/TR]
[/TABLE]
