PHP 7.2.34 (cli) (built: Sep 27 2022 19:08:09) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.2.0, Copyright (c) 1998-2018 Zend Technologies
Ist eine Installation auf Blech auf einem APU2C4
Ich hab leider keine Ahnung von Linux und steh hier vor Böhmischen Dörfern
[root@edomi influx-client]# yum search mbstring
Geladene Plugins: fastestmirror
Loading mirror speeds from cached hostfile
* base: mirror.imt-systems.com
* epel: mirror.imt-systems.com
* extras: mirror.ratiokontakt.de
* remi-php72: merlin.fit.vutbr.cz
* remi-safe: merlin.fit.vutbr.cz
* updates: mirror.imt-systems.com
================================================== ================= N/S matched: mbstring ================================================== =================
php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php54-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php55-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php56-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php70-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php71-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php72-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php73-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php74-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php80-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php81-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
php82-php-mbstring.x86_64 : A module for PHP applications which need multi-byte string handling
only-Übereinstimmungen in Name und Zusammenfassung, «Alles suchen» für vollständige Suche.
[root@edomi tmp]# php installer
All settings correct for using Composer
Downloading...
Composer (version 2.4.3) successfully installed to: /tmp/composer.phar
Use it: php composer.phar
[root@edomi tmp]# mv -f composer.phar /usr/local/bin/composer
[root@edomi tmp]# rm -rf /usr/local/edomi/www/admin/include/php/influx-client
[root@edomi tmp]# mkdir /usr/local/edomi/www/admin/include/php/influx-client
[root@edomi tmp]# cd /usr/local/edomi/www/admin/include/php/influx-client
[root@edomi influx-client]# composer require influxdata/influxdb-client-php:2.8
Do not run Composer as root/super user! See https://getcomposer.org/root for details
Continue as root/super user [yes]? yes
https://repo.packagist.org could not be fully loaded (curl error 28 while downloading https://repo.packagist.org/packages.json: timed out before SSL handshake), package information was loaded from the local cache and may be out of date
In VersionParser.php line 521:
Could not parse version constraint 2.8: Invalid version string "2.8"
require [--dev] [--dry-run] [--prefer-source] [--prefer-dist] [--prefer-install PREFER-INSTALL] [--fixed] [--no-suggest] [--no-progress] [--no-update] [--no-install] [--no-audit] [--audit-format AUDIT-FORMAT] [--update-no-dev] [-w|--update-with-dependencies] [-W|--update-with-all-dependencies] [--with-dependencies] [--with-all-dependencies] [--ignore-platform-req IGNORE-PLATFORM-REQ] [--ignore-platform-reqs] [--prefer-stable] [--prefer-lowest] [--sort-packages] [-o|--optimize-autoloader] [-a|--classmap-authoritative] [--apcu-autoloader] [--apcu-autoloader-prefix APCU-AUTOLOADER-PREFIX] [--] [<packages>...]
[root@edomi influx-client]# cd /usr/local/edomi/www/admin/include/php/
[root@edomi php]# mkdir influx-client
mkdir: das Verzeichnis „influx-client“ kann nicht angelegt werden: Die Datei existiert bereits
[root@edomi php]# cd influx-client/
Info from https://repo.packagist.org: #StandWithUkraine
Cannot use influxdata/influxdb-client-php's latest version 3.0.0 as it requires ext-mbstring * which is missing from your platform.
In PackageDiscoveryTrait.php line 313:
Package influxdata/influxdb-client-php has requirements incompatible with your PHP version, PHP extensions and Composer version:
- influxdata/influxdb-client-php 3.0.0 requires ext-mbstring * but it is not present.
