LBS(Sammlung) Squeeze
    Hier noch ein aktuellerer TraceLOG::
    2016-04-01 16:48:21 613832 EXEC 25582 LBS19000200(13): Using named pipe '/tmp/EDOMI_LBS19000200.command.pipe' Ok
    2016-04-01 16:48:21 614239 EXEC 25582 LBS19000200(13): daemon started Ok
    2016-04-01 16:48:21 616095 EXEC 25582 LBS19000200(13): Sending 'listen 1' Ok
    2016-04-01 16:48:21 722666 EXEC 25582 LBS19000200(13): RECV: listen 1 Ok
    2016-04-01 16:48:21 723077 EXEC 25582 LBS19000200(13): Sending 'players' Ok
    2016-04-01 16:48:21 828192 EXEC 25582 LBS19000200(13): RECV: players count:2 Ok
    2016-04-01 16:48:21 829174 EXEC 25582 LBS19000200(13): Sending 'players 0 1' Ok
    2016-04-01 16:48:21 938360 EXEC 25582 LBS19000200(13): RECV: players 0 1 count:2 playerindex:0 playerid:00:1e:06:10:1d:e1 uuid: ip:192.168.0.110:41812 name:Wohnzimmer model:squeezelite isplayer:1 displaytype:none canpoweroff:1 connected:1 Ok
    2016-04-01 16:48:21 938878 EXEC 25582 LBS19000200(13): Sending '00:1e:06:10:1d:e1 status - 1 subscribe:0 tags:aAcCdDefgiIjJKlLNoOqrstTuxy' Ok
    2016-04-01 16:48:22 063110 EXEC 25582 LBS19000200(13): RECV: 00:1e:06:10:1d:e1 status - 1 subscribe:0 tags:aAcCdDefgiIjJKlLNoOqrstTuxy player_name:Wohnzimmer player_connected:1 player_ip:192.168.0.110:41812 power:0 signalstrength:0 mode:stop remote:1 current_title:Rockland Radio (Frankfurt am Main) time:0 rate:1 sync_master:00:1e:06:10:1d:e1 sync_slaves:b8:27:eb:a1:be:f0 mixer volume:50 playlist repeat:2 playlist shuffle:0 playlist modeff seq_no:0 playlist_cur_index:0 playlist_timestamp:1459513824.11793 playlist_tracks:1 digital_volume_control:1 remoteMeta:HASH(0x43e2900) playlist index:0 id:-68555256 title:Rockland Radio (Frankfurt am Main) coverid:-68555256 duration:0 coverart:0 artwork_urllugins/TuneIn/html/images/icon.png type:Radio bitrate:0 url:http://opml.radiotime.com/Tune.ashx?...b3&filter=s:~R remote:1 year:0 Ok
    2016-04-01 16:48:22 066123 EXEC 25582 LBS19000200(13): Sending 'players 1 2' Ok
    2016-04-01 16:48:22 174320 EXEC 25582 LBS19000200(13): RECV: players 1 2 count:2 playerindex:1 playerid:b8:27:eb:a1:be:f0 uuid: ip:192.168.0.114:45770 name:Esszimmer model:squeezelite isplayer:1 displaytype:none canpoweroff:1 connected:1 Ok
    2016-04-01 16:48:22 174721 EXEC 25582 LBS19000200(13): Sending 'b8:27:eb:a1:be:f0 status - 1 subscribe:0 tags:aAcCdDefgiIjJKlLNoOqrstTuxy' Ok
    2016-04-01 16:48:22 297480 EXEC 25582 LBS19000200(13): RECV: b8:27:eb:a1:be:f0 status - 1 subscribe:0 tags:aAcCdDefgiIjJKlLNoOqrstTuxy player_name:Esszimmer player_connected:1 player_ip:192.168.0.114:45770 power:0 signalstrength:0 mode:stop remote:1 current_title:Rockland Radio (Frankfurt am Main) time:0 rate:1 sync_master:00:1e:06:10:1d:e1 sync_slaves:b8:27:eb:a1:be:f0 mixer volume:38 playlist repeat:2 playlist shuffle:0 playlist modeff seq_no:0 playlist_cur_index:0 playlist_timestamp:1459513824.11793 playlist_tracks:1 digital_volume_control:1 remoteMeta:HASH(0x41825f0) playlist index:0 id:-68555256 title:Rockland Radio (Frankfurt am Main) coverid:-68555256 duration:0 coverart:0 artwork_urllugins/TuneIn/html/images/icon.png type:Radio bitrate:0 url:http://opml.radiotime.com/Tune.ashx?...b3&filter=s:~R remote:1 year:0 Ok
    2016-04-01 16:48:22 300324 EXEC 25582 LBS19000200(13): Sending 'version ?' Ok
    2016-04-01 16:48:22 405550 EXEC 25582 LBS19000200(13): RECV: version 7.9.0 Ok
    2016-04-01 16:48:22 406464 EXEC 25582 LBS19000200(13): Verbunden mit LMS an 192.168.0.110:9090, Version 7.9.0, 2 Player verbunden
      ZITAT: "Hier ist n Knopp ... da steht ON/OFF ... soll ich da ma draufdrücken .... ;-) .... => Es läuft .... es läuft .... ich werd verrückt ... es läuft!!!" /QUELLE: gerade unbekannt ;-)
      (Fehler war: eine fehlende Verbindung zum Server. Der Server hat also die KommandoKO vom Client von mir nicht bekommen. Tze .... )
        Jaja... 200 puls
        Es sind jetz uebrigens die drei wichtigen LBS in neuen Versionen vorhanden:
        19000200 (Server) @0.6
        19000201 (Client) @0.4
        19000202 (Kommando) @0.5
        Bedeutende Aenderungen waeren:
        -Unterstuetzung der Sleep-Funktionalitaet
        -Unterstuetzung von dynamischen bzw SQL-Playlisten
        -Der Client-LBS zeigt jetzt bei verbubbelten Playern schonmal den jeweiligen Master der Sync-Gruppe an (bzw alle verbubbelten Slaves). Wie ich von da aus weiter mache, weiss ich allerdings noch nicht so genau
        viel Spass :: Michael
          Hi Michael,
          irgendwas passt da nicht .... wusstest Du, dass 1 x 2.5 = 10 ist ... ;-) ... ?
          >> Ziel sollte sein: 10er Schritte beim verringern bzw. erhöhen der Lautstärke. Dazu habe ich E19 des SqueezeCommand 0.5 auf 2.5 und die Schritte an E8 bzw. E9 auf 1 gesetzt. Die 10er Schritte habe ich nun. Aber wieso? Vor dem Update auf 0.5 war ebenfalls eine kuriose Berechnung für das Ergebnis notwendig: 1 x 0.5 = 10
          ... nur zur Info: Es funzt ja... alllerdings komisch, oder?
          Noch etwas: Generell ist mein Status in der Visu sehr träge; d.h. ich sehe bei manchen Elementen die Änderung erst nach 5-20 Sek.; gerade nach dem ersten aktivieren des Projekts. Wenn dann der Statuswechsel einmal erfolgt ist, funktioniert es relativ zeitnah (im von gaert öfter schon mal angesprochenen Rahmen von ca 3 Sek). Ich dachte, dass diese Problem nicht mehr auftauchen müsste, nach dem Wechsel in den EXEC -Bereich.
            Nein, das ist mir neu
            Aaaaber: E8/E9 sind keine Schritte, sondern erhoehen/erniedrigen die Laustaerke um die Schrittweite wenn eine "1" anliegt... eine "2" geht vermutlich auch, fuehrt aber zum selben Ergebnis. Die Schrittweite muss (AFAIK) ein Integer sein, der LMS arbeitet intern mit einer Lautstaerke von 0-100, jeweils in ganzzahligen Schritten. Ich hab keine Ahnung was passiert wenn man da nen Float uebergibt (also zB 2.5), aber ich mir zumindest relativ sicher, dass nicht das gewuenschte Resultat bei rumkommt
            Also: E19 ein ganzzahliger Wert zwischen 0 und 100 (wobei 0 und 100 vermutlich nicht ganz so viel Sinn ergeben ) und E8 und E9 sind keine Zaehler.
            Was die Traegheit angeht: ich hab noch immer keine Visu und kann das daher noch immer nicht direkt testen
            Sind deine Player gesynced? Generell pollt der Baustein nicht am LMS, der LMS meldet den Status-Wechsel an den Baustein. Also ist entweder der LMS langsam, oder irgendwas in Edomi. Was passiert denn, wenn Du fuer den Server-LBS das Debugging aktivierst? Siehst Du dann im tracelog die Status-Meldungen sofort oder kommen die da auch schon verzoegert an?
              ah .... dann darf ich in der Visu nicht sagen "Erhöhe / Addiere KO um 1" für E8 / E9 ... verstehe! Es reicht also, wenn die eins geliefert wird, wenn der Button gedrückt wird.... okay ... da habe ich wohl zu komplizert gedacht ;-)
                Ja, beide Player sind gesynct; so wie im LMS hier in diesem Thread irgendwo empfohlen. In edomi geht eigentlich noch (fast) gar nichts; außer eine Mini-Testvisu, die aber nur die KOs (deiner) LBS abfragt. Sprich: die LBS Squeeze und CalDAV; und einen LBS für Müllkalender. Mehr habe ich noch nicht geschafft... Das mit dem Debugging für den Server-LBS probiere ich mal. Wir hatten den Client aktiviert (s..o.) oder? Am besten schmeiße ich das Debug dann mal raus (bzw, disable es), oder?
                  Ich weiss nicht mehr, Du hattest ja mehrere Probleme
                  Hier war noch wer anders der von Verzoegerungen im Setup mit verbubbelten Playern berichtet hatte... ich habs selber noch nicht nachgestellt, da ich mich mit dem Syncen erst recht oberflaechlich befasst habe (und das ja offiziell auch noch garnicht unterstuetzt wird )
                    Jetzt habe ich das mal getestet:
                    - E19 => Erhöhungswert auf 10
                    - E8 / E9 in Visu auf KO-Wert 1 zuweisen
                    => Resultat: Erhöhung von 10 auf 50 auf 90 und vice versa ... )
                      => Das lag - zugegebenermaßen - an meiner Ungeduld => RTFM würde helfen! Die besprochenen Probs sind weg! Das o.g. ist neu...
                        Wenn die Player verbubbelt sind (vor allem im Bezug auf die Laustaerke), dann waere ich jetzt bei 2 Playern von einer Erhoehung von 20 ausgegangen - weil Du ja beide Player parallel ansteuerst (was im verbubbelten Setup ja ueberfluessig - oder besser redundant - ist).
                        Wieso da jetzt 40 bei rauskommt weis sich auch nicht, aber irgendwie wirds schlussendlich 4x veraendert. Probier bitte mal die PLayer nicht zu syncen, dann muesste das mit der Lautstaerke auf jeden Fall schonmal funktionieren und vllt verschwinden ja die Verzoegerungen in der GUI ebenfalls...
                          Das war schon mal ein guter Hinweis! Das syncen in LMS war der Grund. Nun bin ich beim Delta von 20; statt 40 ... also E19 wieder auf 5 und gudd is ... ;-)
                            Ich habs grad nochmal nachgestellt:
                            a) der Kommando LBS wertet 0 und 1 aus - bei Volume+ zB wird die Lautstaerke erhoeht wenn Eingang=1 und verringert wenn Eingang=0
                            b) wenn ich (ueber die Admin-GUI) eine 1 reinschreibe, wird die Lautstaerke auch korrekt um die Schrittweite erhoeht
                            Jemand hatte aber mal geschrieben, dass er Werte aus der Visu doppelt bekommt, ich weiss aber grad nicht mehr wer/wo/wie und in welchem Zusammenhang. Vielleicht ist es bei dir irgendwie aehnlich, die Bausteine machen das jedenfalls erstmal korrekt.
                              Ich bin davon ausgegangen, dass die Lautstärke reduziert wird, wenn der Eingang "Volume-" eine 1 bekommt und analog bei "Volume+"... also quasi als zu setzendes Flag zu verstehen. Dann kann ich ja auch für beide Zustände mit einen KO arbeiten. Okay ... :-)
                              Zuletzt geändert von MIT; 05.04.2016, 20:01.
                                Ich habe nun angefangen die tollen Bausteine mit einer VISU-Seite zu verknüpfen. Ich hab' da nun folgendes Problem, dass mehr ein schwieriges EDOMI Verhalten ist, als ein Fehler in den Bausteinen: Wenn ich einen Player benutzen will, der aktuell nicht connected ist, bekomme ich bei einem Refresh auf allen Ausgängen einen Leerstring. Den kann ich aber nicht in die Visu bringen, da sich ein Leerstring mit keinem der beiden Eingänge einer Ausgangsbox in ein KO schreiben lässt. Stell ich mich da zu dumm? Muss ich da extra einen LBS bauen, der diese Info umwandelt? Kann man keinen Eingang in einer Ausgangsbox haben, der alles durchtriggert?
