Zitat von Msinn
Gruss,
[LIST][*]2017-11-03 00:10:59 ERROR Main Plugin sonos exception: expected an indented block (__init__.py, line 2748)[*]Traceback (most recent call last):[*]File "/usr/local/smarthome/lib/plugin.py", line 63, in __init__[*]plugin_thread = PluginWrapper(smarthome, plugin, classname, classpath, args, instance)[*]File "/usr/local/smarthome/lib/plugin.py", line 99, in __init__[*]exec("import {0}".format(classpath))[*]File "<string>", line 1, in <module>[*]File "/usr/local/smarthome/plugins/sonos/__init__.py", line 2748[*]sonos_speaker[uid] = Speaker(uid=uid, logger=logger)[*]^[*]IndentationError: expected an indented block[/LIST]
local_webservice_path: /xxx/snippet local_webservice_path: /xxx/tts
2017-11-12 15:37:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:37:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:37:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:39:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:39:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:39:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:39:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:39:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:39:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:41:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:41:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:41:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:41:52 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:41:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:41:52 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:43:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:43:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:43:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:43:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:43:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:45:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:45:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:45:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:45:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:45:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:47:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:47:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:47:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:47:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:47:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:47:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:49:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:49:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:49:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:49:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:49:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:51:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:51:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:51:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:51:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:51:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:53:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:53:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:53:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:53:52 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:53:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:53:52 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:55:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:55:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:55:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:55:52 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:55:52 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:57:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:57:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:57:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:57:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:57:51 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 15:59:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=14, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 15:59:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 15:59:52 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 15:59:52 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-11-12 15:59:52 INFO sonos_discover_scheduler Sending Browse [('ObjectID', 'SQ:'), ('BrowseFlag', 'BrowseDirectChildren'), ('Filter', '*'), ('StartingIndex', 0), ('RequestedCount', 100), ('SortCriteria', '')] to 192.168.8.67
2017-11-12 16:01:51 INFO sonos_discover_scheduler Sending discovery packets on [<socket.socket fd=16, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>, <socket.socket fd=17, family=AddressFamily.AF_INET, type=SocketKind.SOCK_DGRAM, proto=17, laddr=('0.0.0.0', 0)>]
2017-11-12 16:01:51 INFO sonos_discover_scheduler Sending GetZoneGroupState None to 192.168.8.67
2017-11-12 16:01:51 INFO sonos_discover_scheduler Received status 200 from 192.168.8.67
2017-11-12 16:01:51 INFO sonos_discover_scheduler Sending GetLEDState None to 192.168.8.67
2017-12-28 23:26:28 ERROR Main Plugin 'sonos' exception during import of __init__.py: No module named 'plugins.sonos.soco' File "/usr/local/smarthome/plugins/sonos/__init__.py", line 42, in <module> from plugins.sonos.soco.exceptions import SoCoUPnPException ImportError: No module named 'plugins.sonos.soco'
