Hatte ich schon auf meinen Zettel geschrieben. Macht zwar die Konfig etwas komplizierter, aber Sinn macht es trotzdem. Am WE mach ich (hoffentlich) was fertig.
Gruss,
Gruss,
if sh.Zentral.Klingel() == True:
time.sleep(30)
sh.EG.Wohnzimmer_TV_schalten(1)
sh.MySonos.Wohnzimmer.play_snippet.snippet_volume(90)
sh.MySonos.Wohnzimmer.play_snippet('glocke.mp3')
2018-01-06 08:18:58 ERROR logics.Klingel Item MySonos.Wohnzimmer.play_snippet: problem running <bound method Sonos.update_item of <plugins.sonos.Sonos object at 0x7226bd10>>: Language not supported: /tmp/tts
Traceback (most recent call last):
File "/usr/local/smarthome/lib/item.py", line 788, in __update
method(self, caller, source, dest)
File "/usr/local/smarthome/plugins/sonos/__init__.py", line 2551, in update_item
fade_in)
File "/usr/local/smarthome/plugins/sonos/__init__.py", line 2138, in play_snippet
sonos_speaker[self.coordinator].play_tts(audio_file, local_webservice_path, webservice_url, volume, fade_in)
File "/usr/local/smarthome/plugins/sonos/__init__.py", line 2167, in play_tts
tts = gTTS(tts, self._logger, tts_language)
File "/usr/local/smarthome/plugins/sonos/tts.py", line 145, in __init__
raise Exception('Language not supported: %s' % lang)
Exception: Language not supported: /tmp/tts
tts_language:
type: str
value: de
sonos_attrib: tts_language
