- √ - HomeServer problem---Sorry dont know german
    HS/FS - √ - HomeServer problem---Sorry dont know german
    Hi guys
    I am sorry i dont know German (sorry) and hopefully that shoouldnt put you guys off frm helping. have just started workign with Home Server. I am finding it real hard to connect it to my system at work.
    I have set up at Bank board at work that controls the lights, blinds and windows and works perfectly well. So now i decided to make my way to home server.
    But i can not seem to access the server at home all through my lap top. I have a router ip on the board as well Which works fine.
    I tried:
    Connected to my HS network via network cable
    Connected laptop to my network via cable netowork
    both these network cables connected to the switch (network owner).
    BUT I CAN NOT ACCESS THE HS THROUGH MY LAPTOP.
    have checked the ip address 198.168.0.11 its the default and its not been taken over by any other device.
    PLEASE can someone can give me help.If you in detail on how to connect the HS and log into it. That would be great.appreciate the time and effort.
    Thank you
    vimal
    Did you transfer an initial project defining the bus acces type, adresses etc. and also the IP adress via serial transfer from the Experten-Software?
    Best regards
    2 Objekte, 6 Linien + KNX/IP-Bereich, HS 3 SW 2.8, Visu mit 2x 15"-Touch, Softwaregateway KNX/IP für 2x Novelan Wärmepumpe, viele Ideen und wenig Zeit
      Thanks for the prompt reply appreciate it.
      No dint do that if you can tell me bit more clearly on how to go about that please. I have downloaded the expert software, but never worked with it before.
      if you can tell me how to transfer the files that would be awesome!
      Thank you veryyyy much
      vimal
        Sory, but that's the very basics: You MUST prepare your own "project" within the experten-Software and load that into the Homeserver, otherwise it is just a piece of dumb but expensive hardware.
        I think there is a GIRA "getting started" document which is also delivered with the HS, however i dont know if it is customized into english if you buy that thing in the UK.
        Install the Experten-Software, take one of the example projects, customize it to your own setup (at least bus acess mode and IP adresses) and load it onto the HS via RS232. Next loads after that can be done via TCP/IP (and will therefore be quite faster).
        Regards,
          cheers for that mate appreciate it.
          i do have the commissioning manual but doesnt say anythign about the transferring of these files.
          i know you have helped me a lot. but can you tell me where i can find and change the IP adress and bus access mode please
          Thanks again
          vimal
            You need the "Experte"-Software (runs on Windows) which is provided on CD in the HS package. If not, you can download it there Gira Download (you have to register with Gira to get access to this download).
            Install this software and configure your HS according to your needs, at least you should enter the basic information for your network. Then you can transfer your project to the HS, the initial transfer has to be made via RS232 (cable should be provided in the box).
            You might need to update the HS-Firmware according to the Experte-Version.
            After the initial transfer (containing a project with valid network configuration) you can access the HS via network / IP.
              Hi guys
              with the advice from the guys above and after pondering in the net, to certain level understand this but i still have problems:
              1.Since i am doing this is the first time i have to do it through RS232:
              so Master Data---project---Project setting----eib&iets::: here what do i select for the interface? or is this only for Ip router.
              2. when i checked the project these errors come up:
              --Host adress or Ip port invalid
              --invalid prefix or suffix entered.
              3. the same errors come up when i am transferring them as wel
              and i guess the transfer is stopped
              any advice on this? cheers for the help so far thank you
              vimal
                Goto project, settings, Network first in order to enter ip-Adress, Gateway etc.
                It should be the top icon on the left side
                Gruss aus Radevormwald
                Michel
                  See attached Screenshot. Open the project, first Click marked 1. Then set up the type of connection to the EIB, either serial mode with FT1.2 interface, USB, or IP (2). Then assign an EIB-address for the HS (3).
                  Then klick on "Netzwerk" and put in the IP-Address, Mask, Gateway, DNS for the Ethernet-Interface.
                  Close the dialog, open "Übertragen", select "über serielle Schnittstelle", choose your COM interface, klick "Starten". Dont forget to connect your PC with the HS with the special nullmodem-cable (should be in the package).
                  Have fun,
                    Hi guys
                    vimal
                      You should post some Screenshots of your settings so that we can show you whats wrong.
                      Nils
                      aktuelle Bausteine:
                        Hi Guys
                        Its me again!!
                        First of all THANK YOU for all the replies and comments.
                        I am attaching the screenshots of my homeserver and hopefully you guys will extend yet another helping hand and fix this problem i have
                        for SWENGA: When i press the transfer button no dilaouge box comes up so i am not sure what to do to select COM port and serial link.
                        cheers guys appreciate the help
                        vimal
                          Pic1 & 5:
                          this ist the Network config. Is there a networkadministrator? He should know the Gateway & CO
                          Otherwise you can try:
                          Default-gateway 192.168.0.1
                          DNS Server 192.168.0.1
                          (If the Networkadress 192.168.0.11 is the right one)
                          You can also look at your Notebook! Networkconections/Details (if you are at the same Network)
                          Pic 2 The first time you have to upload with the serial port. The button ist the right one. On the next Popup the 2. TAB (over serial). there can you choose your COM port. After press start, you have to restart your HS.(see instructions)
                            Thanks for the reply mate.....
                            i looked into my laptop and got the DNS, Subnet and default gateway.
                            PIC 1: How do you know what com port it is ? i assumed it to be 1.
                            PIC 2: Started the transfer
                            a) Switched off the HS
                            b) Connected the HS and my laptop with the serial cable RS232
                            c) Started the transfer on teh HS expert
                            d) Then switched on the HS
                            PIC3: After waiting for a while this appeared.
                            PIC4 & PIC 5 : These are the setting. i used teh default IP address for the Homeserver as i know its not been used by any other device.
                            WHAT AM I DOING WRONG???? so sorrryy to bother you guys over and over again.PLEASE HELP!
                            Thank you
                            vimal
                              Did u used the original HS Cable? Ther are differences between the "Standard Cable" and the "HS-Transfer cable!" Your PC has an real RS 232 or is it a USB to RS232 converter?
