HomeServer automated login
    HS/FS HomeServer automated login
    The doc says "the login process can be automated with the "client.exe"
    After much trial & error; I end up nowhere.
    Here is the command I'm using, and several variations of the same command
    C:\Users\Public\Documents\Gira\HS+FS Experte 4.1\tools\client\hsclient 4.1.exe/hs?&user=warichet&pw=secret&cl=GIRA1024;&ref=R3
    each time, I get a pop-up for the login, with only the server field, the other (username & password) are empty, hence no auto login.
    Also, somewhere else....
    Der Aufruf erfolgt wie folgt:
    hsclient.exe 1100550055 KEY BENUTZERNAME PASSWORT
    What is this "key" ? any example ?
    Here it comes. Id equals Key
    This gallery has 1 photos.
      E:\HS\client\hsclient.exe 0 213 user passwort
        Sorry to be a pain ... it doesn't work .... where is this 213 coming from ?
        In the Experte, I've seen the "Projekt ID" but obviously not the right one
          Hi Warichet.
          it has nothing to do with the Experte configurations.
          You are working with client.exe!!!!!!!!!!!!!!!!!!!!!!
          So all your configs need to be done in the Client-config. Forget Experte!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
          Otherwise you'll never get finished.
          Ciao
          Der DJ
          Darf man fremden Leuten eigentlich Fragen stellen, nachdem sie im Bus telefoniert haben und einem noch etwas unklar ist?
          Projects: Sonos Gateway (Musterprojekt) - KNX-MonAMI - Nutzer-Profile
            Hi DJ,
            Thank you for putting me right.
            Can you, please, tell me how to setup auto-login ?
            I understand that I've to supply a couple of parameters (username, pw etc) but don't know how to start.
            Thank you for your patience with a newbe.
            PS: I've no problem with log-in when using the web interface, hence I guess my params are OK.
            What's wrong in the line below ?
            C:\Users\Public\Documents\Gira\HS+FS Experte 4.1\tools\client\hsclient 4.1.exe/hs?&user=warichet&pw=secret&cl=GIRA102 4;&ref=R3
            Zuletzt geändert von Warichet; 31.03.2018, 13:51. Grund: add an example
              sorry, but everything you need was explained before.
              See topic #2 and #3 and everything is fine. I can tell you only the same stuff.
              And ... sorry, you should do, what people recommend ... so forget your line!!!!!!!!!!!!!!!!!!!!!THAT'S COMPLETLY WRONG!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
              That's all:
              C:\Users\Public\Documents\Gira\HS+FS Experte 4.1\tools\client\hsclient.exe 0 213 warichet secret
                Thank you
