ETS 5.6.6 released
    ETS 5.6.6 released
    Zur Info:
    Eine neue Version der ETS steht zum Download bereit.
    Hier die Release Notes:
    Released 22 October 2018, build 1190
    Download ETS v5.6.6 New features
    User Interface & Functionality
    • N/A
    ETS SDK
    • N/A
    Improvements
    • Secure devices: manage 'SeqNr' per device individually
    • ETS external library updates: Xceed WPF Toolkit to 3.7 + MvvmLightLibs to 5.4.1
    Bug fixes
    • Licensing of ETS Apps
    • ETS App Project merge: indicates the modified devices in merged projects
    • ETS App Device Compare: gives correct results (i.e. no more False negatives)
    • Auto-completion for rooms
    • Group Monitor: format for float values
    • The function 'Update from OnlineCatalog/ProductStore' no longer requires the OnlineCatalog license
    • Linking Group Addresses to Group Objects (i.e. current selection no longer lost)
    • Secure devices: Unload
    • Secure devices: Reset
    • Secure devices: commission with 'Secure commissioning' property set to 'Deactivated'
    • Secure devices: commission via Media Couplers
    • KNX IP Routers with more than 15 additional addresses
    • KNX IP Router: clear error message if it is commissioned via its proper tunneling connection and when this results in proper security related modifications
    • KNX IP Devices: automatic IP address assignment
    • Devices with removed plug-in
    • Property access for devices with active (i.e. not the default) BCU-Key
    • Bus service 'A_DeviceDescriptorRead' (AKA 'mask version read') in case of an idle open local TL connection
    • Legacy products: option 'LegacyPatchManufacturerIdInTaskSegment'
    ETS SDK
    • Secure devices: DeviceManagement
    • DCA life-cycle when changing tab content
    mfg
    Wolfgang
    Zitat von Eraser Beitrag anzeigen
    [*]The function 'Update from OnlineCatalog/ProductStore' no longer requires the OnlineCatalog license
    Na also, geht doch.
      hat die schon wer getetestet ob diese uneingeschränkt funktioniert und keine Probleme macht? Bin derzeit noch aif 5.6.2 unterwegs und würd gern updaten
        Bei mir tut bisher noch alles.
          Wenn ich im Arbeitsbereich Gebäude in einem Raum oder Verteiler ein Gerät markiere und die Entfernen Taste drücke wird der Raum gelöscht, nicht nur das Gerät.
          Kann aber nicht sagen ob das schon in der letzten Version so war.
            OPC Export ist zwar Old-School, aber für einige Visus (EibPC und Domovea) brauchte man das schon.
            Seit 5.6.5 gibt es das gar nicht mehr (ode rich find es nicht mehr).
            Dafür kann man sich die Gruppenadressen als PDF, CSV oder HTML ausgeben lassen. Da dann aber nur mit der Angabe
            schaltend, Prozent 0-100 usw, aber nicht mit dem verwendeten DTP 1001 oder 5001.
            Das find ich persönlich wenig hilfreich.
              Den OPC Export findest du mit Rechtsklick auf das Projekt -> Export. In dem folgenden Fenster kannst du dann als Datentyp OPC auswählen.
              was ich davon halte, jedesmal für den Export aus dem Projekt rausgehen zu müssen, sag ich aber lieber nicht.....
                Musst du nicht. Du kannst auch einfach im Projekt bleiben und oben links den grünen Ets Button drücken um ins Hauptmenü zu kommen.
                QC-Client, HS-Logikbausteine
                  Ich meine, das hätte ich schon mal gemacht, dann wären aber die letzten Änderungen nicht im Export gewesen.
                  Ich werde nochmal versuchen...
                    Danke für den Hinweis BadSmiley. Ich hatte jetzt noch nicht alle Möglichkeiten angeklickt. Es fiel halt nur letztens auf, dass der Menueintrag "Extras" nicht mehr
                    da war und im Gruppenadressfenster bei Export kein OPC zu finden ist.
                      ansonsten kann ich updaten ohne Angst haben?
                        No risk, no fun oder abwartend Tee trinken - deine Entscheidung
                        GLT
                          automatische suche vergebens
                          muß wohl download "drüberbügeln"
                          This gallery has 1 photos.
                            Da wird wohl der KNX-Update-Server überlastet sein.
                            Downloaden und installieren geht genauso gut.
                              Jetzt noch überlastet!!
                              da ist eher der Rechner verbogen (1/4 Jahr alt)
