Zur Info:
Eine neue Version der ETS steht zum Download bereit.
Hier die Release Notes:
Released 22 October 2018, build 1190
Download ETS v5.6.6 New features
User Interface & Functionality
- N/A
- N/A
- Secure devices: manage 'SeqNr' per device individually
- ETS external library updates: Xceed WPF Toolkit to 3.7 + MvvmLightLibs to 5.4.1
- Licensing of ETS Apps
- ETS App Project merge: indicates the modified devices in merged projects
- ETS App Device Compare: gives correct results (i.e. no more False negatives)
- Auto-completion for rooms
- Group Monitor: format for float values
- The function 'Update from OnlineCatalog/ProductStore' no longer requires the OnlineCatalog license
- Linking Group Addresses to Group Objects (i.e. current selection no longer lost)
- Secure devices: Unload
- Secure devices: Reset
- Secure devices: commission with 'Secure commissioning' property set to 'Deactivated'
- Secure devices: commission via Media Couplers
- KNX IP Routers with more than 15 additional addresses
- KNX IP Router: clear error message if it is commissioned via its proper tunneling connection and when this results in proper security related modifications
- KNX IP Devices: automatic IP address assignment
- Devices with removed plug-in
- Property access for devices with active (i.e. not the default) BCU-Key
- Bus service 'A_DeviceDescriptorRead' (AKA 'mask version read') in case of an idle open local TL connection
- Legacy products: option 'LegacyPatchManufacturerIdInTaskSegment'
- Secure devices: DeviceManagement
- DCA life-cycle when changing tab content
