KNX Taster 2- bis 8-fach mit Temp. und Luftfeuchte im 55er Maß für 40,- bis 60,-€
Kaykoon
Leider nein, vermute mal du musst bei Jung selbst schauen. Preislich attraktiv ist aber dann vermutlich anders.
Das ist in der Tat so, da liegt ein einfacher Feuchtemesser bei weit über 200€. Es muss doch irgendein Feuchtemesser eines Fremdherstellers geben, der preislich attraktiv ist bei passendem Maß.
I have somewhat similar product selection dilemma - need temp/humidity sensors for bathrooms to match LS 990 Light Gray look.
Sadly Jung does not have an affordable temperature/moisture sensor, only combined sensor with CO2 that makes it quite expensive (over 200 EUR).
Here are options I was considering:
1) For LS990 Jung has 55mm intermediate frame, that allows to mount most 55x55 devices in Jung LS990 frames - the product code is "LS 961 Z5". For me this won't work because no other manufacturer makes 55x55mm temp/humidity sensor that matches Jung LG color. But this could fit for Jung ivory or white (WW).
2) Since for my install the sensors have separate location and do not need to grouped with switches - perhaps I could use "frameless" humidity sensor like Zennio Flat Sensato. However those are mostly over 100 EUR anyway, so savings over using Jung CO2 sensors are not that great...
3) Get Jung LS990 blank cover plate, cheapest KNX temp/humidity sensor and hack them together. The biggest problem - Jung cover and frame would have to be modified to allow some air flow for the sensor to work. Jung CO2 sensor uses different cover plate that is not flat with frame and has vent on the bottom to provide air flow to sensor, but that cover, of course, cannot be bought separately.
Currently I am leaning towards just getting Jung CO2 sensors instead of tinkering with DIY solution or sacrificing aesthetics.
In my case CO2 sensors in two of the bathrooms might actually be beneficial because those contain central ventilation extract vents that are fed from ventilation supply in bedrooms. There is always an air flow from bedroom to it's linked bathroom and CO2 sensed in bathroom would closely match CO2 levels in bedroom - could be used for on-demand ventilation system control.
ich habe Ende letzten Jahre nochmal L&J-Taster nachbestellt und habe nun gesehen, dass Lingg&Janke dem Taster ein umfangreiches Redesign verpasst hat. Ich habe mal Vergleichsbilder der älteren Variane (links) mit der neueren Variante (rechts) gemacht.
Die meisten Anpassungen sind durchaus sinnvoll: Der Programmiertatser und der QR-Code für KNX-Secure sind nun auf der Vorderseite des Buskopplers und damit auch im eingebauten Zustand erreichbar. Die Tiefe des Buskopplers hat sich deutlich verringert und die Leiterplatte ist nun mit Kunststoff verdeckt. Wippen und Tastereinsatz sind bei beiden Varianten mechanisch kompatiebel.
Einziger Nachteil: Die Lödpads für SMD-LEDs sind auf dem Tastereinsatz entfallen. Ich habe diese immer selbst bestückt um eine Orientierungslicht zu realisieren.
