Please try to disable the secure IP of the router and be sure that the router functionality is enabled inyour MDT. Thanks.
KNX node for node-red
hier der flow:
[{"id":"1379b016.c3dfd","type":"ui_dropdown","z":"7 0e755c4.bfab24","name":"Select Strip Color","label":"SELECT STRIP COLOR","tooltip":"","place":"SELECT STRIP COLOR","group":"6780fab6.ac6f6c","order":4,"width" :0,"height":0,"passthru":false,"options":[{"label":"RED","value":"10,20,30","type":"str"},{" label":"GREEN","value":"40,50,60","type":"str"},{" label":"BLUE","value":"70,80,90","type":"str"},{"l abel":"WHITE","value":"80,90,100","type":"str"},{" label":"PURPLE","value":"000000","type":"str"},{"l abel":"CYAN","value":"000000","type":"str"},{"labe l":"YELLOW","value":"000000","type":"str"}],"payload":"","topic":"","x":210,"y":180,"wires ":[["ae25915b.5176e8","6c0b0a72.0746ec","9f0c9ee7.796d a"]]},{"id":"6780fab6.ac6f6c","type":"ui_group","z":"" ,"name":"WS2812B LED STRIP","tab":"b25e5e2d.8067f","order":1,"disp":tru e,"width":"6","collapse":false},{"id":"b25e5e2d.80 67f","type":"ui_tab","z":"","name":"Lab","icon":"d ashboard","order":1}]
please use this sample: https://github.com/Supergiovane/node...le---RGB-Color
But before, please upgrade knx-ultimate node to the latest 1.1.34. It will be out in about 30 minutes.
Bye.
- Likes 2
Never seen such a reactivity before: 35 min
Chris (https://proknx.com)
wir haben ARAGON entwickelt, einen offline Sprachassistenten für KNX.
Google, Amazon und Apple hätten das auch gekonnt. Aber sie verdienen eben besser an unseren persönlichen Daten...
- Likes 1
work fine, thank you!
here my code: (node-red , Siemens Bus Coupling Unit, Arduino, WS2812B LED STRIP)
[{"id":"70e755c4.bfab24","type":"tab","label":"L ED-Streifen-V3","disabled":false,"info":""},{"id":"b9880be0.2c 9a9","type":"ui_colour_picker","z":"70e755c4.bfab2 4","name":"Color Picker","label":"COLOR PICKER","group":"6780fab6.ac6f6c","format":"hex"," outformat":"string","showSwatch":true,"showPicker" :true,"showValue":true,"showHue":false,"showAlpha" :false,"showLightness":true,"square":"false","orde r":1,"width":0,"height":0,"passthru":true,"topic": "","x":130,"y":120,"wires":[["fa9c494.c7c56b8"]]},{"id":"3d8c515f.4b360e","type":"ui_button","z":" 70e755c4.bfab24","name":"Clear","group":"6780fab6. ac6f6c","order":6,"width":0,"height":0,"passthru": false,"label":"CLEAR","tooltip":"","color":"","bgc olor":"","icon":"","payload":"000000","payloadType ":"str","topic":"","x":130,"y":280,"wires":[["fa9c494.c7c56b8"]]},{"id":"1379b016.c3dfd","type":"ui_dropdown","z": "70e755c4.bfab24","name":"Select Strip Color","label":"SELECT STRIP COLOR","tooltip":"","place":"SELECT STRIP COLOR","group":"6780fab6.ac6f6c","order":4,"width" :0,"height":0,"passthru":false,"options":[{"label":"Chocolate1","value":"FF7F24","type":"str "},{"label":"DarkOliveGreen1","value":"CAFF70","ty pe":"str"},{"label":"LightSalmon","value":"FFA07A" ,"type":"str"},{"label":"DarkOrange","value":"FF8C 00","type":"str"},{"label":"OrangeRed","value":"FF 4500","type":"str"}],"payload":"","topic":"","x":110,"y":200,"wires ":[["fa9c494.c7c56b8"]]},{"id":"ae25915b.5176e8","type":"knxUltimate","z" :"70e755c4.bfab24","server":"afd77a75.8c21b","topi c":"1/2/0","outputtopic":"","dpt":"232.600","initialread": false,"notifyreadrequest":false,"notifyresponse":f alse,"notifywrite":true,"notifyreadrequestalsoresp ondtobus":false,"notifyreadrequestalsorespondtobus defaultvalueifnotinitialized":"0","listenallga":fa lse,"name":"test3","outputtype":"write","outputRBE ":false,"inputRBE":false,"formatmultiplyvalue":1," formatnegativevalue":"leave","formatdecimalsvalue" :999,"x":730,"y":180,"wires":[[]]},{"id":"72700998.d01668","type":"function","z":"7 0e755c4.bfab24","name":"KNX","func":"rgb = msg.payload;\nrot = rgb[0];\ngruen = rgb[1];\nblau = rgb[2];\nmsg.payload={red:rot, green:gruen, blue:blau};\nreturn msg;","outputs":1,"noerr":0,"x":550,"y":180,"wires ":[["ae25915b.5176e8","7cba5ee0.fbb0b"]]},{"id":"7cba5ee0.fbb0b","type":"debug","z":"70e75 5c4.bfab24","name":"","active":true,"tosidebar":tr ue,"console":false,"tostatus":false,"complete":"fa lse","x":730,"y":20,"wires":[]},{"id":"fa9c494.c7c56b8","type":"color-convert","z":"70e755c4.bfab24","input":"hex","outp ut":"rgb","outputType":"array","scaleInput":false, "x":390,"y":180,"wires":[["72700998.d01668"]]},{"id":"da0cf78b.94fe6","type":"comment","z":"70e 755c4.bfab24","name":"http://www.farb-tabelle.de/de/rgb2hex.htm?q=%23FF4500","info":"","x":230,"y":400 ,"wires":[]},{"id":"6780fab6.ac6f6c","type":"ui_group","z":"" ,"name":"WS2812B LED STRIP","tab":"1a6e180f.7b37b","order":1,"disp":tru e,"width":"6","collapse":false},{"id":"afd77a75.8c 21b","type":"knxUltimate-config","z":"","host":"192.168.178.102","port":"36 71","physAddr":"15.15.22","suppressACKRequest":fal se,"csv":"","KNXEthInterface":"Auto","KNXEthInterf aceManuallyInput":"","statusDisplayLastUpdate":tru e,"statusDisplayDeviceNameWhenALL":true,"statusDis playDataPoint":false,"stopETSImportIfNoDatapoint": "stop","loglevel":"error"},{"id":"1a6e180f.7b37b", "type":"ui_tab","z":"","name":"Home","icon":"dashb oard","disabled":false,"hidden":false}]
- Likes 1
TheMax74
great piece of software. Is it also possible for you to integrate an esf file import of the knx addresses? I am using the ets inside and in combination with the ets demo I can only create esf files like used for the import in edomi.
Other way could be a ets inside backup file import.
thank you,
best regards
johannes
you can create the esf file in the ETS on the project list. Right mouse click on the project -> export -> chose esf as file format. The other format is knxproj, the actual export format. But if you don‘t have the possibility to create an esf file I will build you a demo project file in esf format.
greetings
Hi Johannes
V. 1.1.36 is out. Please refresh your palette and install the update.
Then, please, let me know.
You need to check and adjust some of the ESF datapoints, because they're absolutely no accurate as they in the CSV export file.Zuletzt geändert von TheMax74; 24.02.2020, 16:30.
