Thank you, I will give it a try in the next days.
KNX node for node-red
I have created the GA CSV-Export exactely as shown in the Video and pasted it for import in the node-configuration.
As not all GA‘s have a DP (yet), I selected to ignore these GA‘s and proceed, so I got quite a lot of warnings during deploy.
But unfortunately the auto-complete does not work, so it looks as if the import did not work. Any hint, how I could find the Problem?
BTW: KNX Ultimate is working great, very good work!
Hi Martiko
I strongly suggest you to fix the datapoints, then export again the CSV. Datapoints are VITAL for all visualization and management system.
I'ts a matter of minutes to set the right datapoints.
Otherwise you need to change each KNX-Ultimate node, by setting the right datapoint. Every time you add a new KNX Node. This is very frustrating.
"Ignore and continue" was requested by an user. I added it, but i've made a great mistake, beause then you have a totally unstable installation, with random values outputted by nodes and wrong numeric visualization if you use a visu, like for example Smartvisu.
I plan to remove the "Ignore and continue" :-)Zuletzt geändert von TheMax74; 02.03.2020, 17:20.
I am still in the stage of testing with my KNX-Board, but I have already created most of the GA‘s I plan to use in my final implementation.
but as this is still work im progress and I don‘t even know or own the Final devices, it‘s not yet the right time to define all DPs (as I plan to use Copy&Paste for the GA-Structure).
But I don‘t understand why the Import should not work for all GA‘s which are already defined with a DP (so for all, which I have already in use for testing). So to my mind, it would be a step back, if you remove this feature.
but ok, for the Moment, it is working without the import and manual DP definition....
PS: You surely don‘t need to set the DP‘s for me... but thanks for the offer ;-)
PPS: Mi dispiacce, che non parle bene italiano, ma mille grazie per l‘eccelente lavoro!Zuletzt geändert von martiko; 02.03.2020, 17:27.
Hello Martiko
ok this make sense, for testing. I already found why you don't see the device name in the list. Can you send me, please, your CSV file? You can send it per PM or via mail info@supergiovane.it
I'll make immediately a new version, to allow you to import and test your system.
- Likes 1
Hi,Zitat von TheMax74 Beitrag anzeigenHello Martiko
i've just sent you the file via e-mail...
Thanks in advance!
Your node is really awsome! For testing I currently use the universal mode which is - in conjunction with the imported GA-File - a great way to implement a Bus-Monitor. I currently dump the output to a file so that I have an overview what data is retrieved and can be used for entry in an InfluxDB.Zitat von TheMax74 Beitrag anzeigenHi Martiko,
V. 1.1.38 is out with changed behaviour in importing CSV file. A fake Datapoint 1.001 will now be set for GA with unset datapoint.
You should see the new version in minutes.
Probably I will even use this mode to "catch all" Traffic and automate the Filtering and Storing in InfluxDB. I think this is easier than building single Flows for each data I want to archive. So the testing shows that I need to rework my naming conventions for the GAs (and even the names of the middle groups) including Separators, so that I can easyly split these and use them for tagging.
Un altra volta, mille grazie!!!
- Likes 1
Good Morning TheMax,
im trying out your program.
I installed it on my RasPi (has knxd installed an works --> i can make changes on the KNX over SSH for example).
NodeRed is running on the Pi, i can access in Browser from my PC
Could you help me make the right settings to get connection between your software and KNX
Thank you
