Gira X1 und Modbus TCP mit Logikbaustein
    Zitat von Esteban Beitrag anzeigen
    I have tried with radzio modbus master and the result is the same.
    your screenshot states an error while connecting to the IP adress of the X1. what means, the program tries to connect to a modbus server on the X1. but there is no one.
    if you have the same problem (same error), that you did the same: you tried to connect to an non existing modbus server.
    Have you used a basic sofware tool to simulate the comunication. Can you tell me with one?
    i have never used a simulator but only real devices.
    i suggest to open another thread, where you explain your detailed setup and what you want to try to reach. your problem seems not really related to this modbus node, that is being discussed here.
    Alram
      Dear Alram,
      I have know communication. Hexadecimal at Raw output and decimal at register output.
      But how do you manage this data? At homeserver there are more advanced modules to do it. But at X1 how do you do it?
      Thank you in advanced.
      Esteban
        Hi Esteban,
        don't understand your problem. the "RAW / Error" output is just for debugging purposes. not indeded for use as part of any logic.
        But the output ("Register Wert") should provide simply the value from the modbus register. What to do with that is up to you or what you want to reach.
        Alram
          Dear Alram,
          I have the modul working fine.
          But I have to read negative values.
          The module has any way to process negative values?
          Thank you
            Hi Esteban,
            just checked: INT datatype uses BitConverter.ToInt32 (https://github.com/rossmann-engineer...Client.cs#L281) regarding to MSDN doc (https://docs.microsoft.com/en-us/dot..._System_Int32_) this is already treated as signed value. so negative value should already work (with the latest version).
            BR
            Alram
              Estimado Alram,
              estoy usando la última versión (V0.0.3). Creo.
              Te adjunto la imagen con los datos reales (software qmodmaster) y los datos del módulo.
              Los datos positivos funcionan perfectamente.
              Esteban​​
              This gallery has 1 photos.
                Hi Esteban,
                sry - but i don't speak/understand spanish. latest version is 0.0.12 (https://knx-user-forum.de/forum/%C3%...32#post1657832).
                Alram
                  Hi Alram,
                  I'm sorry , my last chat was translated automatically to spannish languaje.
                  I attach you the screen shot of a free software reading the modbus negative data and the X1 module with the 0.0.12 version.
                  The data is 16bits and it doesn't understand negative values.
                  Thank you.
                    try this version and the new data type "16 bit signed". pls provide feedback - thanks!
                    HTH Alram
                      Dear Alram,
                      Thanks a lot for your answer.
                      I have checked the 0.0.13 version but I have not found the 16 bits integer signed option.
                      With 16 bits integer doesn't works with negative values.
                      Thanks
                        strange - i have the new datatype. can you try to create new project in GPA and insert new query modbus node there?
                          Alram,
                          You were right. I have solved restarting the GPA software. Creating a new project the problem was the same.
                          Now it works perfectly!!!
                          Thanks a lot
                            der Post ist ja schon was älter.
                            Wo finde ich denn dieses Modbus Logik Modul in der Gira GPA.
                            Bei mir ist das garnicht vorhanden.
                            Schöne Grüße,
                            Thomas
                              Lesen hilft, oder mag hier jeder eine persönliche Antwort?
                                habe mir den Gesamten Verlauf mehrmals durchgelesen, aber leider keine Lösung für mein Problem herauslesen können.
                                Ich finde in der GPA / Logikmodul keine Modbus Grundfunktion. Damit hat der Ersteller des Beitrages ja angefangen.
