[HowTo] Eibd unter Windows
    Hmm. das paket läuft hier stabil auf einem win2003 server.
    Welches OS setzt du ein? wenn Win7 hast du mal starten als administrator probiert?
    Ich meine aber das ich den eibd auch schon mal unter win7 64bit testhalber am laufen hatte.
      Hallo
      Ich habe es auf Win7 64bit und auf Win8 64bit versucht.
      Ich habe auch das starten als Administrator ausprobiert leider ohne erfolg.
      Gruss Tom
        Wenn ich den Dienst ohne -S starte startet er ohne Probleme.
          Hi.
          I am also trying to configure eibd under windows but I'm still a bit confused
          I am trying to connect a Gira Homeserver to my KNX bus using a Weinzierl BAOS 770 IP interface (no routing).
          I still haven't managed to access the KNX bus using the HS.
          Can someone help me?
          I have to play with 3 IP addresses:
          192.168.0.22 - Gira HS3
          192.168.0.20 - Weinzierl BAOS 770
          192.168.0.12 - Windows Machine
          I start eibd with:
          eibd -S -T -D -i ipt:192.168.0.20
          It apparently runs with no error.
          Now...I've configured the Gira HS using the expert software to set the bus access to EIBNet IP/Routing but I don't know exactly what IP should I use.
          I tried leaving the multicast address (224.0.23.12:3671) but still can't access the bus.
          I've thought of using the eibd's IP address but don't know which port to use :P
          I don't know what to do next
          What am I doing wrong?
          How can I check if eibd is working?
          Thanks.
            Still trying with no success.
            When I run eibnetsearch (included in eibd) without running eibd I get the following result:
            Asking 224.0.23.12 at port 3671 from port 3672
            Answer from 192.168.0.20 at port 3671
            Medium: 2
            State: 0
            Addr: 1.1.17
            InstallID: 0
            Serial: 00 C5 07 04 00 74
            Multicast-Addr: 0.0.0.0
            MAC: 00 50 C2 55 4E 21
            Name: KNX IP BAOS 770
            Service 2 Version 1
            Service 3 Version 1
            Service 4 Version 1
            When I run it after running eibd (eibd -S -T -D -i ipt:192.168.0.20) I get this:
            IP initialisation failed
            What is wrong?
              No one?
