I think I have been missing to connect the developer tokens to my account. The page for that seems to be different now - it is https://www.miele.com/developer/openapi/index.html (click on a green "authorize" button at the bottom right). After that, the page displays lots of developer endpoints and the module works without exception. Thanks, Roeller
Getting a security token seems not to work always.
Had to shutdown my HS for half a hour and since then the building block is not working anymore.
Fails to get a new token.
Also after i do some tests from the miele api website.
It seems they also will fase out the way of authenticating is done now somewhere in 2026....
