I think I have been missing to connect the developer tokens to my account. The page for that seems to be different now - it is https://www.miele.com/developer/openapi/index.html (click on a green "authorize" button at the bottom right). After that, the page displays lots of developer endpoints and the module works without exception. Thanks, Roeller
Getting a security token seems not to work always.
Had to shutdown my HS for half a hour and since then the building block is not working anymore.
Fails to get a new token.
Also after i do some tests from the miele api website.
It seems they also will fase out the way of authenticating is done now somewhere in 2026....
I am getting error 500. The app works. The error text from the block is as follows
HTTP Code: 500 received when doing a GET request. Response: <html>#015#012<head><title>500 Internal Server Error</title></head>#015#012<body>#015#012<center><h1>500 Internal Server Error</h1></center>#015#012<hr><center>nginx</center>#015#012</body>#015#012</html>
I would guess the reason is that Miele switched to oauth2 and their legacy oauth server (used by the LBS) does not work right now. Would it be difficult to switch the module to oauth2 ?
I can rebuild it to the new oauth (I recently looked at it when creating the new beta for the X1 Miele logic node, see the other topic), but at that time the new oauth didn’t work on the Miele developer website (swagger). There was a bug in the resources, you should post that and the Miele developer website does a post with the wrong values (with a semicolon between read and the value). Probably it is that new that it doesn’t even work at their own site yet..
if it works there, then I will also upgrade this logic node.
zu Weihnachten gab es eine neue Waschmaschine von Miele.
Dazu habe ich mir mal den Baustein auf den Homeserver gespielt.
Alle Einstellungen und Vorkehrungen laut Roeller habe ich vorgenommen.
Leider kommt eine Fehlermeldung:
10.01.2026 12:27:54 (1)
File "hs_logik.py", line 231, in calc
File "formula", line 1, in [module]
File "[14360_Miele_0]", line 52, in __init__
File "[14360_Miele_0]", line 70, in check
File "[14360_Miele_0]", line 107, in get_code
NameError: global name 'auth_url' is not defined
[5012L, 14360L, 0L, '(EI or EC[1] or EC[2] or EC[3] or EC[4] or EC[5] or EC[6] or EC[7])', 'Miele(locals())', '', 0L, 0L, 1L, 0L]
Auch ist die Bedienung nicht möglich.
Kann jemand weiterhelfen?
Ich meine, ich hatte den Fehler auch. Soweit ich mich eriinere passiert der Crash in einem Teil des Programmcodes, der normalerweise nicht erreicht werden sollte und deswegen nicht so gut getestet ist. Aktuell funktioniert der Baustein nicht (s.o.) deswegen würde ich abwarten.
That’s really strange, I will take a look at it and the auth_url is a constant, if you filled in all the needed parameters it should be right.
Its functioning here, everyday, cause I shout out ‘he google, turn on coffee machine’ which works via babtech appmodule (google assistant) which is binded to KNX to the HomeServer module.
Still all working on the ‘old authentication’ method.
Also here, still not working anymore. Tried older version, new Miele api registration, always same error when retrieving a new token.
Something else that i can test? Or information i can provide to troubleshoot.
Maybe this could be the cause.
The primary url was linked to miele.com/f/com/en/register_api.aspx
But this link seems to be broken now.
When you register an api token at the new Miele API Link at Get Involved you can`t link the api token to your account anymore. Or did I miss something?
Maybe it isn´t necessary any more?
And what language setting must be used in the LBS if I live in Austria? at-AT?
