Das ist schön --- die 5.2 lief bei mir leider nicht durch
./configure --help [...] Optional Features: [...] --enable-onlyeibd build only eibd (requires no libxml and m68hc05-gnu) [...]
checking for LOG4CPP... no no checking for LUA... no no checking for LUA... no no
root@debian:/usr/local/src/linknx# lua Lua 5.1.4 Copyright (C) 1994-2008 Lua.org, PUC-Rio
*** Failed to install the package Do you want to see the log file? [y]: y Selecting previously deselected package linknx. (Reading database ... 15724 files and directories currently installed.) Unpacking linknx (from .../linknx_0.0.1.29-1_armel.deb) ... dpkg: dependency problems prevent configuration of linknx: [B] linknx depends on eibd-server; however: Package eibd-server is not installed.[/B]
dpkg -i --force-depends linknx_0.0.1.29-1_armel.deb
