Bei einer csv spart man sich das umbenennen wenn sie aus dem Tabellenprogramm purzelt. Ergo: csv.
media ~/src/csv $ telnet backup 8888 Trying 192.168.1.16... Connected to backup.lan. Escape character is '^]'. [B]get ci yield_dec_last[/B] [B][COLOR=Red]4569.000[/COLOR][/B] [B][COLOR=Black]get ci yield_nov_last[/COLOR][/B] [B][COLOR=Red]3419.000[/COLOR][/B] shutdown Connection closed by foreign host.
backup src # valgrind --leak-check=full --show-reachable=yes ./ebusd ==6351== Memcheck, a memory error detector ==6351== Copyright (C) 2002-2011, and GNU GPL'd, by Julian Seward et al. ==6351== Using Valgrind-3.7.0 and LibVEX; rerun with -h for copyright info ==6351== Command: ./ebusd ==6351== configuration file /etc/ebusd/ebusd.conf not found. local configuration file ebusd.conf used. address = FF cfgdir = /usr/src cfgfile = /etc/ebusd/ebusd.conf device = /dev/ttyUSB0 extension = .csv foreground = YES loglevel = ALL logfile = /var/log/ebusd.log pidfile = /var/run/ebusd.pid port = 8888 rawdump = NO rawfile = /tmp/ebusd.bin showraw = NO settings = YES max_retry = 3 skip_ack = 1 max_wait = 4000 2013-02-04 22:43:49.994 [0x02 NOT] /usr/src/vaillant_get.csv 2013-02-04 22:43:50.185 [0x02 NOT] /usr/src/vaillant_get.csv success 2013-02-04 22:43:50.214 [0x01 INF] /dev/ttyUSB0 opened. 2013-02-04 22:43:50.222 [0x01 INF] port 8888 opened. 2013-02-04 22:43:50.224 [0x01 INF] msg queue initialized. 2013-02-04 22:43:51.054 [0x20 EBH] 10 fe b5 05 04 27 00 1f 00 4f 2013-02-04 22:43:51.314 [0x20 EBH] 10 fe b5 05 03 4a 01 00 f4 2013-02-04 22:43:51.565 [0x20 EBH] 10 08 b5 09 03 29 b9 01 66 00 03 b9 01 00 66 00 2013-02-04 22:43:51.737 [0x20 EBH] 10 08 b5 09 03 29 0f 00 56 00 05 0f 00 76 00 00 5d 00 2013-02-04 22:43:51.901 [0x20 EBH] 10 08 b5 09 03 29 bb 00 ca 00 03 bb 00 64 b5 00 2013-02-04 22:43:52.064 [0x20 EBH] 10 08 b5 09 03 29 ba 00 51 00 03 ba 00 0a cd 00 2013-02-04 22:43:52.113 [0x80 NET] client [6] from 192.168.1.11 connected. 2013-02-04 22:43:52.227 [0x20 EBH] 10 08 b5 09 03 29 e2 01 b3 00 03 e2 01 65 a8 00 2013-02-04 22:43:53.142 [0x20 EBH] 10 53 b5 05 07 2b 00 01 00 00 00 00 5a 00 00 00 00 2013-02-04 22:43:53.419 [0x20 EBH] 10 08 b5 11 02 03 00 1e 00 0a fc 01 74 09 44 06 03 2c 00 00 9c 00 2013-02-04 22:43:53.581 [0x20 EBH] 10 08 b5 11 01 02 8a 00 05 00 00 c8 00 c8 ca 00 2013-02-04 22:43:53.748 [0x20 EBH] 10 ed b5 08 07 07 01 01 e0 03 d0 01 d1 00 00 00 00 2013-02-04 22:43:55.173 [0x20 EBH] 10 08 b5 13 03 04 cd 01 7f 00 0a cd 01 00 00 00 00 01 00 01 00 fa 00 2013-02-04 22:43:55.620 [0x20 EBH] 03 0a b5 03 02 00 01 dc 00 0a ff ff ff ff ff ff ff ff ff ff 0f 00 2013-02-04 22:43:56.192 [0x80 NET] >>> client [6] [B]get ci yield_dec_last[/B] 2013-02-04 22:43:56.197 [0x02 NOT] search: get ci.yield_dec_last 2013-02-04 22:43:56.202 [0x02 NOT] found: 15B509030D8558 type: 3 ==> id: 42 2013-02-04 22:43:56.204 [0x10 DBG] add: id: 42 clientfd: 6 ==> entries: 1 2013-02-04 22:43:56.206 [0x10 DBG] del: id: 42 clientfd: 6 ==> entries: 0 2013-02-04 22:43:56.214 [0x20 EBH] 15 b5 09 03 0d 85 58 2013-02-04 22:43:56.331 [0x20 EBH] 02 d9 11 2013-02-04 22:43:56.381 [0x80 NET] <<< client [6] [COLOR=Red][B]4569.000[/B][/COLOR] 2013-02-04 22:43:57.161 [0x20 EBH] 10 08 b5 10 09 00 02 3a 00 00 00 00 00 02 d1 00 00 00 00 2013-02-04 22:43:57.404 [0x20 EBH] 10 08 b5 09 04 0e d1 00 00 29 00 00 00 00 2013-02-04 22:43:59.161 [0x20 EBH] 10 08 b5 09 03 29 01 00 23 00 05 01 00 f7 01 00 52 00 2013-02-04 22:43:59.342 [0x20 EBH] 10 25 b5 04 01 01 d2 00 09 30 03 00 00 00 03 00 01 00 f2 00 2013-02-04 22:43:59.510 [0x20 EBH] 10 25 b5 04 02 0d 00 be 00 05 50 00 8e 03 30 d1 00 2013-02-04 22:43:59.587 [0x80 NET] >>> client [6] [B]get ci yield_nov_last[/B] 2013-02-04 22:43:59.588 [0x02 NOT] search: get ci.yield_nov_last 2013-02-04 22:43:59.589 [0x02 NOT] found: 15B509030D8550 type: 3 ==> id: 40 2013-02-04 22:43:59.589 [0x10 DBG] add: id: 40 clientfd: 6 ==> entries: 1 2013-02-04 22:43:59.598 [0x10 DBG] del: id: 40 clientfd: 6 ==> entries: 0 2013-02-04 22:43:59.598 [0x20 EBH] 15 b5 09 03 0d 85 50 2013-02-04 22:43:59.770 [0x20 EBH] 02 5b 0d 2013-02-04 22:43:59.770 [0x80 NET] <<< client [6] [B][COLOR=Red]3419.000[/COLOR][/B] 2013-02-04 22:43:59.876 [0x20 EBH] 10 25 b5 04 01 31 e2 00 02 00 00 2c 00 2013-02-04 22:44:01.193 [0x20 EBH] 10 08 b5 09 03 29 07 00 4f 00 05 07 00 f0 01 00 24 00 2013-02-04 22:44:01.357 [0x20 EBH] 10 08 b5 09 03 29 b8 01 fd 00 03 b8 01 00 70 00 2013-02-04 22:44:03.122 [0x20 EBH] 10 fe b5 05 04 27 00 1f 00 4f 2013-02-04 22:44:03.419 [0x80 NET] >>> client [6] shutdown ==6351== ==6351== HEAP SUMMARY: ==6351== in use at exit: 0 bytes in 0 blocks ==6351== total heap usage: 306 allocs, 306 frees, 9,898,979 bytes allocated ==6351== ==6351== All heap blocks were freed -- no leaks are possible ==6351== ==6351== For counts of detected and suppressed errors, rerun with: -v ==6351== ERROR SUMMARY: 0 errors from 0 contexts (suppressed: 2 from 2)
. Das mit den 1ern kommt mir merkwürdig vor, kenne aber auch den Arduino eBUS converter nicht. Beim fertigen eBus Converter mußten wir hier alle erst mal am Poti feinjustieren, bis die Flut von AAs und halbwegs brauchbare Pakete aufgetaucht sind. Hier hat sich der simple Einsatz von HTERM bewährt oder der Daemon im Dumpmode von Roland.2013-02-06 23:46:55.380 [0x80 NET] >>> client [6] get mv undercool_temp 2013-02-06 23:46:55.380 [0x02 NOT] search: get mv.undercool_temp 2013-02-06 23:46:55.380 [0x02 NOT] found: 08B509030D8E00 type: 3 ==> id: 93 2013-02-06 23:46:55.566 [0x02 NOT] send retry: 1 2013-02-06 23:46:55.720 [0x80 NET] <<< client [6] 0.0000
