- √ - Firmware upgrade from 2.5 to 2.7
    Zitat von NilsS Beitrag anzeigen
    Hmm seems you lost your Remanent Data
    I did a backup.
    I think the UZSU is remembered in the Remanent Data. I checked it, looks fine
    The Error looks like the Project wont fit somehow in the HS Memory
    Indeed, but given the Debug/Memory stats, I wonder if it is the real cause.
    Anyway, a well written application should check if the pre-requisites are met before running.
    Do you use Quad?
    No
    Make a Backup of your Projekt and remove some stuff
    OK, thanks, I'll try.
      I sign that
      Nils
      aktuelle Bausteine:
        Maybe I could use the new standalone application "HS Transfer" but it expects a .hst file.
        How could I prepare such a file ?
          New firmware and you try to upload your project? I think the password is not correct.
            That's very possible, I haven't done a firmware upgrade since years.
            I have an understanding problem about passwords.
            I know there is a password in the project, but it is compared to what ?
            In other words, how can I recover the situation ?
            NB: Uploading the project via RS232 works fine.
              Just look for your password under "Benutzer" it is there in plaintext and reenter it in the Transfer Dialog. Transfer over RS232 dont use the password.
              Nils
              aktuelle Bausteine:
                You are correct by thinking it is not correct
                It works, so I goofed in the password (the error message doesn't help much)
                Many thanks for your kind help.
