den fsck kann man auch beim Reboot machen
shutdown -Fr now
der dauert aber dann viel länger wie gewöhnlich.
shutdown -Fr now
drive status error uncorrectable error
Reading package lists... Building dependency tree... Reading state information... The following packages were automatically installed and are no longer required: libsensors4 lm-sensors Use 'apt-get autoremove' to remove them. The following NEW packages will be installed: smartmontools 0 upgraded, 1 newly installed, 0 to remove and 34 not upgraded. Need to get 326kB of archives. After this operation, 815kB of additional disk space will be used. Get:1 http://archive.debian.org lenny/main smartmontools 5.38-2+lenny1 [326kB] debconf: delaying package configuration, since apt-utils is not installed Fetched 326kB in 1s (217kB/s) Selecting previously deselected package smartmontools. (Reading database ... 54232 files and directories currently installed.) Unpacking smartmontools (from .../smartmontools_5.38-2+lenny1_i386.deb) ... Processing triggers for man-db ... Setting up smartmontools (5.38-2+lenny1) ... Not starting S.M.A.R.T. daemon smartd, disabled via /etc/default/smartmontools (warning).
root@wiregate451:~# sudo update-smart-drivedb -bash: sudo: command not found root@wiregate451:~# sudo smartctl -i -bash: sudo: command not found root@wiregate451:~# sudo smartctl -s -bash: sudo: command not found
