Versteht man,
aber wie löst ihr dann die ansteuerung des tv, bzw. bei anderen modellen?
IR Transmitter?
IR Transmitter?
[COLOR=#000000][FONT=Times New Roman]Wireless Remote Control menu echo "Content-type: text/html\n\n"; flush(); $sock = socket_create(AF_INET, SOCK_STREAM, getprotobyname('tcp')); $result = socket_connect($sock, $tvip, '55000'); if( $result === false) die ("Could not create socket: \n"); //Normal remote keys //KEY_0 //KEY_1 //KEY_2 //KEY_3 //KEY_4 //KEY_5 //KEY_6 //KEY_7 //KEY_8 //KEY_9 //KEY_UP //KEY_DOWN //KEY_LEFT //KEY_RIGHT //KEY_MENU //KEY_PRECH //KEY_GUIDE //KEY_INFO //KEY_RETURN //KEY_CH_LIST //KEY_EXIT //KEY_ENTER //KEY_SOURCE //KEY_AD //KEY_PLAY //KEY_PAUSE //KEY_MUTE //KEY_PICTURE_SIZE //KEY_VOLUP //KEY_VOLDOWN //KEY_TOOLS //KEY_POWEROFF //KEY_CHUP //KEY_CHDOWN //KEY_CONTENTS //KEY_W_LINK //Media P //KEY_RSS //Internet //KEY_MTS //Dual //KEY_CAPTION //Subt //KEY_REWIND //KEY_FF //KEY_REC //KEY_STOP //Bonus buttons not on the normal remote: //KEY_TV //Don't work/wrong codes: //KEY_CONTENT //KEY_INTERNET //KEY_PC //KEY_HDMI1 //KEY_OFF //KEY_POWER //KEY_STANDBY //KEY_DUAL //KEY_SUBT //KEY_CHANUP //KEY_CHAN_UP //KEY_PROGUP //KEY_PROG_UP if(!isset($_REQUEST["key"])){ $_REQUEST["key"] = 'KEY_CHAN_UP'; } $ipencoded = base64_encode($myip); $macencoded = base64_encode($mymac); $messagepart1 = chr(0x64) . chr(0x00) . chr(strlen($ipencoded)) . chr(0x00) . $ipencoded . chr(strlen($macencoded)) . chr(0x00) . $macencoded . chr(strlen(base64_encode($remotename))) . chr(0x00) . base64_encode($remotename); $part1 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart1)) . chr(0x00) . $messagepart1; socket_write($sock, $part1, strlen($part1)); echo $part1; echo "\n"; $messagepart2 = chr(0xc8) . chr(0x00); $part2 = chr(0x00) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart2)) . chr(0x00) . $messagepart2; socket_write($sock, $part2, strlen($part2)); echo $part2; echo "\n"; //Preceding sections all first time only if (isset($_REQUEST["key"])) { //Send remote key $key = "KEY_" . $_REQUEST["key"]; $messagepart3 = chr(0x00) . chr(0x00) . chr(0x00) . chr(strlen(base64_encode($key))) . chr(0x00) . base64_encode($key); $part3 = chr(0x00) . chr(strlen($tvappstring)) . chr(0x00) . $tvappstring . chr(strlen($messagepart3)) . chr(0x00) . $messagepart3; socket_write($sock,$part3,strlen($part3)); //echo $part3; echo "\n"; } else if (isset($_REQUEST["text"])) { //Send text, e.g. in YouTube app's search, N.B. NOT BBC iPlayer app. $text = $_REQUEST["text"]; $messagepart3 = chr(0x01) . chr(0x00) . chr(strlen(base64_encode($text))) . chr(0x00) . base64_encode($text); $part3 = chr(0x01) . chr(strlen($appstring)) . chr(0x00) . $appstring . chr(strlen($messagepart3)) . chr(0x00) . $messagepart3; socket_write($sock,$part3,strlen($part3)); //echo $part3; echo "\n"; } socket_close($sock); echo "\n\n"; ?>[/FONT][/COLOR]
