- √ - How to: Urlaubskalender
    I'd like to start using the "Urlaubskalender", I've never done it before.
    I've created several entries in the menu Urlaubskalender, but there it stops
    The doc says
    In dieser Maske werden die Urlaubskalender verwaltet.
    Die Kalender werden im Menü angezeigt.
    but I've no idea as how to proceed, for the next step
    I guess I must enter the dates somewhere ?
    My purpose is to have the heating system react upon a holiday and switch to the "sunday" regime.
    Thank you for any hint.
    You must now create an entry on your visu with command:
    "Urlaubskalender öffnen"
    Now you can add entries to this Urlaubskalender. Data will be used in UZSU.
      Hi Matthias,
      Thank you for the quick reply
      OK, thank you, I didn't see this in the doc.
      If it isn't asking too much, would you be so kind to provide me with a PrintScreen of the relevant menus, please ?
      Also, among the available commands I see
      "Feirtagskalender öffnen"
      I guess those commands have the same result ?
      Thank you for your patience
        There are no menues, it is just the mask.
        Urlaubskalender and Feiertagskalender is different.
        Urlaub can be "23.12.09-07.01.10" - one entry only.
        Feiertagskalender is based on month.
        So you normally have 12 Feiertagskalender, for example one for January where you can add single days (more than one) like 6 (in Germany/Bavaria)
          Pfiou ! I think I got it.
          Thanks a lot (the doc could have been a little bit more explicit )
            to be honest, I have searched for that "?=")($/%" Feiertags functionality for a long time now but never realized it in that menu.
            Is there any flag that might be checked for "Urlaub" or "Feiertag"? Probably any flag that will be set internally to 1 or whatever?
            Any idea is really appreciated.
            Happy New Year!
            Ciao
            Der DJ
            Darf man fremden Leuten eigentlich Fragen stellen, nachdem sie im Bus telefoniert haben und einem noch etwas unklar ist?
            Projects: Sonos Gateway (Musterprojekt) - KNX-MonAMI - Nutzer-Profile
              I've the excuse for not knowing the language very well, so I'm allowed to ask very dumb questions (That excuse is not valid for you )
              I don't think so.
              I've followed Matthias's recommendation.
              So, I started with the Menu "Urlaubskalender" and entered some dates there.
              Then I created a new page in the Visu, with 2 columns, one for Feiertagskalender and one for Urlaubskalender.
              Save & download.
              From the HS Client, navigate to the new page, click each line, and enter the relevant date.
              Save & download.
              I guess all this data will be compound in UZSU, there you can select whichever type you want.
                How to really use several Urlaubskalender?
                This is also one of my many questions related to the Urlaub- und Feiertagskalender: How can I access internal variables related to these timing functions?
                Furthermore I am asking myself whether I can use various Urlaubskalender for different usages such as, e.g., the control of room heating for rooms that are only occupied in specific periods of time. I wanted to use different Urlaubskalender but they seem to be ORed all together. Is there a way to know out of which Urlaubskalender the event is coming? Are there any other ideas for this very problem or do I have to wait until GIRA might (or might not) add that functionality one day?
                Thanks for your support and...
                A Happy New Year to all of you,
                Felix
                  No way.
                  Best solution: logic module for these days:
                  Homeserver
                    Ist es möglich den Urlaubskalender mit dem QuadClient zu öffnen?
