Installation Callidomus auf APU
    Kabel ist da, Verbindung steht - boot-device scheint er zu finden, aber keinen boot loader und/oder Kernel? Ich bräuchte Hilfe, wie ich das zu interpretieren habe:
    SeaBIOS (version ?-20160307_153453-michael-desktop64)
    XHCI init on dev 00:10.0: regs @ 0xfeb22000, 4 ports, 32 slots, 32 byte contexts
    XHCI    extcap 0x1 @ feb22500
    XHCI    protocol USB  3.00, 2 ports (offset 1), def 0
    XHCI    protocol USB  2.00, 2 ports (offset 3), def 10
    XHCI    extcap 0xa @ feb22540
    Found 2 serial ports
    ATA controller 1 at 4010/4020/0 (irq 0 dev 88)
    EHCI init on dev 00:13.0 (regs=0xfeb25420)
    ATA controller 2 at 4018/4024/0 (irq 0 dev 88)
    Searching bootorder for: /pci@i0cf8/*@14,7
    Searching bootorder for: /rom@img/memtest
    Searching bootorder for: /rom@img/setup
    ata0-0: TS32GMSA370 ATA-9 Hard-Disk (30533 MiBytes)
    Searching bootorder for: /pci@i0cf8/*@11/drive@0/disk@0
    XHCI no devices found
    Initialized USB HUB (0 ports used)
    All threads complete.
    Scan for option roms
    PCengines Press F10 key now for boot menu:
    Searching bootorder for: HALT
    drive 0x000f2e90: PCHS=16383/16/63 translation=lba LCHS=1024/255/63 s=62533296
    Space available for UMB: c1000-ef000, f0000-f2e90
    Returned 262144 bytes of ZoneHigh
    e820 map has 7 items:
      0: 0000000000000000 - 000000000009f800 = 1 RAM
      1: 000000000009f800 - 00000000000a0000 = 2 RESERVED
      2: 00000000000f0000 - 0000000000100000 = 2 RESERVED
      3: 0000000000100000 - 00000000dffae000 = 1 RAM
      4: 00000000dffae000 - 00000000e0000000 = 2 RESERVED
      5: 00000000f8000000 - 00000000fc000000 = 2 RESERVED
      6: 0000000100000000 - 000000011f000000 = 1 RAM
    enter handle_19:
      NULL
    Booting from Hard Disk...
    Booting from 0000:7c00
    gptboot: No /boot/loader on 0:ad(0p2)
    gptboot: No /boot/kernel/kernel on 0:ad(0p2)
    FreeBSD/x86 boot
    Default: 0:ad(0p2)/boot/kernel/kernel
    boot:
    Edith: Bin einen Schritt weiter gekommen, da mein Problem ja dem in https://knx-user-forum.de/forum/supp...2c4-nicht-mehr entspricht. Eingabe von
     0:ad(0p3)/boot/loader
    hat auch mein APU veranlasst zu booten. An dieser Stelle die Frage an Marcus: Was macht der Befehl und warum ist/war er nötig?
    Allerdings geht's dann nicht viel weiter, sondern das System kann die shell nicht finden (habe einmal "RETURN" gedrückt am Ende - hilft nix):
    enter handle_19:
      NULL
    Consoles: internal video/keyboard   )
    BIOS drive C: is disk0el/kernel on 0:ad(0p2)
    BIOS 638kB/3668664kB available memory
    FreeBSD/x86 boot
    FreeBSD/x86 bootstrap loader, Revision 1.1
    (root@build.callidomus.com, Tue Aug 16 17:43:05 UTC 2016)
    Loading /boot/defaults/loader.conf
    //bboooott//kkeerrnneell//kkeerrnneell  tteexxtt==00xxffee3344cc88  dda t a = 0 x 1 2 9 4 6 8 + 0 x 2 0 7 f a 0   ssy m s = [ 0 x 8 + 0 x 1 46 f 8 8 ++0 x 8 +p2)help
    0 x 1 6 1 3 a e ]]|
    //bboooott//kkeerrn e l / s p l a s h _ b m p . k o   s i z e   0 xx33bb0000  aatt  00xx1199bbdd000000
    Default: 0:ad(0p2)?
    --ot: ?. .. mfs
    BBoooottiinngg  [[//bboooott//kkeerrnneell//kkeerrnneell]]......
    Default: 0:ad(0p2)?
    \Copyright (c) 1992-2016 The FreeBSD Project.
    Copyright (c) 1979, 1980, 1983, 1986, 1988, 1989, 1991, 1992, 1993, 1994
    FreeBSD/The Regents of the University of California. All rights reserved.
    FreeBSD is a registered trademark of The FreeBSD Foundation.
    FreeBSD 10.3-RELEASE-p7 #8 r304222: Tue Aug 16 17:52:38 UTC 2016
        root@build.callidomus.com:/data/tmp/obj/amd64/data/src/releng/10.3/sys/GENERIC amd64
    FreeBSD clang version 3.4.1 (tags/RELEASE_34/dot1-final 208032) 20140512
    CPU: AMD GX-412TC SOC                                (998.15-MHz K8-class CPU)
      Origin="AuthenticAMD"  Id=0x730f01  Family=0x16  Model=0x30  Stepping=1
      Features=0x178bfbff<FPU,VME,DE,PSE,TSC,MSR,PAE,MCE,CX8,APIC,SEP,MTRR,PGE,MCA,CMOV,PAT,PSE36,CLFLUSH,MMX,FXSR,SSE,SSE2,HTT>
      Features2=0x3ed8220b<SSE3,PCLMULQDQ,MON,SSSE3,CX16,SSE4.1,SSE4.2,MOVBE,POPCNT,AESNI,XSAVE,OSXSAVE,AVX,F16C>
      AMD Features=0x2e500800<SYSCALL,NX,MMX+,FFXSR,Page1GB,RDTSCP,LM>
      AMD Features2=0x1d4037ff<LAHF,CMP,SVM,ExtAPIC,CR8,ABM,SSE4A,MAS,Prefetch,OSVW,IBS,SKINIT,WDT,Topology,PNXC,DBE,PTSC,PL2I>
      Structured Extended Features=0x8<BMI1>
      XSAVE Features=0x1<XSAVEOPT>
      SVM: NP,NRIP,AFlush,DAssist,NAsids=8
      TSC: P-state invariant, performance statistics
    real memory  = 4815060992 (4592 MB)
    avail memory = 4100100096 (3910 MB)
    Event timer "LAPIC" quality 400
    ACPI APIC Table: <CORE   COREBOOT>)
    FreeBSD/SMP: Multiprocessor System Detected: 4 CPUs
    FreeBSD/SMP: 1 package(s) x 4 core(s)
     cpu0 (BSP): APIC ID:  0
     cpu1 (AP): APIC ID:  1gpart on 0:ad(0p2)
     cpu2 (AP): APIC ID:  2
     cpu3 (AP): APIC ID:  3
    random: <Software, Yarrow> initialized
    ioapic1: Changing APIC ID to 5
    ioapic0 <Version 2.1> irqs 0-23 on motherboard
    ioapic1 <Version 2.1> irqs 24-55 on motherboard
    module_register_init: MOD_LOAD (vesa, 0xffffffff80dc6550, 0) error 19
    kbd0 at kbdmux0boot: No mfs on 0:ad(0p2)
    acpi0: <CORE COREBOOT> on motherboard
    acpi0: Power Button (fixed)
    cpu0: <ACPI CPU> on acpi0
    cpu1: <ACPI CPU> on acpi0er-
    cpu2: <ACPI CPU> on acpi0
    cpu3: <ACPI CPU> on acpi0
    atrtc0: <AT realtime clock> port 0x70-0x71 irq 8 on acpi0
    Event timer "RTC" frequency 32768 Hz quality 0
    attimer0: <AT timer> port 0x40-0x43 irq 0 on acpi0
    Timecounter "i8254" frequency 1193182 Hz quality 0
    Event timer "i8254" frequency 1193182 Hz quality 100
    Timecounter "ACPI-safe" frequency 3579545 Hz quality 850
    acpi_timer0: <32-bit timer at 3.579545MHz> port 0x818-0x81b on acpi0
    hpet0: <High Precision Event Timer> iomem 0xfed00000-0xfed003ff on acpi0
    Timecounter "HPET" frequency 14318180 Hz quality 950
    acpi_button0: <Power Button> on acpi0
    pcib0: <ACPI Host-PCI bridge> port 0xcf8-0xcff on acpi0
    pci0: <ACPI PCI bus> on pcib0
    pcib1: <ACPI PCI-PCI bridge> at device 2.2 on pci0
    pcib1: failed to allocate initial I/O port window: 0x1000-0x1fff
    pci1: <ACPI PCI bus> on pcib1
    igb0: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> mem 0xfe600000-0xfe61ffff,0xfe620000-0xfe623fff at device 0.0 on pci1
    igb0: Using MSIX interrupts with 5 vectors
    igb0: Ethernet address: 00:0d:b9:42:67:6c
    igb0: Bound queue 0 to cpu 0
    igb0: Bound queue 1 to cpu 1
    igb0: Bound queue 2 to cpu 2
    igb0: Bound queue 3 to cpu 3
    pcib2: <ACPI PCI-PCI bridge> at device 2.3 on pci0
    pci2: <ACPI PCI bus> on pcib2
    igb1: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0x2000-0x201f mem 0xfe700000-0xfe71ffff,0xfe720000-0xfe723fff at device 0.0 on pci2
    igb1: Using MSIX interrupts with 5 vectors
    igb1: Ethernet address: 00:0d:b9:42:67:6d
    igb1: Bound queue 0 to cpu 0
    igb1: Bound queue 1 to cpu 1
    igb1: Bound queue 2 to cpu 2
    igb1: Bound queue 3 to cpu 3
    pcib3: <ACPI PCI-PCI bridge> at device 2.4 on pci0
    pci3: <ACPI PCI bus> on pcib3
    igb2: <Intel(R) PRO/1000 Network Connection, Version - 2.5.3-k> port 0x3000-0x301f mem 0xfe800000-0xfe81ffff,0xfe820000-0xfe823fff at device 0.0 on pci3
    igb2: Using MSIX interrupts with 5 vectors
    igb2: Ethernet address: 00:0d:b9:42:67:6e
    igb2: Bound queue 0 to cpu 0
    igb2: Bound queue 1 to cpu 1
    igb2: Bound queue 2 to cpu 2
    igb2: Bound queue 3 to cpu 3
    pci0: <encrypt/decrypt> at device 8.0 (no driver attached)
    xhci0: <XHCI (generic) USB 3.0 controller> mem 0xfeb22000-0xfeb23fff at device 16.0 on pci0
    xhci0: 32 bytes context size, 64-bit DMA
    usbus0 on xhci0
    ahci0: <AMD Hudson-2 AHCI SATA controller> port 0x4010-0x4017,0x4020-0x4023,0x4018-0x401f,0x4024-0x4027,0x4000-0x400f mem 0xfeb25000-0xfeb253ff at device 17.0 on pci0
    ahci0: AHCI v1.30 with 2 6Gbps ports, Port Multiplier supported with FBS
    ahcich0: <AHCI channel> at channel 0 on ahci0
    ahcich1: <AHCI channel> at channel 1 on ahci0
    ehci0: <EHCI (generic) USB 2.0 controller> mem 0xfeb25400-0xfeb254ff at device 19.0 on pci0
    usbus1: EHCI version 1.0
    usbus1 on ehci0
    isab0: <PCI-ISA bridge> at device 20.3 on pci0
    isa0: <ISA bus> on isab0
    sdhci_pci0: <Generic SD HCI> mem 0xfeb25500-0xfeb255ff at device 20.7 on pci0
    sdhci_pci0: 1 slot(s) allocated
    uart0: <16550 or compatible> port 0x3f8-0x3ff irq 4 flags 0x10 on acpi0
    uart0: console (115200,n,8,1)
    orm0: <ISA Option ROMs> at iomem 0xc0000-0xc0fff,0xef000-0xeffff on isa0
    ppc0: cannot reserve I/O port range
    uart1: <16550 or compatible> at port 0x2f8-0x2ff irq 3 on isa0
    hwpstate0: <Cool`n'Quiet 2.0> on cpu0
    Timecounters tick every 1.000 msec
    random: unblocking device.
    usbus0: 5.0Gbps Super Speed USB v3.0
    usbus1: 480Mbps High Speed USB v2.0
    ugen0.1: <0x1022> at usbus0
    uhub0: <0x1022 XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
    ugen1.1: <AMD> at usbus1
    uhub1: <AMD EHCI root HUB, class 9/0, rev 2.00/1.00, addr 1> on usbus1
    ada0 at ahcich0 bus 0 scbus0 target 0 lun 0
    ada0: <TS32GMSA370 O0918B> ACS-2 ATA SATA 3.x device
    ada0: Serial Number D007501940
    ada0: 600.000MB/s transfers (SATA 3.x, UDMA6, PIO 1024bytes)
    ada0: Command Queueing enabled
    ada0: 30533MB (62533296 512 byte sectors)
    ada0: Previously was known as ad4
    SMP: AP CPU #1 Launched!
    SMP: AP CPU #2 Launched!
    SMP: AP CPU #3 Launched!
    Timecounter "TSC" frequency 998146792 Hz quality 1000
    Root mount waiting for: usbus1 usbus0
    uhub0: 4 ports with 4 removable, self powered
    uhub1: 2 ports with 2 removable, self powered
    ugen1.2: <vendor 0x0438> at usbus1
    uhub2: <vendor 0x0438 product 0x7900, class 9/0, rev 2.00/0.18, addr 2> on usbus1
    uhub2: 4 ports with 4 removable, self powered
    Trying to mount root from ufs:/dev/gpt/root1 [ro]...
    pid 16 (sh), uid 0: exited on signal 10
    Aug 24 18:15:52 init: /bin/sh on /etc/rc terminated abnormally, going to single user mode
    Enter full pathname of shell or RETURN for /bin/sh:
    pid 17 (sh), uid 0: exited on signal 11
    Aug 24 18:16:04 init: single user shell terminated, restarting
    Zuletzt geändert von DiMa; 24.08.2016, 19:19.
      In dem thread https://knx-user-forum.de/forum/supp...2c4-nicht-mehr steht was dazu.
      Gruß Waldemar
      OpenKNX www.openknx.de
        hast du den Installer nochmal laufen lassen? Also ich würde jetzt einfach nochmal von dem USBStick booten und die installation nochmal durchführen.
        VG
        Jürgen
          mumpf - zu dem shell-Problem? Dann bin ich blind... Zumal sich bei einer callidomus-Installation die shell auch unter /bin/sh finden lassen sollte.
          heckmannju - den Installer habe ich am Wochenende mehrfach laufen lassen, immer mit dem gleichen Ergebnis. Siehe weiter vorne in diesem thread. Ich kann mir eigentlich nicht vorstellen, dass sich daran nach Anschluß eines Nullmodemkabels was ändert.
          Zuletzt geändert von DiMa; 24.08.2016, 20:52.
            Aber dann kannst du dir wenigstens mal den output von dem Restart nach der Installation ansehen da wird ja irgentwas gemacht und das ist ja wohl auch irgendwas bei dir schief gelaufen. Ändern wird es nix aber vielleicht hilft es ja zu erkennen was passiert ist.
            Vg
            Jürgen
              Hi, nicht zum Shell-Problem, sondern zum boot. Ich hab wohl vor deinem edit geschrieben.
              Gruß Waldemar
                Hier der Stand von der Front: Nach einer erneuten Installation, während derer ich diesmal (!!! - das ist bei den letzten drei nicht passiert - !!!) eine Fehlermeldung bzgl. korrupten gpt bekomme
                Starting installation
                Loesche Festplatte | Clearing disk
                GEOM: diskid/DISK-D007501940: the secondary GPT table is corrupt or invalid.
                GEOM: diskid/DISK-D007501940: using the primary only -- recovery suggested.
                Formatiere Festplatte | Creating disk
                Lade aktuelles Image | Fetching current release
                -                                             100% of  112 MB 1501 kBps 01m17s
                Initialisiere data und cache | Init data and cache
                Aktiviere TRIM Unterstuetzung | Enabling trim support
                tunefs: issue TRIM to the disk set
                Installation finished!
                startet das System neu bis
                pid 16 (init), uid 0: exited on signal 11
                Aug 25 18:31:34 init: fatal signal: Segmentation fault
                Wenn ich lange genug warte, startet sich die APU selber neu und dann habe ich die gleiche Symptomatik wie in #61. Den /bin/sh-Fehler kann ich allerdings nicht mehr reproduzieren.
                Funkelnagelneue SSD defekt?!
                Ich probier's jetzt nochmal mit einer Neuinstallation und danach mal auf einer anderen APU mit einer anderen SSD... Zum Glück hat man das ja alles mehrfach 'rumliegen
                BTW, Vorschläge zur Überprüfung der SSD sind auch willkommen...
                  Also: 2x Neuinstallieren hat den gpt-Fehler eliminiert:
                  -                                             100% of  112 MB 1494 kBps 01m17s
                  Bitte geben Sie 'reboot' ein um das System neu zu starten, oder 'halt' um es herunterzufahren.
                  Enter 'reboot' to reboot, or 'halt' to halt the system.
                  Danach bootet er wieder bis zur exakt gleichen Stelle und dann wiederholt sich die Geschichte:
                  Aug 25 18:49:08 init: fatal signal: Segmentation fault
                  Ich baue jetzt auf ein anderes System um...
                    Neues System (anderes (neues) mainboard, andere (neue) SSD). Installation wie gehabt:
                    -                                             100% of  112 MB 1553 kBps 01m14s
                    Und es scheint zu laufen!!!
                    Mounting late file systems:.
                    Generating DH parameters, 2048 bit long safe prime, generator 2
                    This is going to take a long time
                    Bis später, drückt die Daumen!
                      Läuft!
                      Merke: Auch neue Hardware kann defekt sein
                      callidomus Kann ich eigentlich einfach die SSD mit dem lauffähigen System in das andere mainboard einbauen um ganz sicher zu gehen, dass das Problem wirklich von der SSD kommt, oder kriege ich dann Probleme mit dem Lizenzfile und/oder den erzeugten keys, weil die irgendwie ans mainboard gebunden sind?
                      Edith: Da ich weiterkommen muss, hab' ich es einfach probiert: Klappt. Vielleicht ja auch noch für jemand anderes interessant.
                      Wer kann mir denn jetzt helfen, meine bestehende Installation auf das neue System umzuziehen? Also was muss ich von wo nach wo kopieren?
                      Edith2: gefunden: https://knx-user-forum.de/forum/supp.../947643-backup callidomus vielleicht auch was für die Doku?
                      Zuletzt geändert von DiMa; 26.08.2016, 18:10.
