Bitte Perl regular expressions lernen: man perlre .
VG Fry
VG Fry
jalo_west_runter => {transmit=>['2/2/5','3/2/45','3/2/55'], translate=>sub{int($month) < 12 && int($month) > 1 ? 1:undef;}, debug=> 1}, # +21 min Schlafzimmer, Willi_West, Bad OG jalo_west_runter_januar => {transmit=>['2/2/5','3/2/45','3/2/55'], translate=>sub{int($month) == 1 && int($day_of_month) > 6 ? 1:undef;}, debug=> 1},
jalo_schlafzimmer_runter_januar => {transmit=>'2/2/5', timer=>{time=>['22:00'], date=>'01/01-01/06'},translate=>1,debug=>1},
2015-01-05 22:00:01.739,Logikprozessor.pl,Naechster Aufruf der timer-Logik 'jalo_schlafzimmer_runter_januar' in 361 Tagen, am 1.1.2016, um 22:00.
# eibpa.conf - falls existent - einlesen my %eibpa=(); if(open EIBPA, "</etc/wiregate/eibpa.conf") { $/="\n"; while(<EIBPA>) { next unless /^(.*)\s+([0-9]+\.[0-9]+\.[0-9]+)\s*$/; $eibpa{$2}=$1; $eibpa{$1}=$2; } close EIBPA; } $plugin_cache{$plugname}{eibpa}=\%eibpa;
P_WZ_unter_Galerie 1.1.24 P_G 1.1.25 P_WF 1.1.26 P_SZ_Ankleide 1.1.34 T_G_Tuer 1.1.35 T_G_Werkbank 1.1.36 T_WZ_u_Galerie 1.1.48 T_WZ_zentral1 1.1.49 T_WZ_zentral2 1.1.50
# Knopf Licht-aus an Eingangstuer bewirkt Szene global-aus $logic{ZZ_GL_aus}={ trigger=>'LI_GL==0', transmit=>'ZZ_GL', translate => sub { return $msg{sender} eq 'T_E' ? scene(1) : undef; }, transmit_changes_only=>1, };
diff => { receive=>'9/5/207', transmit=>'9/5/208', state=>{lastval=>undef, lasttime=>undef}, translate => sub { my $valdiff=$input-$state->{lastval}; $state->{lastval}=$input; my $timediff=$systemtime-$state->{lasttime}; $state->{lasttime}=$systemtime; return $valdiff/$timediff; } },
<?xml version="1.0" ?> <config> <logging output="/var/log/linknx.log" format="%d{%Y-%m-%d %H:%M:%S,%l} %5p > %c %x - %m%n" level="INFO" maxfilesize="10000" maxfileindex="2"></logging> <services> <knxconnection url="ip:127.0.0.1" /> <persistence type="file" path="/var/lib/linknx/persist" /> </services> <objects> <object type="1.001" id="0_0_2" gad="0/0/2" init="persist" flags="crw" /> <object type="1.001" id="0_0_5" gad="0/0/5" init="persist" flags="crw" /> <object type="1.001" id="0_1_2" gad="0/1/2" init="persist" flags="crw" /> <object type="1.001" id="0_1_3" gad="0/1/3" init="persist" flags="crw" /> </objects> </config>
xmasTimerAnAus => { transmit=>'2/0/3', transmit_on_startup=>1, translate => sub { plugin_log($plugname, "=== xmasTimerAnAus!"); ( ($month == 12 || $month == 1) ? 1 : 0 ) }, debug=>1 },
2015-01-27 13:28:43.597,Logikprozessor.pl,compiled in 0.1s 2015-01-27 13:28:44.118,Logikprozessor.pl,--- transmit_on_startup: xmasTimerAnAus 2015-01-27 13:28:44.121,Logikprozessor.pl,Followup 'xmasTimerAnAus' folgt sofort. 2015-01-27 13:28:45.158,Logikprozessor.pl,=== xmasTimerAnAus! 2015-01-27 13:28:45.228,Logikprozessor.pl,253 initialisiert; $logic->{xmasTimerAnAus}{transmit}(Logik) -> 2/0/3:1 gesendet (followup); ,1.5s,
2015-01-27 13:29:20.658,Logikprozessor.pl,253 initialisiert; ,1.5s,
if($event=~/restart|modified/ || $config_modified)
persistValueExample => { transmit=>'2/0/3', translate => 1, persist => 1, debug=>1 },
