Hallo heckmannju,
ich wäre Dir sehr dankbar, wenn Du den Scan durchführen könntest.
Viele Grüsse
Jürg
Viele Grüsse
Jürg
C:\can_progs\win>can_scan.exe com6 680 700 elster-kromschroeder can-bus address scanner and test utility copyright (c) 2015 Juerg Mueller, CH-5524 700 is not a legal can id! use scanner can_scan <can dev> <sender can id> [ <scan can id> | "total" ] [ "cs_com" ] [ "t race" ] or read/change value can_scan <can dev> <sender can id> <receiver can id> "." <elster index> [ "." <n ew value> ] [ "cs_com" ] [ "trace" ] example: can_scan can0 780 180 (scan all elster indices from 0000 to 1 fff) or can_scan can0 780 180.0126 (read minutes at elster index 0126) or can_scan can0 780 180.0126.0f00 (set minutes to 15) allowed sender can id: 680 or 700 or 780 BE CAREFUL WITH THIS TOOL !!!
C:\can_progs\win>can_scan com6 680 total elster-kromschroeder can-bus address scanner and test utility copyright (c) 2015 Juerg Mueller, CH-5524 scan on CAN-id: 680 list of valid can id's: 000 (c306 = 1731) 101 (8000 = 128) 180 (8000 = 128) 301 (c306 = 1731) 302 (8000 = 128) 480 (8000 = 128) 601 (8000 = 128) 602 (8000 = 128) { 0x000, 0x0001, 0x0045}, { 0x000, 0x0002, 0x00e5}, { 0x000, 0x0004, 0x00e5}, { 0x000, 0x0005, 0x00d3}, { 0x000, 0x0006, 0x00d3}, { 0x000, 0x0007, 0x00d3}, { 0x000, 0x0008, 0x00cc}, { 0x000, 0x0009, 0x0a17}, { 0x000, 0x000a, 0x0603}, { 0x000, 0x000b, 0xc306}, { 0x000, 0x0010, 0x0400}, { 0x000, 0x0011, 0x00d1}, { 0x000, 0x0012, 0x00cc}, { 0x000, 0x001f, 0x0190}, { 0x000, 0x0020, 0x015e}, { 0x000, 0x0021, 0x0000}, { 0x000, 0x0022, 0x0032}, { 0x000, 0x0023, 0x0000}, { 0x000, 0x0024, 0x0100}, { 0x000, 0x0025, 0x0000}, { 0x000, 0x0026, 0x0014}, { 0x000, 0x0027, 0x0352}, { 0x000, 0x0028, 0x012c}, { 0x000, 0x0029, 0x0a00}, { 0x000, 0x002a, 0x1e00}, { 0x000, 0x002b, 0x7800}, { 0x000, 0x002d, 0x00c8}, { 0x000, 0x002f, 0x0000}, { 0x000, 0x0058, 0x0000}, { 0x000, 0x0059, 0x0000}, { 0x000, 0x006e, 0x0100}, { 0x000, 0x0075, 0x01e6}, { 0x000, 0x00fa, 0x0000}, { 0x000, 0x00fe, 0x0100}, { 0x000, 0x010e, 0x0014}, { 0x000, 0x0178, 0x0001}, { 0x000, 0x018f, 0x0000}, { 0x000, 0x0199, 0x00c3}, { 0x000, 0x019a, 0x0006}, { 0x000, 0x019d, 0x0000}, ^C C:\can_progs\win>can_scan com6 680 700 elster-kromschroeder can-bus address scanner and test utility copyright (c) 2015 Juerg Mueller, CH-5524 ^C C:\can_progs\win>can_scan.exe com6 680 700.0126 elster-kromschroeder can-bus address scanner and test utility copyright (c) 2015 Juerg Mueller, CH-5524 no value read C:\can_progs\win>
