Hier ein Bild, hab keine Ahnung welches die Version angibt
Und hier meine verwendete config:
## CUSTOM ASOUND.CONF by stonie
## Channel splitting your UA0099 USB sound card to get up to four
## independent stereo outputs (...and more )
## for the first USB-Souncard:
## stereofront1 = the FRONT labeled green jack
## stereosurround1 = the SURROUND labeled black jack
## stereocenter1 = the CENTER / BASS labeled yellow jack
## stereoback1 = the BACK labeled black jack
## stereoall1 = all stereo outputs
## for the second USB-Souncard:
## stereofront2 = the FRONT labeled green jack
## stereosurround2 = the SURROUND labeled black jack
## stereocenter2 = the CENTER / BASS labeled yellow jack
## stereoback2 = the BACK labeled black jack
## stereoall2 = all stereo outputs
## labels and colors could be different for differnt vendors or
## versions of the device (Logilink, Sewell, Sweex, ...)
## put this file into your /etc/asound.conf
pcm.snd_card1 {
type hw
card 1
device 0
ctl.snd_card1 {
type hw
card 1
device 0
pcm.snd_card2 {
type hw
card 2
device 0
ctl.snd_card2 {
type hw
card 2
device 0
pcm.dmixer1 {
type dmix
ipc_key 1024
ipc_perm 0666
slave.pcm "snd_card1"
slave {
period_time 0
period_size 1024
buffer_size 4096
rate 44100
channels 8
bindings {
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
pcm.dmixer2 {
type dmix
ipc_key 1024
ipc_perm 0666
slave.pcm "snd_card2"
slave {
period_time 0
period_size 1024
buffer_size 4096
rate 44100
channels 8
bindings {
0 0
1 1
2 2
3 3
4 4
5 5
6 6
7 7
pcm.out {
type plug
slave.pcm {
type multi
slaves {
a {
channels 8
pcm "dmixer1"
b {
channels 8
pcm "dmixer2"
bindings {
0 { slave a channel 0 }
1 { slave a channel 1 }
2 { slave a channel 2 }
3 { slave a channel 3 }
4 { slave a channel 4 }
5 { slave a channel 5 }
6 { slave a channel 6 }
7 { slave a channel 7 }
8 { slave b channel 0 }
9 { slave b channel 1 }
10 { slave b channel 2 }
11 { slave b channel 3 }
12 { slave b channel 4 }
13 { slave b channel 5 }
14 { slave b channel 6 }
15 { slave b channel 7 }
pcm.!default {
type plug
slave {
pcm "out"
channels 16
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
ttable.0.4 1
ttable.1.5 1
ttable.0.6 1
ttable.1.7 1
ttable.0.8 1
ttable.1.9 1
ttable.0.10 1
ttable.1.11 1
ttable.0.12 1
ttable.1.13 1
ttable.0.14 1
ttable.1.15 1
pcm.stereofront1 {
type plug
slave {
pcm "out"
channels 16
ttable.0.0 1
ttable.1.1 1
pcm.stereocenter1 {
type plug
slave {
pcm "out"
channels 16
ttable.0.2 1
ttable.1.3 1
pcm.stereoback1 {
type plug
slave {
pcm "out"
channels 16
ttable.0.4 1
ttable.1.5 1
pcm.stereosurround1 {
type plug
slave {
pcm "out"
channels 16
ttable.0.6 1
ttable.1.7 1
pcm.stereofront2 {
type plug
slave {
pcm "out"
channels 16
ttable.0.8 1
ttable.1.9 1
pcm.stereocenter2 {
type plug
slave {
pcm "out"
channels 16
ttable.0.10 1
ttable.1.11 1
pcm.stereoback2 {
type plug
slave {
pcm "out"
channels 16
ttable.0.12 1
ttable.1.13 1
pcm.stereosurround2 {
type plug
slave {
pcm "out"
channels 16
ttable.0.14 1
ttable.1.15 1
pcm.alle {
type plug
slave {
pcm "out"
channels 16
ttable.0.0 1
ttable.1.1 1
ttable.0.2 1
ttable.1.3 1
ttable.0.4 1
ttable.1.5 1
ttable.0.6 1
ttable.1.7 1
ttable.0.8 1
ttable.1.9 1
ttable.0.10 1
ttable.1.11 1
ttable.0.12 1
ttable.1.13 1
ttable.0.14 1
ttable.1.15 1
