8-Kanal Multiroom Audio Controller+Verstärker auf piCorePlayer Basis
  • stonie2oo4
    Also ich hab folgende config bei mir für 2 Soundkarten im Einsatz. Ist allerdings auch auf einem Pi3 und frag mich bitte nicht welche picore Version ich hab.
    Hier ein Bild, hab keine Ahnung welches die Version angibt .
    Und hier meine verwendete config:
    ## CUSTOM ASOUND.CONF by stonie
    ## Channel splitting your UA0099 USB sound card to get up to four
    ## independent stereo outputs (...and more )
    ## for the first USB-Souncard:
    ## stereofront1 = the FRONT labeled green jack
    ## stereosurround1 = the SURROUND labeled black jack
    ## stereocenter1 = the CENTER / BASS labeled yellow jack
    ## stereoback1 = the BACK labeled black jack
    ## stereoall1 = all stereo outputs
    ## for the second USB-Souncard:
    ## stereofront2 = the FRONT labeled green jack
    ## stereosurround2 = the SURROUND labeled black jack
    ## stereocenter2 = the CENTER / BASS labeled yellow jack
    ## stereoback2 = the BACK labeled black jack
    ## stereoall2 = all stereo outputs
    ## labels and colors could be different for differnt vendors or
    ## versions of the device (Logilink, Sewell, Sweex, ...)
    ## put this file into your /etc/asound.conf
    pcm.snd_card1 {
    type hw
    card 1
    device 0
    ctl.snd_card1 {
    type hw
    card 1
    device 0
    pcm.snd_card2 {
    type hw
    card 2
    device 0
    ctl.snd_card2 {
    type hw
    card 2
    device 0
    pcm.dmixer1 {
    type dmix
    ipc_key 1024
    ipc_perm 0666
    slave.pcm "snd_card1"
    slave {
    period_time 0
    period_size 1024
    buffer_size 4096
    rate 44100
    channels 8
    bindings {
    0 0
    1 1
    2 2
    3 3
    4 4
    5 5
    6 6
    7 7
    pcm.dmixer2 {
    type dmix
    ipc_key 1024
    ipc_perm 0666
    slave.pcm "snd_card2"
    slave {
    period_time 0
    period_size 1024
    buffer_size 4096
    rate 44100
    channels 8
    bindings {
    0 0
    1 1
    2 2
    3 3
    4 4
    5 5
    6 6
    7 7
    pcm.out {
    type plug
    slave.pcm {
    type multi
    slaves {
    a {
    channels 8
    pcm "dmixer1"
    b {
    channels 8
    pcm "dmixer2"
    bindings {
    0 { slave a channel 0 }
    1 { slave a channel 1 }
    2 { slave a channel 2 }
    3 { slave a channel 3 }
    4 { slave a channel 4 }
    5 { slave a channel 5 }
    6 { slave a channel 6 }
    7 { slave a channel 7 }
    8 { slave b channel 0 }
    9 { slave b channel 1 }
    10 { slave b channel 2 }
    11 { slave b channel 3 }
    12 { slave b channel 4 }
    13 { slave b channel 5 }
    14 { slave b channel 6 }
    15 { slave b channel 7 }
    pcm.!default {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
    ttable.0.4 1
    ttable.1.5 1
    ttable.0.6 1
    ttable.1.7 1
    ttable.0.8 1
    ttable.1.9 1
    ttable.0.10 1
    ttable.1.11 1
    ttable.0.12 1
    ttable.1.13 1
    ttable.0.14 1
    ttable.1.15 1
    pcm.stereofront1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1
    ttable.1.1 1
    pcm.stereocenter1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.2 1
    ttable.1.3 1
    pcm.stereoback1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.4 1
    ttable.1.5 1
    pcm.stereosurround1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.6 1
    ttable.1.7 1
    pcm.stereofront2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.8 1
    ttable.1.9 1
    pcm.stereocenter2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.10 1
    ttable.1.11 1
    pcm.stereoback2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.12 1
    ttable.1.13 1
    pcm.stereosurround2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.14 1
    ttable.1.15 1
    pcm.alle {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
    ttable.0.4 1
    ttable.1.5 1
    ttable.0.6 1
    ttable.1.7 1
    ttable.0.8 1
    ttable.1.9 1
    ttable.0.10 1
    ttable.1.11 1
    ttable.0.12 1
    ttable.1.13 1
    ttable.0.14 1
    ttable.1.15 1
  • Hewi92
    Hat schon jemand das Ganze mit 2 Soundkarten am Raspberry PI4 und PCP 6 am laufen.
    bei mir Funktionierts nur mit einer Soundkarte.
    Wenn ich allerdings die gleiche SD-Karte in einen RPI3 schiebe funktionieren beide Soundkarten.
    Verwende diese Alsaconfig:
    ## stereofront = the FRONT labeled green jack
    ## stereosurround = the SURROUND labeled black jack
    ## stereocenter = the CENTER / BASS labeled yellow jack
    ## stereoback = the BACK labeled black jack
    ## stereoall = all stereo outputs
    ## for up to eight mono output channels use:
    ## monofrontl = the FRONT labeled green jack - tip
    ## monofrontr = the FRONT labeled green jack - ring
    ## monosurroundl = the SUROUND labeled black jack - tip
    ## monosurroundr = the SUROUND labeled black jack - ring
    ## monocenterl = the CENTER / BASS labeled yellow jack - tip
    ## monocenterr = the CENTER / BASS labeled yellow jack - ring
    ## monobackl = the BACK labeled black jack - tip
    ## monobackr = the BACK labeled black jack - ring
    ## put this file into your /ect/asound.conf
    # pcm.pcpinput { #Line Input Streamer
    # type plug
    # slave.pcm "hw:1,0"
    pcm.snd_card1 { # alias for sound card 1
    type hw # must be hw in our case
    card 1 # check your correct card number by typing
    device 0 # 'aplay -l' in your terminal
    } # the 1st usb card on the Raspi shows as
    # card 1: Device [USB Sound Device], device 0: USB Audio [USB Audio]
    ctl.snd_card1 {
    type hw
    card 1
    device 0
    pcm.snd_card2 { # alias for sound card 2
    type hw
    card 2
    device 0
    ctl.snd_card2 {
    type hw
    card 2
    device 0
    pcm.dmixer1 {
    type dmix
    ipc_key 1024 # must be unique number on your system
    ipc_perm 0666 # neccesary for normal user to have access
    slave {
    period_time 0
    period_size 1024
    buffer_size 4096
    rate 44100
    channels 8
    bindings {
    0 0
    1 1
    2 2
    3 3
    4 4
    5 5
    6 6
    7 7
    pcm.dmixer2 {
    type dmix
    slave {
    period_time 0
    period_size 1024
    buffer_size 4096
    rate 44100
    channels 8
    bindings {
    0 0
    1 1
    2 2
    3 3
    4 4
    5 5
    6 6
    7 7
    pcm.out {
    type plug
    slave.pcm {
    type multi
    slaves {
    a {
    channels 8
    pcm "dmixer1"
    b {
    channels 8
    pcm "dmixer2"
    bindings {
    pcm.!default {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
    ttable.0.4 1
    ttable.1.5 1
    ttable.0.6 1
    ttable.1.7 1
    ttable.0.8 1
    ttable.1.9 1
    ttable.0.10 1
    ttable.1.11 1
    ttable.0.12 1
    ttable.1.13 1
    ttable.0.14 1
    ttable.1.15 1
    #Soundkarte 1
    pcm.stereofront1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1
    ttable.1.1 1
    pcm.stereocenter1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.2 1
    ttable.1.3 1
    pcm.stereoback1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.4 1
    ttable.1.5 1
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.6 1
    ttable.1.7 1
    pcm.stereoall1 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1 # input left and right to all 4 l+r outputs
    ttable.1.1 1
    ttable.0.2 1
    ttable.1.3 1
    ttable.0.4 1
    ttable.1.5 1
    ttable.0.6 1
    ttable.1.7 1
    pcm.monofrontl1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.0 1 # in-channel 0, out-channel 0, 100% volume
    ttable.1.0 1 # in-channel 1, out-channel 0, 100% volume
    pcm.monofrontr1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.1 1
    ttable.1.1 1
    pcm.monocenterl1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.2 1
    ttable.1.2 1
    pcm.monocenterr1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.3 1
    ttable.1.3 1
    pcm.monobackl1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.4 1
    ttable.1.4 1
    pcm.monobackr1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.5 1
    ttable.1.5 1
    pcm.monosurroundl1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.6 1
    ttable.1.6 1
    pcm.monosurroundr1 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.7 1
    ttable.1.7 1
    # Soundkarte 2
    pcm.stereofront2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.8 1
    ttable.1.9 1
    pcm.stereocenter2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.10 1
    ttable.1.11 1
    pcm.stereoback2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.12 1
    ttable.1.13 1
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.14 1
    ttable.1.15 1
    pcm.stereoall2 {
    type plug
    slave {
    pcm "out"
    channels 16
    ttable.0.8 1 # input left and right to all 4 l+r outputs
    ttable.1.9 1
    ttable.0.10 1
    ttable.1.11 1
    ttable.0.12 1
    ttable.1.13 1
    ttable.0.14 1
    ttable.1.15 1
    pcm.monofrontl2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.8 1 # in-channel 0, out-channel 0, 100% volume
    ttable.1.8 1 # in-channel 1, out-channel 0, 100% volume
    pcm.monofrontr2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.9 1
    ttable.1.9 1
    pcm.monocenterl2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.10 1
    ttable.1.10 1
    pcm.monocenterr2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.11 1
    ttable.1.11 1
    pcm.monobackl2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.12 1
    ttable.1.12 1
    pcm.monobackr2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.13 1
    ttable.1.13 1
    pcm.monosurroundl2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.14 1
    ttable.1.14 1
    pcm.monosurroundr2 {
    type route
    slave {
    pcm "out"
    channels 16
    ttable.0.15 1
    ttable.1.15 1
  • Hewi92
    Zitat von Monaco Beitrag anzeigen
    Super cooles Projekt. Vielen Dank fürs Teilen.
    Wie bekommt ihr die Alsomixer Einstellungen über einen Reboot hinaus gespeichert? bei mir tut
    sudo alsactl store
    sudo filetool.sh -b
    leider nicht. Ich bin aber auch kein Linux Crack.
    mit einem
    sudo alsactl restore
    werden die gespeicherten Einstellungen wieder geladen.
    Ich habe es so gelöst indem ich mir diesen Code in die
    [I]bootlocal.sh[/I]
    geschrieben habe.
    Vielleicht gibt es aber auch noch andere/bessere Ansätze
    LG
  • Monaco
    sudo alsactl store
    sudo filetool.sh -b
  • mfd
    Zitat von eldrik Beitrag anzeigen
    Mittlerweile ist der Player auf drei USB Soundkarten, für 12 versorgte Räume, angewachsen
    Das kommt davon, wenn eine Umsetzung so günstig ist, dann kriegen die Spielkinder nie genug...
    Hätte ich mal Lizenzgebühren pro verbautem Kanal verlangen sollen...
  • eldrik
    Zitat von blaum Beitrag anzeigen
    Danke mars und Hochpass !
    Ich vermute, man steckt dann einen massiven Leiter durch alle 8 Module und lötet die jeweils an. Anschließend die Zuleitung in der Mitte zw. dem 4. und 5. Modul anlöten, oder?
    Ich habe es bei mir für die Spannungsversorgung als auch für die zugehörigen Mute Partner, mit einem entsprechenden starren Silberdraht passend zur Bohrung, der noch in der Schublade lag, direkt verlötet.
    https://knx-user-forum.de/forum/%C3%...99#post1128699
    Greetz
    Eldrik
  • Lennox
    Alter...., Respekt! So etwas würde mir nie einfallen.
  • Hochpass
    A ist besser als B. Draht durchstecken wird nicht gehen, weil die Bohrungen in der Leiterkarte nicht sehr groß ist.
    Niederimpedant heißt kurz und großer Querschnitt. Theoretisch ist es besser den Querschnitt zu erhöhen, praktisch hätte ich gesagt probier es erstmal aus bevor es ein Kunstwerk wird. Ideal wird es eh nicht, gut ist gut genug. -> Probiers aus. 3 m Klinkenkabel in der Mitte durchschneiden und 1,5 Meter Überlänge im Gehäuse verstauen wird nix. 10-15 cm Kabel gut verlegt wir sicher noch ok sein.
    Zuletzt geändert von Hochpass; 15.01.2020, 22:02.
  • blaum
    Also so (a)
    und nicht so (b):
    Ist es ok, die Zuleitungen vom Netzteil mittels Klemmen (Wago 221) zu machen oder sollten diese auch verlötet werden?
    Noch eine Nachfrage zur Verbindung zw. Soundkarte und den Verstärkermodulen. Du (Hochpass) hattest geschrieben, Masseverbindung wie gehabt niederimpedant ausführen. Das heißt auch hier möglicht großen Querschnitt? Die Klinkenkabel haben ja (zumindest meine hier) einen sehr kleinen Querschnitt... Sollte man dann hier das Kabel nach dem Klinkenstecker abschneiden und dickere anlöten?
  • Hochpass
    Zitat von mfd Beitrag anzeigen
    Den Link auf den Beitrag von Hochpass habe ich im Eingangspost ergänzt.
    Oh, dann hätte ich mir mehr Mühe geben sollen...
    blaum
    Besser als Klemmen für die Spannungsversorgung ist das direkte Löten wie du es beschrieben ist. Dabei besonders auf die Masse aufpassen. Zwischen den Verstärkermodulen so dick und kurz wie möglich. Klemmen haben höhere Übergangswiderstände als direkte Lötung.
    Sekundärseitig auf Lautsprecherseite kann man nicht viel falsch machen, da gibt es keine Masseschleifen. Auch die Übergangswiderstände von klemmen sind nicht so relevant.
    Stecker die man am Gehäuse befestigt nennt man Panelmontage. Lautsprecherbuchen für Panelmontage spuckt bei Google jede menge aus. Ich habe Banenenbuchsen genommen da man dafür ein einfaches rundes Loch ins Gehäuse bohren kann.
    https://www.ebay.de/i/254149584433
    Kabel zwischen Verstärkermodueln und Soundkarte wie gehabt nicht zu lang. Masseverbindung wie gehabt niederimpedant und keine großen Schleifen legen.
    Bei den LEDs gibt es unterschiede im Vorwärtsstrom 20-25 mA ist üblich. Es gibt spezielle low power LED mit 3-5mA. Die würde ich bevorzugen, weil der PI an allen GPIOs in Summe nur 50mA treiben kann/darf. Die IOs kann man himmeln wenn man drüber hinausgeht.
    Die Muteschaltung im ersten Post wird wohl funktionieren ist aber nicht ganz ideal, da der Strom nicht definiert ist .
  • mfd
    Bei meinem ursprünglichen Aufbau sind ja auch "Mono" Module verbaut, für jeden Kanal eines. Das sollte IMHO so stimmen.
    Das ist auch baugleich mit dem im Link von mars
  • uncelsam
    mfd Beim Link hast du allerdings das BTl-Mono Modul erwischt, den müsstest noch mal anpassen ;-)
  • mfd
    Intenos
    blaum
    Link für das Verstärkermodul ist erneuert. Es gibt aber auch viele weitere Händler, die die baugleiche Platine anbieten. Das sollte die Beschaffung eigentlich einfach machen.
  • mars
    ... bin zwar kein Guru, aber habe mir ein Gerät gebaut, das sehr zur Zufriedenheit läuft.
    Ich versuche mal ein paar Fragen zu beantworten:
    Link zu ebay mit den TPA3118D2 Endstufenmodule funktioniert nicht
    suche mal in der Bucht nach TPA3118. Da kommen eine vielzahl von Angeboten, z.B.: das hier
    Massiven Leiter durchs Lötloch stecken und rundherum anlöten?
    genau so habe ich es gemacht. An diese "Verbinder" habe ich dann direkt die Verbindung zur SV angelötet.
    Gilt das gleiche auch für die Lautsprecherleitungen?
    hier habe ich die Leitungen zu den Klemmen direkt angelötet, da die Verbindung der Verstärker imho keinen Sinn macht (getrennte Stereo-Kanäle)
    Und wo findet man eigentlich diese Buchsen bzw. wie heißen die?
    z.B. bei Reichelt (Leiterplattenklemmen) oder Voelkner (Platinenteckverbinder)
    Was für Teile/Buchsen kann man hier nehmen?
    Ich wollte die Verbindung zu den Lautsprecherleitungen im Schrank steckbar und habe diese steckbaren Lüsterklemmen verwendet. Gibt sicher auch andere steckbare Lösungen aber die Klemmen habe ich gut im Gehäuse befestigen können.
    Wie verhält es sich mit den Leitungen von der Soundkarte zu den Verstärkerplatinen?
    Ich habe vorkonfektionierte 3,5mm-Klinkenkabel (beideitig Stereo-Klinke) verwendet und in der Mitte durchgeschnitten. Der Stecker kommt in die Soundkarte, das freie Ende direkt an der Verstärkerplatinen angelötet.
    Einfach irgendwelche bedrahteten 5mm LEDs
    Ja, genau so (Ich habe 3mm LEDs genommen, da passen 4 Stück nebeneinander gut in ein 1HE-Gehäuse ;-)
    Querschnitt vermutl. egal, oder?
    Ja, völlig egal, wird ja keine Leitung übertragen.
    Also direkt nach dem einen Widerstand parallel 8x auf die einzelnen GPIO Leitungen, oder?
    Die Frage verstehe ich nicht. Die einzelnen GPIOs müssen getrennt bleiben. Einfach mehrere GPIOs parallel auf einen Widerstand geht nicht. Dann sind sie miteinander Verbunden bzw. gegeneinander kurzgeschlossen.
    Es gab mal eine Muting-Platine von papaarrugada (vielen Dank noch Mal dafür). Ggf. hat er noch welche zu verkaufen. Einfach mal fragen.
    Gruß Marco
  • blaum
    Der im Eingagsposting verlinkte Link zu ebay mit den TPA3118D2 Endstufenmodule funktioniert nicht mehr. Gibt es eine empfohlene Alternative?
