Gira expert logic question (timer function)
    Hi
    I have an external webserver where I save selected HS3 communication object data to a mysql server. In this example, I have 3 Expert functions Web pages/IP devices items setup (1 for electric usage, 1 for water usage, 1 for temperatures)
    filedata/fetch?id=1170932&d=1513862117&type=thumb
    No my question is , since I haven't got my up to date HS3 project files anymore, is how can I let the HS3 run these 3 Expert functions Web pages/IP devices at a regular interval ? (preferably every 30minutes)
    I have setup the following logic, but I cannot test it out in real life if I'm not sure it's working like I hope, because otherwise I lose the current (working) situation on my HS3
    filedata/fetch?id=1170933&d=1513862117&type=thumb
    This gallery has 2 photos.
    That logic looks OK. That module sends a '1' followed by a '0'. As this is a command (which only acts on a value not equal to zero) you could also use a simpler module, such as 9030 (Telegrammgenerator). You could also consider having only a single output with three commands - depends on your personal preference. For clarification I always include a few words in the 'Designation' field of the command, in this case it would be 'Query Tellerstanden & Temperatures'.
    Bram
      Bram
      Thanks for the help
      I'm a bit out of practice, my last steps with KNX were about 5 years back. (If it ain't broken, don't fix it) But now I want to make some adjustments, so I need to get back into the programming.
        ...not programming, others did that for us. All we do is a bit of configuration...
          Hi Houseofdreams,
          there are several way in realizing it like bramlangen mentioned. If you want to indivually specify your interval through your VISU you could also use a logic like this.
          Through "Schalter" you can switch it on/off. "Zyklus" is your intervall in seconds and in "Ausgangs-Box" I have specified my http-requests.
          Quite easy to handle.
          Ciao
          DJ
          Darf man fremden Leuten eigentlich Fragen stellen, nachdem sie im Bus telefoniert haben und einem noch etwas unklar ist?
          Projects: Sonos Gateway (Musterprojekt) - KNX-MonAMI - Nutzer-Profile
            This now works, sort of I just need to find the correct telnet settings in the send-tab, but that will not be a problem, just a little trial & error...
            Thanks for all the help, much appreciated!
