Weil UP Geräte nicht in den Schaltschrank gehören?
Ich bin davon ausgegangen, dass du kein REG Gerät mit 4 Eingängen brauchst.
// cistern measurement table (got from manufacturer GRAF) // data below are from a 7500l flat plastic cistern // // first column = fillheight in mm // second column = liter const literingTable = [ [0, 0], [100, 368], [200, 976], [300, 1621], [400, 2339], [500, 3153], [600, 3796], [700, 4609], [800, 5341], [900, 6057], [1000, 6731], [1100, 7301], [1200, 7515], [1260, 7550] ]; // pressure Sensor parameters const max_height = 2; // 2m const max_mA = 20; // mA at max_height const min_mA = 4; // mA at zero height // index to table for lowest level in cistern where water // can still be sourced. Below, pump can't reach the water const percent_0_index = 2 // eg, 2 is 200mm // Main starts here var y; var measured_mA = msg.payload; // get mA value from Sensor as input if (measured_mA < min_mA){ // if its below allowed range, then exit node.warn("Error ! Input Value below 4mA") return; } var high_mm = Math.round((max_height * 1000 / (max_mA - min_mA) * (measured_mA - min_mA))); // bugfix -> string problem fixed var x = high_mm; //search for fitting table area, getting index into table as i for(var i = 0; i < literingTable.length; i++) { if ( literingTable[i][0] > x ) break; // if "end entry" found, then exit } i = i - 1; // correct index to "start entry" // check if index was inside table and not the last entry if (i<literingTable.length-1){ // was inside table // get values from table var x1 = literingTable[i+0][0]; var y1 = literingTable[i+0][1]; var x2 = literingTable[i+1][0]; var y2 = literingTable[i+1][1]; // and calculate the value in between y=y1+((x-x1)/(x2-x1)*(y2-y1)); } else{ // was the last entry, // so return last entry as fixe value from table // no calcuation needed y=literingTable[i+0][1] } // calculate percentage from table index 2 as 0% to last table index as 100% var percent = 100 / (literingTable[literingTable.length-1][1] - literingTable[percent_0_index][1]); percent = (percent * (y - literingTable[2][1])).toFixed(0) * 1; if (percent < 0){ percent = -1; } msg = { topic: "L", payload: y }; msg2 = { topic: "%", payload: percent }; return [msg, msg2];
