Dear all,
sorry for English, my written German is not so good. I can read it und understand so you can reply also in German.
We have one KNX project with topology presented on the attached picture.
There is 1 ABB IPR/S IP router and 2 ABB LK/S line coupler devices which should devide topology in 3 lines, one for each floor.
KNX physical addresses are set as presented on the picture. We noticed that LK/S can only be set to have address in from the same segment where is IPR/S.
While setting up the system with base settings for the IPR/S and LK/S we noticed that there is no KNX communication between floors, so push button from Line 2 can’t reach device on Line 2 (through group addresses).
Settings for group telegrams in the IPR/S and LK/S was set to filter. We changed this to route and communication between floors staring to work fine.
But recently we found that we have certain communication problem in whole KNX network. For now it is showing when we try to program certain devices. For example from our PC we can’t change settings of the switcher 1.1.11, from ETS 5 we get the message that device can’t be reached in the defined time. But in the same time we can program switcher 1.2.11 or 1.3.11. Also if we disconnect Line 2 and Line 3 from Line 1 then we can program device 1.1.11.
We checked traffic and it seems that there is no heavy traffic on the network. Only 4 thermostats are set to send actual temperature with the value change all other devices are set to send a telegram on change or request.
From all of this we can conclude that maybe we made some error in the topology configuration. I'm not sure did we make some error in the topology or there is some error in the line coupler settings. Settings of the line coupler are also attached.
Can you please give some suggestions or advise.
Many thanks.
Regards
Alen
Many thanks.
Regards
Alen
