/usr/local/edomi/www/data/log/edomi-smarthome-skill-PLv3.log
Alexa Smarthome Skill (Payload Version 3)
existiert nicht nur das normale Log von Edomi
Code:[TR] [TD="colspan: 5"]{EDOMI,CUSTOMLOG_Alexa_Smarthome_Skill-LBS19001200.htm,12.01.2020,20:04:19,056265,21213}[/TD] [/TR] [TR] [TD]Zeitstempel[/TD] [TD]ms[/TD] [TD]PID[/TD] [TD]LogLevel[/TD] [TD]Meldung[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]056225[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: LBS started[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]065709[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: Daemon is not running[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]065970[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: Starting daemon ...[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]073951[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: LBS ended[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318100[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: LBS started[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318561[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: Discovered SmartHome Devices:[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318594[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: ================ ARRAY/OBJECT START ================[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318619[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: {"Device001":{"id":"Device001","name":"Licht K\u00fcche","proactive":"0","retrievable":"1","dea ctivation":null,"displayCategory":"LIGHT","camConf igs":null,"capabilities":[{"interface":"Alexa.PowerController","propertie s":["powerState"]}]}}[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318641[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: ================ ARRAY/OBJECT END ================[/TD] [/TR] [TR] [TD]2020-01-12 20:04:19[/TD] [TD]318837[/TD] [TD]21213[/TD] [TD]debug[/TD] [TD]LBS19001200 [v0.6]: LBS ended[/TD] [/TR]
hmm, ich bin zumindest schon mal weiter. Ich hatte statt profile:user_id nur user_id drin.
Jetzt schimpft er aber was mit oAuth. hab das ganze jetzt 2x noch durchgeschaut, aber nu ist alles so wie in der Anleitung. Fällt dir ein an was das noch liegen könnte?
Code:Verknüpfung mit EDOMI konnte diesmal nicht hergestellt werden. Weitere Informationen und Unterstützung bei der Konfiguration Ihres Skills für die Kontoverknüpfung mit OAuth finden Sie in [URL="https://developer.amazon.com/public/solutions/alexa/alexa-skills-kit/docs/linking-an-alexa-user-with-a-user-in-your-system"]diesem Handbuch[/URL].
mea culpa, da is was beim kopieren schiefgegangen. geht aber trotzdem nicht, aber ich hab jetz ein Skill-Log für dich
scheint dass er den Token nicht verifizieren kann / nicht bekommt
PHP-Code:Received (JSON) Event from alexa@amazon ========================================= No OAUTH Access Token received Received (JSON) Event from alexa@amazon ========================================= Array ( [directive] => Array ( [header] => Array ( [payloadVersion] => 3 [namespace] => Alexa.Authorization [name] => AcceptGrant [messageId] => 51118c8e-34b1-4633-a1df-ad8751edf4c5 ) [payload] => Array ( [grantee] => Array ( [token] => Atza|IwEBIEsIvk0rzIy_XAq-KMvM_fk-qaEOaDdlCx4AgSZVnFBoFAtSZfcc9SU3PuHwjbx4hGAX-zfmgwNNks26MjvGVwNMb_4lx0k91HZZJyU6Nu6CVwnA1sZeiqN 2RjKdwcbe9BuVoUlY4t28Q3Uipwm1k5xco1ceWviPJP4jhmwUe HclzJsVBcNiJeS5KwBWFwULJ43pbe_qvDHuhu74Aai0Mocfybf eL7akRxheDdQIlG5L0TNRa0Hb1YvksgjZpyKxiHuROOt1tZ-6mNp4N6nT5mREcf7RyNrbX7_0iK3ZpnV2-AR3kDzuUzeijyajF9SoHCLG5jqKHdTQapXyqYbnlMvJ2O-fnICdu3LGz0zw75x1XUm5cF770nMi_WFzMnkOOt7F2L4O4lp34 wGfiKT3chcCIv53fByIKkOZDroGxzcW5BDi6U84G7DyINhnsUp IpFILLBANBddNkK7pBqrgc-0hvi3JVkobOUzdH4AZ_vik7T8Am895xhNzZb79zeAsLpNhbXix 7AR8azK5y6Xghyac [type] => BearerToken ) [grant] => Array ( [code] => RHjXXwUoxHIEGsxDNaNc [type] => OAuth2.AuthorizationCode ) ) ) ) Validation URL: https://api.amazon.com/auth/O2/tokeninfo?access_token=Atza|IwEBIEsIvk0rzIy_XAq-KMvM_fk-qaEOaDdlCx4AgSZVnFBoFAtSZfcc9SU3PuHwjbx4hGAX-zfmgwNNks26MjvGVwNMb_4lx0k91HZZJyU6Nu6CVwnA1sZeiqN 2RjKdwcbe9BuVoUlY4t28Q3Uipwm1k5xco1ceWviPJP4jhmwUe HclzJsVBcNiJeS5KwBWFwULJ43pbe_qvDHuhu74Aai0Mocfybf eL7akRxheDdQIlG5L0TNRa0Hb1YvksgjZpyKxiHuROOt1tZ-6mNp4N6nT5mREcf7RyNrbX7_0iK3ZpnV2-AR3kDzuUzeijyajF9SoHCLG5jqKHdTQapXyqYbnlMvJ2O-fnICdu3LGz0zw75x1XUm5cF770nMi_WFzMnkOOt7F2L4O4lp34 wGfiKT3chcCIv53fByIKkOZDroGxzcW5BDi6U84G7DyINhnsUp IpFILLBANBddNkK7pBqrgc-0hvi3JVkobOUzdH4AZ_vik7T8Am895xhNzZb79zeAsLpNhbXix 7AR8azK5y6Xghyac JSON Validation Response: OAUTH Validattion Response: Source : FAIL OAUTH Access Token invalid Received (JSON) Event from alexa@amazon ========================================= Array ( [directive] => Array ( [header] => Array ( [payloadVersion] => 3 [namespace] => Alexa.Authorization [name] => AcceptGrant [messageId] => c246a83b-137f-4efa-8595-ec8fa85ca328 ) [payload] => Array ( [grantee] => Array ( [token] => Atza|IwEBIAqyKd4GEAvl7EoQtMi7qNgKS0UTVW_zqqOBNthH2 wRCv-YjlMabL7UefHUTrd6pYLNlb4455NWmcUn8x33TMewotourTO9h qFS3C1q-vJ-opXqaQUdxR9BnD33zM_0NsdS2N19dLjtk2mlHM4hXRZzwYgVMQ jAqNoCeow6w5A2Zl9lMLZwElRNXjcsXnReQZfAqOxpAJyOjb0n HPXks2h9-iVyLnVB9G-Tf4a4Jl6vAfr0G83zjXy8MN3UT37nJNJIvig2Nqrgx3xL3JXVW NAuZQQFocxrxpWZlpZC3ySFW_q761BR1CJDnVYUzu9NfitOVe3 Ra6i6ToktGkkeFLtke8uKvsJepC4nNaBkoD8_nhXLmpQa6pxT_ LVWej0hcj2ydLQR2yX5NH663tm0pKI9dvp7jvcgO_QFe0ifXRE vPA6w84dgblanqJ9ImX-rZSShL9g8vbdavGMoSkQ4okBKHEj-JBJvGXdw1NrA5IdtOkOrmghm2KyKc0P_iFPqlxAenFOeJABXdH kPZ1uktZUxk [type] => BearerToken ) [grant] => Array ( [code] => RHMEZjcsNVshaZxQFEOc [type] => OAuth2.AuthorizationCode ) ) ) ) Validation URL: https://api.amazon.com/auth/O2/tokeninfo?access_token=Atza|IwEBIAqyKd4GEAvl7EoQtM i7qNgKS0UTVW_zqqOBNthH2wRCv-YjlMabL7UefHUTrd6pYLNlb4455NWmcUn8x33TMewotourTO9h qFS3C1q-vJ-opXqaQUdxR9BnD33zM_0NsdS2N19dLjtk2mlHM4hXRZzwYgVMQ jAqNoCeow6w5A2Zl9lMLZwElRNXjcsXnReQZfAqOxpAJyOjb0n HPXks2h9-iVyLnVB9G-Tf4a4Jl6vAfr0G83zjXy8MN3UT37nJNJIvig2Nqrgx3xL3JXVW NAuZQQFocxrxpWZlpZC3ySFW_q761BR1CJDnVYUzu9NfitOVe3 Ra6i6ToktGkkeFLtke8uKvsJepC4nNaBkoD8_nhXLmpQa6pxT_ LVWej0hcj2ydLQR2yX5NH663tm0pKI9dvp7jvcgO_QFe0ifXRE vPA6w84dgblanqJ9ImX-rZSShL9g8vbdavGMoSkQ4okBKHEj-JBJvGXdw1NrA5IdtOkOrmghm2KyKc0P_iFPqlxAenFOeJABXdH kPZ1uktZUxk JSON Validation Response: OAUTH Validattion Response: Source : FAIL OAUTH Access Token invalid Received (JSON) Event from alexa@amazon ========================================= Array ( [directive] => Array ( [header] => Array ( [payloadVersion] => 3 [namespace] => Alexa.Authorization [name] => AcceptGrant [messageId] => 0dc9b03d-3095-4194-bf56-182d6121eca9 ) [payload] => Array ( [grantee] => Array ( [token] => Atza|IwEBIOmCM6s45PLx7-HOD8eQqYd1q4Em-PqUU4L84RwOghPWA7fGJ1hmEpKw3slpn24KN6R_rJU2FYlmja2 bRzbf3EFZ4rcru0xqVxIrU9svvU4Mb92mGyKnvIGDGKfVBWf59 edDGrk4ZE_he3PNDKPYJ2X55ssGCyXzSyKT3mCLDo7v2RRSaNc TJkirOiVa82xu11WAwzn5eOJgnTsMZYBqzWok3V_KeuODv49YV qurmLF0iD1iJdNDwgMA1rc9wGECoQcx3ymK1xASjHQuBVZyZOL oiaEoyFSagd5dCGG5GQ63dFwbsax5shPt5NJAV8m1kbMbmfPJM OUORcvL7itVjZXQWN6qoQ-5EoVDqLnB9ph8SYgEbiS2Rqlz3Kw6Ptn4z6GMG6UuGLHMgi6_r 71OolCZjFBGZkFhxxsNm1LQ-PHOartBB76mp2ZRIDvru4wL4BjUeex8PuRQHAHSNoWQi7T9x-YYZExbP9bJGwE9sOGuMeXyXBvXjUq1p647OWEoE-jp4ljt_4xIT0T-wp5tC6-8 [type] => BearerToken ) [grant] => Array ( [code] => RHEdSSuYOusPWunlGiLR [type] => OAuth2.AuthorizationCode ) ) ) ) Validation URL: https://api.amazon.com/auth/O2/tokeninfo?access_token=Atza|IwEBIOmCM6s45PLx7-HOD8eQqYd1q4Em-PqUU4L84RwOghPWA7fGJ1hmEpKw3slpn24KN6R_rJU2FYlmja2 bRzbf3EFZ4rcru0xqVxIrU9svvU4Mb92mGyKnvIGDGKfVBWf59 edDGrk4ZE_he3PNDKPYJ2X55ssGCyXzSyKT3mCLDo7v2RRSaNc TJkirOiVa82xu11WAwzn5eOJgnTsMZYBqzWok3V_KeuODv49YV qurmLF0iD1iJdNDwgMA1rc9wGECoQcx3ymK1xASjHQuBVZyZOL oiaEoyFSagd5dCGG5GQ63dFwbsax5shPt5NJAV8m1kbMbmfPJM OUORcvL7itVjZXQWN6qoQ-5EoVDqLnB9ph8SYgEbiS2Rqlz3Kw6Ptn4z6GMG6UuGLHMgi6_r 71OolCZjFBGZkFhxxsNm1LQ-PHOartBB76mp2ZRIDvru4wL4BjUeex8PuRQHAHSNoWQi7T9x-YYZExbP9bJGwE9sOGuMeXyXBvXjUq1p647OWEoE-jp4ljt_4xIT0T-wp5tC6-8 JSON Validation Response: OAUTH Validattion Response: Source : FAIL OAUTH Access Token invalid
yum install wget wirkte wunder ...
das war auch das problem jetzt gehts
Edit:
Was mache ich falsch bei meiner Rolläden Ansteuerung, brauche ich da noch eine Rückmeldung das Alexa checkt dass die sich bewegen?
ich hab den percentage controller auf 1 und dann den Ausgang belegt.
nun bringt ein "Alexa Rolläden 50%" das gewünschte Ergebnis, aber Alex meldet statt "OK" -> "Rolläden reagiert leider nicht"
Edit2:
besteht die Möglichkeit irgendwie den baustein von sipiyou für den Saugroboter anzusteuern?Zuletzt geändert von HeMichael; 13.01.2020, 19:45.
Du kannst "alles" Steuern was sich per KO/iKO steuern lässt.
Einfach ein Smarthome-Device anlegen - und dann kannst du z.B. mit Power-Controller einfach den Saugrobotter ein/ausschalten.... (umsetzung des iKO von 0/1 auf die gewünschten Tätogketen musst du dann schon selbst in der Logik definieren).
Fang am besten erstmal an eine Lampe ein/aus zu schalten - oder eine Steckdose an/aus...
Thorsten
Vermutlich mag sie es nicht, wenn du sie Alex nennstZitat von HeMichael Beitrag anzeigenaber Alex meldet statt "OK" -> "Rolläden reagiert leider nicht"
Du musst auf E33 den aktuellen Status deines Rolladen verbinden?
jonofe
ne, sie mag es nur nicht wenn ich sage sie wäre dumm, da sagt se immer das ich net nett wäre
Danke das mit E33 funktioniert. Aber auf/zu kennt sie nicht, muss ich damit leben zu sagen Rolläden 100% oder 0% ?
Sorry wenn ich dich grad nerve
ThorstenGehrig ja soweit bin ich ja. das Klappt ja gut
Der Gedanke war jetz sowas wie "Alexa schicke Putzteufel in die Küche" Putzteufel würde den Roboter aktivieren und Küche müsste dann den Bereich definieren. Kann der Baustein das, oder will ich grad die Eierlegende Wollmilchsau?
Das kommt in kürze mit dem nächsten Update. Solange musst du mit den Befehlen leben, die in der Hilfe beschrieben sind.Zitat von HeMichael Beitrag anzeigenAber auf/zu kennt sie nicht, muss ich damit leben zu sagen Rolläden 100% oder 0% ?
Es sind nur vordefinierte Kommandos bei SmartHome Skills möglich.Zitat von HeMichael Beitrag anzeigen"Alexa schicke Putzteufel in die Küche" Putzteufel würde den Roboter aktivieren und Küche müsste dann den Bereich definieren. Kann der Baustein das,
Eigene Befehle lassen sich nur mit einem CustomSkill umsetzen. Da hat man dann aber das Invocation-Word, also z.B. "Alexa, starte EDOMI und schicke Putzteufel in die Küche." Den Customskill habe ich aber nicht mehr weiterentwickelt. Müsste aber eigentlich trotzdem noch funktionieren.
