Fragen und Probleme mit Edomi unter CentOS 7
    Zitat von Brick Beitrag anzeigen
    $formate[$col] > ''
    Das sieht für mich komisch aus. Ein "größer"-Vergleich mit einem leeren String. Könnte evtl. die Ursache sein.
      Hab mir mal alle Felder ausgeben lassen:
       [TABLE="border: 0, cellpadding: 0, cellspacing: 0"]
       	 		[TR]
       			[TD]2020-03-04 09:08:35[/TD]
       			[TD]387670[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Zeile: |<p align=Center>3<p>;<p align=Center>03.03.20 16:53<p>;<p align=Center>26<p>;<p align=Center>in missed<p>;<p align=Center><img src='/data/liveproject/visu/img/img-708.png' height=40><p>;<p align=Center>225233<p>;<p align=Center>undefined<p>;<p align=Center><img src='/data/liveproject/visu/img/img-701.png' height=40><p>;<p align=Center>0123456789<p>;<p align=Center>Bettina<p>;<p align=Center>0<p>;<p align=Center>undefined<p>;<p align=Center><img src='/data/liveproject/visu/img/img-701.png' height=40><p>;<p align=Center>--<p>;<p align=Center><p>[/TD]
       		[/TR]
       		[TR]
       			[TD]387696[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_ID: 2[/TD]
       		[/TR]
       		[TR]
       			[TD]387717[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Date: 03.03.20 16:22[/TD]
       		[/TR]
       		[TR]
       			[TD]387737[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Typen: 17[/TD]
       		[/TR]
       		[TR]
       			[TD]387758[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_TypeText: outgoing closed[/TD]
       		[/TR]
       		[TR]
       			[TD]387778[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Icon: <img src='/data/liveproject/visu/img/img-704.png' height=40>[/TD]
       		[/TR]
       		[TR]
       			[TD]387798[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Ownnumber: 2372324[/TD]
       		[/TR]
       		[TR]
       			[TD]387818[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Ownname: undefined[/TD]
       		[/TR]
       		[TR]
       			[TD]387839[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_OwnIcon: <img src='/data/liveproject/visu/img/img-701.png' height=40>[/TD]
       		[/TR]
       		[TR]
       			[TD]387887[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_ExtNumber: 0123456789[/TD]
       		[/TR]
       		[TR]
       			[TD]387916[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_ExtName: Bettina[/TD]
       		[/TR]
       		[TR]
       			[TD]387950[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Device: 0[/TD]
       		[/TR]
       		[TR]
       			[TD]387972[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_DeviceName: undefined[/TD]
       		[/TR]
       		[TR]
       			[TD]387993[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_DeviceIcon: <img src='/data/liveproject/visu/img/img-701.png' height=40>[/TD]
       		[/TR]
       		[TR]
       			[TD]388015[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Duration: 10[/TD]
       		[/TR]
       		[TR]
       			[TD]388037[/TD]
       			[TD]95623[/TD]
       			[TD]1[/TD]
       			[TD]Wert_Port:[/TD]
       		[/TR]
       	 [/TABLE]
      Die einzigen leeren Werte kommen bei "Port", bei allen anderen sehen die Werte plausibel aus.
      was müsste ich den an diesem $Formate ändern, das er auch leere Werte akzeptiert ?
       case 'Port':
      $wert = $row[14];
      if ($debug==1) writeToCustomLog('LBS19000454 FritzBox Anrufliste Listausgabe',1,'Wert_Port: '.$wert);
      if ((count($formate) > $col) && [COLOR=#c0392b]$formate[$col] > ''[/COLOR]) $wert = "<p align=".$formate[$col].">".$wert."<p>";
      $zeile .= ";".$wert;
      break;
      kenn mich da leider gar nicht aus.. dachte das rot dargestellte prüft auch leere Werte ?
      EDIT: die Nummern sind natürlich verfälscht.. also ruft nicht an
        so.. weiter geschaut.. es liegt an dieser Zeile:
         case 'Duration':
        [COLOR=#c0392b]$wert = ceil($row[13]/60);[/COLOR]
        wenn ich das "runden" weg lasse geht es...
        wenn ich aus ceil --> round mache geht es auch nicht.
        wenn ich ceil weg lasse und nur /60 drin lasse kommt auch ein Fehler.
        Die Fehlermeldung sagt ja folgendes:
        "A non-numeric value encountered"
        muss ich den wert hinterher evlt. in einen String umwandeln ?
          Nö, entweder $wert prüfen, ob es eine Zahl ist
          PHP-Code:
          if(is_numeric($wert)) {$wert = ceil($row[13]/60);}
          Oder mal prüfen, warum $Wert keine Zahl ist. Vielleicht ein Komma anstatt einem Punkt als Trenner
            Micha meint natürlich $row[13]
            Welche Werte kann Wert_Duration denn annehmen?
            Marcel
              Wenn ich jetzt das vom Micha eintrage kommt nichts mehr im Log raus.. scheint also kein "nummeric" zu sein...
              Komm jetzt nur leider gerade nicht mehr zum weiter testen..
              Lonie .. das ist die Gesprächsdauer in Sekunden.
                Ähm ja Danke!
                  Brick Er teilt nicht mehr durch 60 weil $wert noch vom verherigen Durchlauf den Wert von DeviceIcon hat. Deswegen kommt keine Meldung.
                  Marcel
                    Hab jetzt mal ein $wert = 0; vor die Zeile gesetzt, das half nicht.. (wollte den Wert damit auf "0" bringen)
                    EDIT: wo kommen den jetzt die Balken unter meinem Avatar her... ich sorg offensichtlich für eine "eindrucksvolle Atmosphäre"..
                    na immerhin !!
                      Ich hatte folgende Lösung eingebaut:
                      case 'Duration':
                      $wert = ceil((int)$row[13]/60);
                      Liegt an der restriktiveren Typkonvertierung in PHP7.
                      Leider hatte ich das in der Download-Version wohl noch nicht drin, hol's gleich nach.
                      Winni
                      Zuletzt geändert von Winni; 06.03.2020, 10:32.
                        genau das wär mein nächster Versuch gewesen.. wobei ich "intval" gegoogelt hätte..
                        Vielen Dank !!
                        Probier ich gleich aus
                        Gruß Martin
                        EDIT: Jup.. jetzt gehts.. Vielen Dank !!
                        Zuletzt geändert von Brick; 06.03.2020, 10:27.
                          Bei der Umstellung auf einen funktionierendes System mit Futro 920 und CentOS 7 mit Edomi 2.0 zeigt sich einzig die Visu auf einem iPAD (2?) instabil:
                          Drücken einer "Taste" und dann dauert es >1 Sekunde bis sich ein Pop-Up oder Seite öffnet.
                          Das "Live"-Bild (Einstellung: Update alle 2Sek.) der Überwachungskamera hängt sich sporadisch auf.
                          Ipad meldet mehrmals am Tag "Server nicht erreichbar": Visu muss dann neu gestartet werden.
                          Ich habe irgendwo im Forum mal gelesen, wie man die Visu "beschleunigen" kann. Den Beitrag finde ich allerdings nicht mehr, war aber auch nicht auf CentOS7 bezogen (glaube ich).
                          Beobachtet das noch jemand, woran kann das liegen?
                          Danke und Grüße,
                          Lio
                            mein Installationsversuche mit CentOS 7.6 und Edomi2.01 mit einer festen IP-Adresse sind immer wieder bei einer dynamischen IP gelandet. Auch das spätere Umstellen von
                            - /usr/local/edomi/edomi.ini
                            - /etc/sysconfig/network-scripts/ifcfg-eth0 d.h. ifcfg-enp3s0
                            - /etc/resolv.conf und
                            - /etc/httpd/conf/httpd.conf
                            auf eine feste IP-adresse brachte nicht den erwarteten Erfolg. Edomi lief nicht mehr, den Server konnte man noch über die dynamische IP erreichen. Offenbar müssen noch an anderer Stelle entsprechende Schritte geändert werden.
                            Hat da jemand einen Tipp?
                              Was hast du den wo eingestellt ?
                              normal reich glaub ich die ifcfg-ethx Datei..
                              DHCP ausgeschaltet bzw. auf manuell ?
                                Bei der Installation habe ich hier an der im Anhang beschriebenen Stelle die feste IP eingestellt.
                                HInterher habe ich immer wieder festgestellt, dass dennoch eine dynamische IP vergeben wurde. NUr in einer der oben beschriebenen Dateien hatte die feste IP beinhaltet (welche weiß ich i.M. leider nicht mehr) Die oben beschriebenen Änderungen stammen übrigens aus der Installationsanleitung für CentOS6.5.
