Zitat von Brick
Hab mir mal alle Felder ausgeben lassen:
Die einzigen leeren Werte kommen bei "Port", bei allen anderen sehen die Werte plausibel aus.Code:[TABLE="border: 0, cellpadding: 0, cellspacing: 0"] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387670[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Zeile: |<p align=Center>3<p>;<p align=Center>03.03.20 16:53<p>;<p align=Center>26<p>;<p align=Center>in missed<p>;<p align=Center><img src='/data/liveproject/visu/img/img-708.png' height=40><p>;<p align=Center>225233<p>;<p align=Center>undefined<p>;<p align=Center><img src='/data/liveproject/visu/img/img-701.png' height=40><p>;<p align=Center>0123456789<p>;<p align=Center>Bettina<p>;<p align=Center>0<p>;<p align=Center>undefined<p>;<p align=Center><img src='/data/liveproject/visu/img/img-701.png' height=40><p>;<p align=Center>--<p>;<p align=Center><p>[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387696[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_ID: 2[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387717[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Date: 03.03.20 16:22[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387737[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Typen: 17[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387758[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_TypeText: outgoing closed[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387778[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Icon: <img src='/data/liveproject/visu/img/img-704.png' height=40>[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387798[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Ownnumber: 2372324[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387818[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Ownname: undefined[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387839[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_OwnIcon: <img src='/data/liveproject/visu/img/img-701.png' height=40>[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387887[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_ExtNumber: 0123456789[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387916[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_ExtName: Bettina[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387950[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Device: 0[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387972[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_DeviceName: undefined[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]387993[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_DeviceIcon: <img src='/data/liveproject/visu/img/img-701.png' height=40>[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]388015[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Duration: 10[/TD] [/TR] [TR] [TD]2020-03-04 09:08:35[/TD] [TD]388037[/TD] [TD]95623[/TD] [TD]1[/TD] [TD]Wert_Port:[/TD] [/TR] [/TABLE]
was müsste ich den an diesem $Formate ändern, das er auch leere Werte akzeptiert ?
kenn mich da leider gar nicht aus.. dachte das rot dargestellte prüft auch leere Werte ?Code:case 'Port': $wert = $row[14]; if ($debug==1) writeToCustomLog('LBS19000454 FritzBox Anrufliste Listausgabe',1,'Wert_Port: '.$wert); if ((count($formate) > $col) && [COLOR=#c0392b]$formate[$col] > ''[/COLOR]) $wert = "<p align=".$formate[$col].">".$wert."<p>"; $zeile .= ";".$wert; break;
EDIT: die Nummern sind natürlich verfälscht.. also ruft nicht an
so.. weiter geschaut.. es liegt an dieser Zeile:
wenn ich das "runden" weg lasse geht es...Code:case 'Duration': [COLOR=#c0392b]$wert = ceil($row[13]/60);[/COLOR]
wenn ich aus ceil --> round mache geht es auch nicht.
wenn ich ceil weg lasse und nur /60 drin lasse kommt auch ein Fehler.
Die Fehlermeldung sagt ja folgendes:
"A non-numeric value encountered"
muss ich den wert hinterher evlt. in einen String umwandeln ?
Wenn ich jetzt das vom Micha eintrage kommt nichts mehr im Log raus.. scheint also kein "nummeric" zu sein...
Komm jetzt nur leider gerade nicht mehr zum weiter testen..
Lonie .. das ist die Gesprächsdauer in Sekunden.
Hab jetzt mal ein $wert = 0; vor die Zeile gesetzt, das half nicht.. (wollte den Wert damit auf "0" bringen)
EDIT: wo kommen den jetzt die Balken unter meinem Avatar her... ich sorg offensichtlich für eine "eindrucksvolle Atmosphäre"..
na immerhin !!
genau das wär mein nächster Versuch gewesen.. wobei ich "intval" gegoogelt hätte..
Vielen Dank !!
Probier ich gleich aus
Gruß Martin
EDIT: Jup.. jetzt gehts.. Vielen Dank !!Zuletzt geändert von Brick; 06.03.2020, 10:27.Die Selbsthilfegruppe "UTF-8-Probleme" trifft sich diesmal abweichend im groüen Saal.
Bei der Umstellung auf einen funktionierendes System mit Futro 920 und CentOS 7 mit Edomi 2.0 zeigt sich einzig die Visu auf einem iPAD (2?) instabil:
Drücken einer "Taste" und dann dauert es >1 Sekunde bis sich ein Pop-Up oder Seite öffnet.
Das "Live"-Bild (Einstellung: Update alle 2Sek.) der Überwachungskamera hängt sich sporadisch auf.
Ipad meldet mehrmals am Tag "Server nicht erreichbar": Visu muss dann neu gestartet werden.
Ich habe irgendwo im Forum mal gelesen, wie man die Visu "beschleunigen" kann. Den Beitrag finde ich allerdings nicht mehr, war aber auch nicht auf CentOS7 bezogen (glaube ich).
Beobachtet das noch jemand, woran kann das liegen?
Danke und Grüße,
Lio
mein Installationsversuche mit CentOS 7.6 und Edomi2.01 mit einer festen IP-Adresse sind immer wieder bei einer dynamischen IP gelandet. Auch das spätere Umstellen von
- /usr/local/edomi/edomi.ini
- /etc/sysconfig/network-scripts/ifcfg-eth0 d.h. ifcfg-enp3s0
- /etc/resolv.conf und
- /etc/httpd/conf/httpd.conf
auf eine feste IP-adresse brachte nicht den erwarteten Erfolg. Edomi lief nicht mehr, den Server konnte man noch über die dynamische IP erreichen. Offenbar müssen noch an anderer Stelle entsprechende Schritte geändert werden.
Hat da jemand einen Tipp?
Bei der Installation habe ich hier an der im Anhang beschriebenen Stelle die feste IP eingestellt.
HInterher habe ich immer wieder festgestellt, dass dennoch eine dynamische IP vergeben wurde. NUr in einer der oben beschriebenen Dateien hatte die feste IP beinhaltet (welche weiß ich i.M. leider nicht mehr) Die oben beschriebenen Änderungen stammen übrigens aus der Installationsanleitung für CentOS6.5.Angehängte Dateien
