Hallo meisterschaf,
Super Vielen Dank! hat funktioniert.
{EDOMI,CUSTOMLOG_LBS_XIAOMI_19001929_0.log,28.09.2024,15:37:36,654112,1904}{Zeitstempel,ms,PID,LogLevel,Meldung}
2024-09-28 15:37:36 653620 1904 Debug Cloud-Daten aus Cache verwenden. Kein Login!
2024-09-28 15:37:36 654835 1904 Debug V3=[hier-stand-die-Ausgabe-von-A10]
2024-09-28 15:37:36 655122 1904 Debug cloud->isAccessible:Y-E10=-E11=
2024-09-28 15:37:36 655333 1904 Debug RoborockMe:: ip = [IP-vom-Roborock]; token = [hier-stand-ein-token]; SequenceID: 0
2024-09-28 15:37:41 257503 15499 Info Exec ist bereits aktiv. Aufruf Intervall prüfen
2024-09-28 15:37:56 671641 1904 Debug roborocMe:: ok
2024-09-28 15:37:56 672095 1904 Info Roboter reagiert nicht.
2024-09-28 15:37:56 677620 1904 Debug Ausführungszeit: 20.028375148773 [s]
[root@1e3e0a9939d3 /]# ping 10.0.23.203 PING 10.0.23.203 (10.0.23.203) 56(84) bytes of data. 64 bytes from 10.0.23.203: icmp_seq=1 ttl=253 time=0.677 ms 64 bytes from 10.0.23.203: icmp_seq=2 ttl=253 time=0.539 ms 64 bytes from 10.0.23.203: icmp_seq=3 ttl=253 time=0.697 ms
[root@1e3e0a9939d3 /]# curl 10.0.23.203
<html>
<head>
<script type="text/javascript" src="js/utility.js">
</script>
<script type="text/javascript" src="js/storage.js">
</script>
<script type="text/javascript" src="js/bigint.js">
</script>
<script type="text/javascript" src="js/encrypt.js">
</script>
<script type="text/javascript" src="js/ajax.js">
</script>
<script type="text/javascript" src="js/login.js">
</script>
<script type="text/javascript" src="js/pagecommon.js">
</script>
<script type="text/javascript" language="javascript">
function Initialize() {
//update communication channel encrypt flag:
var sEncryptFlag = document.body.getAttribute("comm_channel_encrypt_flag");
var iEncryptFlag = parseInt(sEncryptFlag);
if (isNaN(iEncryptFlag))
iEncryptFlag = 0;
LocalStorage.Instance().Set("logo_comm_channel_encrypt_flag", iEncryptFlag);
//local storage test:
var sResultValue;
var sTestKey = "local_storage_test";
var sTestValue = sTestKey + "_value";
try {
LocalStorage.Instance().Set(sTestKey, sTestValue);
sResultValue = LocalStorage.Instance().Get(sTestKey);
catch (e) {
//do nothing.
if (sResultValue != sTestValue) {
var sErrorInfo = document.body.getAttribute("local_storage_test_fail");
if (sErrorInfo)
alert(sErrorInfo)
else
alert("local storage is disabled, please enable it.");
var bAutoLoginSuccessfully = false;
if (LocalStorage.Instance().Get("logo_current_autologin")) {
//auto login:
var sPublicKey1 = document.body.getAttribute("logo_public_key1");
var sPublicKey2 = document.body.getAttribute("logo_public_key2");
var sPassword = LocalStorage.Instance().Get("logo_current_password");
//if(sPublicKey1 && sPublicKey2)
LocalLogin(sPublicKey1, sPublicKey2, sPassword, true, LocalStorage.Instance().Get("logo_current_logto_customized_site"));
bAutoLoginSuccessfully = true;
if (!bAutoLoginSuccessfully) {
//try to navigate to real start page:
var iCurLanguage = LocalStorage.Instance().Get("logo_current_language");
if (typeof iCurLanguage == "undefined" || iCurLanguage == null)
iCurLanguage = 1;
window.location.replace("/logo_login.shtm?!App-Language=" + iCurLanguage);
</script>
</head>
<body onload="Initialize();" comm_channel_encrypt_flag="0" logo_ms_state="0"
local_storage_test_fail="Local storage is disabled. Please enable it.">
</body>
</html>
