Zitat von jeff25
knxd -t 1023 -B log -f9 -e 1.1.1 -E 1.1.1:128 -TDRS -B log -b ft12cemi:/dev/ttyAMA0
root@raspberrypi:~# knxd -t 1023 -B log -f9 -e 1.1.1 -E 1.1.2:1 -TDRS -B log -B single -b ft12cemi:/dev/ttyAMA0 Layer 4 [ 1:main 0.000] R state: initialized I00000000: 0.14.1: knxd -t 1023 -B log -f9 -e 1.1.1 -E 1.1.2:1 -TDRS -B log -B single -b ft12cemi:/dev/ttyAMA0 [ 1:main] Layer 4 [ 1:main 0.000] R state: setting up Layer 0 [ 4:log/main 0.000] State setup Layer 3 [ 5:server/Server 0.000] registerLink: server Layer 0 [12:log/A.ft12cemi 0.001] State setup Layer 2 [15:A.ft12cemi/ft12cemi 0.001] Delay is 0.300000 Layer 2 [15:A.ft12cemi/ft12cemi 0.001] Delay is 0.300000 Layer 3 [10:A.ft12cemi/Conn 0.001] registerLink: A.ft12cemi I00000055: Connected: LinkBase: cfg:A.ft12cemi. I00000055: Connected: LinkBase: cfg:server. [ 1:main] [ 1:main] Layer 4 [ 1:main 0.001] R state: setup OK W00000000: Consider using a config file. W00000020: knxd should not run as root [ 1:main] [ 1:main] Layer 4 [ 1:main 0.001] R state: trigger going up Layer 0 [ 4:log/main 0.001] State start Layer 3 [10:A.ft12cemi/Conn 0.001] Start: LinkBase: cfg:A.ft12cemi Layer 5 [10:A.ft12cemi/Conn 0.001] Starting Layer 0 [12:log/A.ft12cemi 0.001] State start Layer 1 [14:A.ft12cemi/ft12ser 0.001] Open Layer 1 [14:A.ft12cemi/ft12ser 0.002] Opened Layer 0 [12:log/A.ft12cemi 0.002] send next Layer 6 [ 1:main 0.002] SN: OK Layer 0 [ 4:log/main 0.002] send next Layer 6 [ 2:main/L 0.002] SN: OK L Layer 0 [12:log/A.ft12cemi 0.002] State started Layer 5 [10:A.ft12cemi/Conn 0.002] Started Layer 4 [10:A.ft12cemi/Conn 0.002] R state: started Layer 6 [ 1:main 0.002] SN: send_more set Layer 3 [ 5:server/Server 0.002] Start: LinkBase: cfg:server Layer 8 [ 5:server/Server 0.002] Open Layer 0 [ 5:server/Server 0.002] Open Layer 0 [ 5:server/Server 0.002] Openend Layer 8 [17:router/driver 0.002] OpenD Layer 8 [17:router/driver 0.003] OpenedD Layer 3 [16:router/ConnC 0.003] registerLink: router_16 Layer 3 [16:router/ConnC 0.003] Start: LinkBase: cfg:router Layer 5 [16:router/ConnC 0.003] Starting Layer 5 [16:router/ConnC 0.003] Started Layer 4 [16:router/ConnC 0.003] R state: started Layer 6 [ 1:main 0.003] SN: send_more set Layer 8 [ 5:server/Server 0.003] Opened Layer 5 [ 5:server/Server 0.003] Started Layer 4 [ 5:server/Server 0.003] R state: started Layer 6 [ 1:main 0.003] SN: send_more set Layer 4 [ 1:main 0.003] R state: going up triggered Layer 0 [ 4:log/main 0.003] State started Layer 4 [ 1:main 0.003] R state: all drivers up Layer 4 [ 1:main 0.003] R state: up Layer 0 [ 5:server/Server 34.490] Recv(016): 06 10 05 30 00 10 29 00 B0 60 11 01 11 14 00 80 Layer 0 [ 4:log/main 34.490] Recv L_Data system from 1.1.1 to 1.1.20 hops: 06 T_CONNECT_REQ Layer 0 [ 4:log/main 34.491] Send L_Data system from 1.1.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 0 [12:log/A.ft12cemi 34.491] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 34.491] Has Addr 1.1.20: no Layer 1 [ 5:server/Server 34.491] Send(010): 29 00 B0 50 11 01 11 14 00 80 Layer 0 [12:log/A.ft12cemi 34.491] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 34.491] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 34.491] Send L_Data system from 1.1.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 5 [13:single/A.ft12cemi 34.491] from 1.1.1 to 1.1.20 Layer 6 [ 1:main 34.492] SN: OK Layer 0 [ 4:log/main 34.492] send next Layer 6 [ 2:main/L 34.492] SN: OK L Layer 0 [ 5:server/Server 34.492] Send(016): 06 10 05 30 00 10 29 00 B0 50 11 01 11 14 00 80 Layer 0 [ 5:server/Server 34.492] Dropped(016): 06 10 05 30 00 10 29 00 B0 50 11 01 11 14 00 80 Layer 0 [ 5:server/Server 34.495] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 34.495] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 34.495] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 34.495] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 34.496] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 34.496] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 34.496] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 34.496] SN: OK Layer 0 [ 4:log/main 34.496] send next Layer 6 [ 2:main/L 34.496] SN: OK L Layer 0 [ 5:server/Server 34.496] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 34.496] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 34.514] Recv(017): 06 10 05 30 00 11 29 00 B0 60 11 01 11 14 01 43 00 Layer 0 [ 4:log/main 34.514] Recv L_Data system from 1.1.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 34.514] Send L_Data system from 1.1.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 34.514] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 34.514] Has Addr 1.1.20: no Layer 1 [ 5:server/Server 34.514] Send(011): 29 00 B0 50 11 01 11 14 01 43 00 Layer 0 [12:log/A.ft12cemi 34.515] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 34.515] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 34.515] Send L_Data system from 1.1.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 6 [ 1:main 34.515] SN: OK Layer 0 [ 4:log/main 34.515] send next Layer 6 [ 2:main/L 34.515] SN: OK L Layer 0 [ 5:server/Server 34.515] Send(017): 06 10 05 30 00 11 29 00 B0 50 11 01 11 14 01 43 00 Layer 0 [ 5:server/Server 34.515] Dropped(017): 06 10 05 30 00 11 29 00 B0 50 11 01 11 14 01 43 00 Layer 0 [ 5:server/Server 37.604] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 37.605] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 37.605] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 37.606] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 37.606] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 37.606] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 37.607] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 37.607] SN: OK Layer 0 [ 4:log/main 37.607] send next Layer 6 [ 2:main/L 37.607] SN: OK L Layer 0 [ 5:server/Server 37.608] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 37.608] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 40.525] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 40.525] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 40.526] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 40.526] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 40.526] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 40.527] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 40.527] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 40.527] SN: OK Layer 0 [ 4:log/main 40.528] send next Layer 6 [ 2:main/L 40.528] SN: OK L Layer 0 [ 5:server/Server 40.528] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 40.529] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 43.529] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 43.529] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 43.530] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 43.530] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 43.531] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 43.531] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 43.531] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 43.532] SN: OK Layer 0 [ 4:log/main 43.532] send next Layer 6 [ 2:main/L 43.532] SN: OK L Layer 0 [ 5:server/Server 43.532] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 43.533] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 46.531] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 46.532] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 46.533] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 46.533] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 46.533] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 46.534] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 46.534] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 46.534] SN: OK Layer 0 [ 4:log/main 46.534] send next Layer 6 [ 2:main/L 46.535] SN: OK L Layer 0 [ 5:server/Server 46.535] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 46.536] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 49.543] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 49.543] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 49.544] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 49.544] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 49.545] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 49.545] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 49.545] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 49.546] SN: OK Layer 0 [ 4:log/main 49.546] send next Layer 6 [ 2:main/L 49.546] SN: OK L Layer 0 [ 5:server/Server 49.546] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 49.547] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 52.618] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 52.618] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 52.619] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 52.619] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 52.620] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 52.620] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 52.620] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 52.620] SN: OK Layer 0 [ 4:log/main 52.621] send next Layer 6 [ 2:main/L 52.621] SN: OK L Layer 0 [ 5:server/Server 52.621] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 52.622] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 55.556] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 55.557] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 55.557] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 55.557] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 55.557] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 55.557] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 55.557] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 55.557] SN: OK Layer 0 [ 4:log/main 55.558] send next Layer 6 [ 2:main/L 55.558] SN: OK L Layer 0 [ 5:server/Server 55.558] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 55.558] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 58.559] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 58.559] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 58.560] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 58.560] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 58.560] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 58.561] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 58.561] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 58.561] SN: OK Layer 0 [ 4:log/main 58.561] send next Layer 6 [ 2:main/L 58.561] SN: OK L Layer 0 [ 5:server/Server 58.561] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 58.562] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 61.560] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 61.560] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 61.560] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 61.560] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 61.561] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 61.561] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 61.561] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 61.561] SN: OK Layer 0 [ 4:log/main 61.561] send next Layer 6 [ 2:main/L 61.561] SN: OK L Layer 0 [ 5:server/Server 61.561] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 61.562] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 64.564] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 64.564] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 64.565] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 64.565] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 64.565] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 64.565] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 64.565] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 64.565] SN: OK Layer 0 [ 4:log/main 64.566] send next Layer 6 [ 2:main/L 64.566] SN: OK L Layer 0 [ 5:server/Server 64.566] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 64.566] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 67.641] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 67.641] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 67.641] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 67.641] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 67.642] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 67.642] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 67.642] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 67.642] SN: OK Layer 0 [ 4:log/main 67.642] send next Layer 6 [ 2:main/L 67.642] SN: OK L Layer 0 [ 5:server/Server 67.642] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 67.643] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 70.570] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 70.571] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 70.571] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 70.571] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 70.572] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 70.572] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 70.572] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 70.572] SN: OK Layer 0 [ 4:log/main 70.572] send next Layer 6 [ 2:main/L 70.572] SN: OK L Layer 0 [ 5:server/Server 70.572] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 70.573] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 73.576] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 11 01 00 00 01 01 00 Layer 0 [ 4:log/main 73.577] Recv L_Data system from 1.1.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 73.577] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [ 5:server/Server 73.577] Send(011): 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [12:log/A.ft12cemi 73.577] Has Addr 1.1.1: no Layer 0 [12:log/A.ft12cemi 73.577] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 73.577] Send L_Data system from 1.1.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 6 [ 1:main 73.578] SN: OK Layer 0 [ 4:log/main 73.578] send next Layer 6 [ 2:main/L 73.578] SN: OK L Layer 0 [ 5:server/Server 73.578] Send(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00 Layer 0 [ 5:server/Server 73.579] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 01 00 00 01 01 00
I00000000: 0.14.1: knxd -t 1023 -B log -f9 -e 1.1.1 -E 1.1.1:250 -TDRS -B log -b ft12cemi:/dev/ttyAMA0 [ 1:main] Layer 4 [ 1:main 0.000] R state: setting up Layer 0 [ 4:log/main 0.000] State setup Layer 3 [ 5:server/Server 0.000] registerLink: server Layer 0 [12:log/A.ft12cemi 0.001] State setup Layer 2 [14:A.ft12cemi/ft12cemi 0.001] Delay is 0.300000 Layer 2 [14:A.ft12cemi/ft12cemi 0.001] Delay is 0.300000 Layer 3 [10:A.ft12cemi/Conn 0.001] registerLink: A.ft12cemi I00000055: Connected: LinkBase: cfg:A.ft12cemi. I00000055: Connected: LinkBase: cfg:server. [ 1:main] [ 1:main] Layer 4 [ 1:main 0.001] R state: setup OK W00000000: Consider using a config file. W00000020: knxd should not run as root [ 1:main] [ 1:main] Layer 4 [ 1:main 0.001] R state: trigger going up Layer 0 [ 4:log/main 0.001] State start Layer 3 [10:A.ft12cemi/Conn 0.001] Start: LinkBase: cfg:A.ft12cemi Layer 5 [10:A.ft12cemi/Conn 0.001] Starting Layer 0 [12:log/A.ft12cemi 0.001] State start Layer 1 [13:A.ft12cemi/ft12ser 0.001] Open Layer 1 [13:A.ft12cemi/ft12ser 0.001] Opened Layer 0 [12:log/A.ft12cemi 0.001] send next Layer 6 [ 1:main 0.001] SN: OK Layer 0 [ 4:log/main 0.001] send next Layer 6 [ 2:main/L 0.001] SN: OK L Layer 0 [12:log/A.ft12cemi 0.001] State started Layer 5 [10:A.ft12cemi/Conn 0.002] Started Layer 4 [10:A.ft12cemi/Conn 0.002] R state: started Layer 6 [ 1:main 0.002] SN: send_more set Layer 3 [ 5:server/Server 0.002] Start: LinkBase: cfg:server Layer 8 [ 5:server/Server 0.002] Open Layer 0 [ 5:server/Server 0.002] Open Layer 0 [ 5:server/Server 0.002] Openend Layer 8 [16:router/driver 0.002] OpenD Layer 8 [16:router/driver 0.002] OpenedD Layer 3 [15:router/ConnC 0.002] registerLink: router_15 Layer 3 [15:router/ConnC 0.002] Start: LinkBase: cfg:router Layer 5 [15:router/ConnC 0.002] Starting Layer 5 [15:router/ConnC 0.003] Started Layer 4 [15:router/ConnC 0.003] R state: started Layer 6 [ 1:main 0.003] SN: send_more set Layer 8 [ 5:server/Server 0.003] Opened Layer 5 [ 5:server/Server 0.003] Started Layer 4 [ 5:server/Server 0.003] R state: started Layer 6 [ 1:main 0.003] SN: send_more set Layer 4 [ 1:main 0.003] R state: going up triggered Layer 0 [ 4:log/main 0.003] State started Layer 4 [ 1:main 0.003] R state: all drivers up Layer 4 [ 1:main 0.003] R state: up Layer 0 [ 5:server/Server 17.547] Recv(016): 06 10 05 30 00 10 29 00 B0 60 00 01 11 14 00 80 Layer 0 [12:log/A.ft12cemi 17.547] Has Addr 0.0.1: no Layer 8 [ 1:main 17.547] unknown addr 0.0.1 Layer 0 [ 4:log/main 17.547] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_CONNECT_REQ Layer 0 [ 4:log/main 17.547] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 0 [12:log/A.ft12cemi 17.548] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 17.548] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 17.548] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 17.548] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 17.548] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 1 [13:A.ft12cemi/ft12ser 17.548] Send(010): 11 00 B0 50 00 01 11 14 00 80 Layer 6 [ 1:main 17.548] SN: OK Layer 0 [ 4:log/main 17.548] send next Layer 6 [ 2:main/L 17.548] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 17.548] Send(017): 68 0B 0B 68 73 11 00 B0 50 00 01 11 14 00 80 2A 16 Layer 0 [13:A.ft12cemi/ft12ser 17.560] Read(001): E5 Layer 0 [12:log/A.ft12cemi 17.560] send next Layer 6 [ 1:main 17.560] SN: send_more set Layer 0 [ 5:server/Server 17.566] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 17.566] found addr 0.0.1 Layer 0 [ 4:log/main 17.566] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 17.567] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 17.567] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 17.567] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 17.567] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 17.567] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 17.567] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000000: EMI_common: send while waiting [14:A.ft12cemi] Layer 1 [13:A.ft12cemi/ft12ser 17.567] Send(011): 11 00 B0 50 00 01 11 14 01 43 00 Layer 6 [ 1:main 17.567] SN: OK Layer 0 [ 4:log/main 17.567] send next Layer 6 [ 2:main/L 17.567] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 17.567] Send(018): 68 0C 0C 68 53 11 00 B0 50 00 01 11 14 01 43 00 CE 16 Layer 0 [13:A.ft12cemi/ft12ser 17.580] Read(001): E5 Layer 0 [12:log/A.ft12cemi 17.580] send next Layer 6 [ 1:main 17.580] SN: send_more set Layer 0 [ 5:server/Server 17.588] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 00 01 00 00 01 01 00 Layer 8 [15:router/ConnC 17.588] found addr 0.0.1 Layer 0 [ 4:log/main 17.588] Recv L_Data system from 0.0.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 17.588] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [12:log/A.ft12cemi 17.588] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 17.588] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 17.588] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read E00000000: EMI_common: send while waiting [14:A.ft12cemi] Layer 1 [13:A.ft12cemi/ft12ser 17.588] Send(011): 11 00 B0 D0 00 01 00 00 01 01 00 Layer 6 [ 1:main 17.588] SN: OK Layer 0 [ 4:log/main 17.588] send next Layer 6 [ 2:main/L 17.589] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 17.589] Send(018): 68 0C 0C 68 73 11 00 B0 D0 00 01 00 00 01 01 00 07 16 Layer 0 [13:A.ft12cemi/ft12ser 17.601] Read(001): E5 Layer 0 [12:log/A.ft12cemi 17.601] send next Layer 6 [ 1:main 17.601] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 17.622] Read(008): 68 0C 0C 68 F3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 17.627] Read(008): 50 00 01 11 14 01 43 00 Layer 0 [13:A.ft12cemi/ft12ser 17.630] Read(002): 8B 16 Layer 0 [13:A.ft12cemi/ft12ser 17.630] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 17.630] unknown data(011): 2E 00 B0 50 00 01 11 14 01 43 00 Layer 0 [13:A.ft12cemi/ft12ser 17.652] Read(008): 68 0C 0C 68 D3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 17.657] Read(008): D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 17.660] Read(002): 84 16 Layer 0 [13:A.ft12cemi/ft12ser 17.660] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 17.660] unknown data(011): 2E 00 B0 D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 17.671] Read(008): 68 0C 0C 68 F3 29 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 17.676] Read(008): E0 11 14 00 00 01 01 40 Layer 0 [13:A.ft12cemi/ft12ser 17.679] Read(002): 13 16 Layer 0 [13:A.ft12cemi/ft12ser 17.679] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 17.679] unknown data(011): 29 00 B0 E0 11 14 00 00 01 01 40 Layer 1 [14:A.ft12cemi/ft12cemi 17.888] No confirm, continuing Layer 0 [12:log/A.ft12cemi 17.888] send next Layer 6 [ 1:main 17.888] SN: send_more set Layer 0 [ 5:server/Server 20.565] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 00 01 00 00 01 01 00 Layer 8 [15:router/ConnC 20.566] found addr 0.0.1 Layer 0 [ 4:log/main 20.566] Recv L_Data system from 0.0.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 20.566] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [12:log/A.ft12cemi 20.566] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 20.566] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 20.566] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [13:A.ft12cemi/ft12ser 20.566] Send(011): 11 00 B0 D0 00 01 00 00 01 01 00 Layer 6 [ 1:main 20.566] SN: OK Layer 0 [ 4:log/main 20.566] send next Layer 6 [ 2:main/L 20.566] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 20.566] Send(018): 68 0C 0C 68 53 11 00 B0 D0 00 01 00 00 01 01 00 E7 16 Layer 0 [13:A.ft12cemi/ft12ser 20.579] Read(001): E5 Layer 0 [12:log/A.ft12cemi 20.579] send next Layer 6 [ 1:main 20.579] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 20.622] Read(008): 68 0C 0C 68 D3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 20.627] Read(008): D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 20.629] Read(002): 84 16 Layer 0 [13:A.ft12cemi/ft12ser 20.629] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 20.630] unknown data(011): 2E 00 B0 D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 20.642] Read(008): 68 0C 0C 68 F3 29 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 20.647] Read(008): E0 11 14 00 00 01 01 40 Layer 0 [13:A.ft12cemi/ft12ser 20.649] Read(002): 13 16 Layer 0 [13:A.ft12cemi/ft12ser 20.649] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 20.650] unknown data(011): 29 00 B0 E0 11 14 00 00 01 01 40 Layer 1 [14:A.ft12cemi/ft12cemi 20.866] No confirm, continuing Layer 0 [12:log/A.ft12cemi 20.866] send next Layer 6 [ 1:main 20.866] SN: send_more set Layer 0 [ 5:server/Server 23.567] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 00 01 00 00 01 01 00 Layer 8 [15:router/ConnC 23.567] found addr 0.0.1 Layer 0 [ 4:log/main 23.567] Recv L_Data system from 0.0.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 23.567] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [12:log/A.ft12cemi 23.568] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 23.568] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 23.568] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [13:A.ft12cemi/ft12ser 23.568] Send(011): 11 00 B0 D0 00 01 00 00 01 01 00 Layer 6 [ 1:main 23.568] SN: OK Layer 0 [ 4:log/main 23.568] send next Layer 6 [ 2:main/L 23.568] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 23.568] Send(018): 68 0C 0C 68 73 11 00 B0 D0 00 01 00 00 01 01 00 07 16 Layer 0 [13:A.ft12cemi/ft12ser 23.581] Read(001): E5 Layer 0 [12:log/A.ft12cemi 23.581] send next Layer 6 [ 1:main 23.581] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 23.622] Read(008): 68 0C 0C 68 D3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 23.626] Read(008): D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 23.629] Read(002): 84 16 Layer 0 [13:A.ft12cemi/ft12ser 23.629] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 23.629] unknown data(011): 2E 00 B0 D0 00 01 00 00 01 01 00 Layer 0 [13:A.ft12cemi/ft12ser 23.647] Read(008): 68 0C 0C 68 F3 29 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 23.651] Read(008): E0 11 14 00 00 01 01 40 Layer 0 [13:A.ft12cemi/ft12ser 23.654] Read(002): 13 16 Layer 0 [13:A.ft12cemi/ft12ser 23.654] Send Ack(001): E5 Layer 0 [11:A.ft12cemi/LowA 23.654] unknown data(011): 29 00 B0 E0 11 14 00 00 01 01 40 Layer 1 [14:A.ft12cemi/ft12cemi 23.868] No confirm, continuing Layer 0 [12:log/A.ft12cemi 23.868] send next Layer 6 [ 1:main 23.868] SN: send_more set Layer 0 [ 5:server/Server 26.573] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 00 01 00 00 01 01 00 Layer 8 [15:router/ConnC 26.573] found addr 0.0.1 Layer 0 [ 4:log/main 26.573] Recv L_Data system from 0.0.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 26.573] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [12:log/A.ft12cemi 26.573] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 26.573] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 26.573] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 1 [13:A.ft12cemi/ft12ser 26.573] Send(011): 11 00 B0 D0 00 01 00 00 01 01 00 Layer 6 [ 1:main 26.573] SN: OK Layer 0 [ 4:log/main 26.573] send next Layer 6 [ 2:main/L 26.573] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 26.573] Send(018): 68 0C 0C 68 53 11 00 B0 D0 00 01 00 00 01 01 00 E7 16 Layer 1 [14:A.ft12cemi/ft12cemi 26.873] No confirm, continuing Layer 0 [12:log/A.ft12cemi 26.873] send next Layer 6 [ 1:main 26.874] SN: send_more set Layer 0 [ 5:server/Server 29.775] Recv(017): 06 10 05 30 00 11 29 00 B0 E0 00 01 00 00 01 01 00 Layer 8 [15:router/ConnC 29.776] found addr 0.0.1 Layer 0 [ 4:log/main 29.776] Recv L_Data system from 0.0.1 to 0/0/0 hops: 06 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [ 4:log/main 29.776] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read Layer 0 [12:log/A.ft12cemi 29.777] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 29.777] Addr Check 0/0/0: yes Layer 0 [12:log/A.ft12cemi 29.777] Send L_Data system from 0.0.1 to 0/0/0 hops: 05 T_DATA_XXX_REQ A_IndividualAddress_Read E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 29.778] SN: OK Layer 0 [ 4:log/main 29.778] send next Layer 6 [ 2:main/L 29.778] SN: OK L Layer 0 [ 5:server/Server 29.856] Dropped(017): 06 10 05 30 00 11 29 00 B0 D0 11 14 00 00 01 01 40 Layer 1 [14:A.ft12cemi/ft12cemi 30.077] No confirm, continuing Layer 0 [12:log/A.ft12cemi 30.077] send next Layer 6 [ 1:main 30.077] SN: send_more set Layer 0 [ 5:server/Server 32.578] Recv(016): 06 10 05 30 00 10 29 00 B0 60 00 01 11 14 00 80 Layer 8 [15:router/ConnC 32.579] found addr 0.0.1 Layer 0 [ 4:log/main 32.579] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_CONNECT_REQ Layer 0 [ 4:log/main 32.580] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 0 [12:log/A.ft12cemi 32.580] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 32.580] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 32.580] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 32.581] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 32.581] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 32.582] SN: OK Layer 0 [ 4:log/main 32.582] send next Layer 6 [ 2:main/L 32.582] SN: OK L Layer 0 [ 5:server/Server 32.597] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 32.597] found addr 0.0.1 Layer 0 [ 4:log/main 32.598] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 32.598] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 32.598] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 32.599] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 32.599] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 32.599] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 32.600] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000000: EMI_common: send while waiting E00000036: Send while data [14:A.ft12cemi] [13:A.ft12cemi] Layer 6 [ 1:main 32.601] SN: OK Layer 0 [ 4:log/main 32.601] send next Layer 6 [ 2:main/L 32.601] SN: OK L Layer 1 [14:A.ft12cemi/ft12cemi 32.898] No confirm, continuing Layer 0 [12:log/A.ft12cemi 32.899] send next Layer 6 [ 1:main 32.899] SN: send_more set Layer 0 [ 5:server/Server 35.611] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 35.611] found addr 0.0.1 Layer 0 [ 4:log/main 35.611] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 35.612] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 35.612] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 35.612] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 35.613] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 35.613] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 35.613] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 35.614] SN: OK Layer 0 [ 4:log/main 35.614] send next Layer 6 [ 2:main/L 35.614] SN: OK L Layer 1 [14:A.ft12cemi/ft12cemi 35.912] No confirm, continuing Layer 0 [12:log/A.ft12cemi 35.912] send next Layer 6 [ 1:main 35.912] SN: send_more set Layer 0 [ 5:server/Server 38.622] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 38.622] found addr 0.0.1 Layer 0 [ 4:log/main 38.622] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 38.622] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 38.622] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 38.622] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 38.622] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 38.623] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 38.623] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 38.623] SN: OK Layer 0 [ 4:log/main 38.623] send next Layer 6 [ 2:main/L 38.623] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 38.634] Read(001): E5 Layer 0 [12:log/A.ft12cemi 38.634] send next Layer 6 [ 1:main 38.635] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 38.675] Read(008): 68 0C 0C 68 F3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 38.680] Read(008): 50 00 01 11 14 01 43 00 Layer 0 [13:A.ft12cemi/ft12ser 38.682] Read(002): 8B 16 Layer 0 [13:A.ft12cemi/ft12ser 38.682] Send Ack(001): E5 Layer 0 [13:A.ft12cemi/ft12ser 38.683] Sequence jump Layer 1 [14:A.ft12cemi/ft12cemi 38.922] No confirm, continuing Layer 0 [12:log/A.ft12cemi 38.922] send next Layer 6 [ 1:main 38.922] SN: send_more set Layer 0 [ 5:server/Server 41.680] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 41.683] found addr 0.0.1 Layer 0 [ 4:log/main 41.683] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 41.683] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 41.683] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 41.683] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 41.683] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 41.684] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 41.684] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 1 [13:A.ft12cemi/ft12ser 41.684] Send(011): 11 00 B0 50 00 01 11 14 01 43 00 Layer 6 [ 1:main 41.684] SN: OK Layer 0 [ 4:log/main 41.684] send next Layer 6 [ 2:main/L 41.684] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 41.684] Send(018): 68 0C 0C 68 73 11 00 B0 50 00 01 11 14 01 43 00 EE 16 Layer 0 [13:A.ft12cemi/ft12ser 41.697] Read(001): E5 Layer 0 [12:log/A.ft12cemi 41.697] send next Layer 6 [ 1:main 41.697] SN: send_more set Layer 1 [14:A.ft12cemi/ft12cemi 41.983] No confirm, continuing Layer 0 [12:log/A.ft12cemi 41.983] send next Layer 6 [ 1:main 41.983] SN: send_more set Layer 0 [ 5:server/Server 44.645] Recv(016): 06 10 05 30 00 10 29 00 B0 60 00 01 11 14 00 81 Layer 8 [15:router/ConnC 44.646] found addr 0.0.1 Layer 0 [ 4:log/main 44.646] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DISCONNECT_REQ Layer 0 [ 4:log/main 44.646] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DISCONNECT_REQ Layer 0 [12:log/A.ft12cemi 44.646] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 44.646] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 44.646] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 44.646] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 44.647] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DISCONNECT_REQ Layer 1 [13:A.ft12cemi/ft12ser 44.647] Send(010): 11 00 B0 50 00 01 11 14 00 81 Layer 6 [ 1:main 44.647] SN: OK Layer 0 [ 4:log/main 44.647] send next Layer 6 [ 2:main/L 44.647] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 44.647] Send(017): 68 0B 0B 68 53 11 00 B0 50 00 01 11 14 00 81 0B 16 Layer 0 [13:A.ft12cemi/ft12ser 44.659] Read(001): E5 Layer 0 [12:log/A.ft12cemi 44.659] send next Layer 6 [ 1:main 44.659] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 44.739] Read(008): 68 0B 0B 68 D3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 44.743] Read(008): 50 00 01 11 14 00 81 A8 Layer 0 [13:A.ft12cemi/ft12ser 44.746] Read(001): 16 Layer 0 [13:A.ft12cemi/ft12ser 44.746] Send Ack(001): E5 Layer 0 [13:A.ft12cemi/ft12ser 44.746] Sequence jump Layer 1 [14:A.ft12cemi/ft12cemi 44.946] No confirm, continuing Layer 0 [12:log/A.ft12cemi 44.946] send next Layer 6 [ 1:main 44.946] SN: send_more set Layer 0 [ 5:server/Server 45.150] Recv(016): 06 10 05 30 00 10 29 00 B0 60 00 01 11 14 00 80 Layer 8 [15:router/ConnC 45.150] found addr 0.0.1 Layer 0 [ 4:log/main 45.150] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_CONNECT_REQ Layer 0 [ 4:log/main 45.150] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 0 [12:log/A.ft12cemi 45.150] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 45.151] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 45.151] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 45.151] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 45.151] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_CONNECT_REQ Layer 1 [13:A.ft12cemi/ft12ser 45.151] Send(010): 11 00 B0 50 00 01 11 14 00 80 Layer 6 [ 1:main 45.151] SN: OK Layer 0 [ 4:log/main 45.151] send next Layer 6 [ 2:main/L 45.151] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 45.151] Send(017): 68 0B 0B 68 73 11 00 B0 50 00 01 11 14 00 80 2A 16 Layer 0 [13:A.ft12cemi/ft12ser 45.163] Read(001): E5 Layer 0 [12:log/A.ft12cemi 45.163] send next Layer 6 [ 1:main 45.163] SN: send_more set Layer 0 [ 5:server/Server 45.168] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 45.168] found addr 0.0.1 Layer 0 [ 4:log/main 45.168] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 45.169] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 45.169] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 45.169] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 45.169] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 45.169] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 45.169] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000000: EMI_common: send while waiting [14:A.ft12cemi] Layer 1 [13:A.ft12cemi/ft12ser 45.169] Send(011): 11 00 B0 50 00 01 11 14 01 43 00 Layer 6 [ 1:main 45.169] SN: OK Layer 0 [ 4:log/main 45.169] send next Layer 6 [ 2:main/L 45.169] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 45.169] Send(018): 68 0C 0C 68 53 11 00 B0 50 00 01 11 14 01 43 00 CE 16 Layer 0 [13:A.ft12cemi/ft12ser 45.182] Read(001): E5 Layer 0 [12:log/A.ft12cemi 45.182] send next Layer 6 [ 1:main 45.182] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 45.207] Read(008): 68 0B 0B 68 F3 2E 00 B0 Layer 0 [13:A.ft12cemi/ft12ser 45.211] Read(008): 50 00 01 11 14 00 80 C7 Layer 0 [13:A.ft12cemi/ft12ser 45.213] Read(001): 16 Layer 0 [13:A.ft12cemi/ft12ser 45.213] Send Ack(001): E5 Layer 0 [13:A.ft12cemi/ft12ser 45.214] Sequence jump Layer 1 [14:A.ft12cemi/ft12cemi 45.469] No confirm, continuing Layer 0 [12:log/A.ft12cemi 45.469] send next Layer 6 [ 1:main 45.469] SN: send_more set Layer 0 [ 5:server/Server 48.180] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 48.180] found addr 0.0.1 Layer 0 [ 4:log/main 48.180] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 48.181] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 48.181] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 48.181] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 48.181] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 48.181] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 48.181] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 1 [13:A.ft12cemi/ft12ser 48.181] Send(011): 11 00 B0 50 00 01 11 14 01 43 00 Layer 6 [ 1:main 48.181] SN: OK Layer 0 [ 4:log/main 48.181] send next Layer 6 [ 2:main/L 48.181] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 48.181] Send(018): 68 0C 0C 68 73 11 00 B0 50 00 01 11 14 01 43 00 EE 16 Layer 0 [13:A.ft12cemi/ft12ser 48.194] Read(001): E5 Layer 0 [12:log/A.ft12cemi 48.194] send next Layer 6 [ 1:main 48.194] SN: send_more set Layer 0 [13:A.ft12cemi/ft12ser 48.235] Read(008): 68 0C 0C 68 F3 2E 00 B0 Layer 1 [14:A.ft12cemi/ft12cemi 48.481] No confirm, continuing Layer 0 [12:log/A.ft12cemi 48.481] send next Layer 6 [ 1:main 48.481] SN: send_more set Layer 0 [ 5:server/Server 51.183] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 51.184] found addr 0.0.1 Layer 0 [ 4:log/main 51.184] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 51.184] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 51.185] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 51.185] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 51.185] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 51.186] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 51.186] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 1 [13:A.ft12cemi/ft12ser 51.186] Send(011): 11 00 B0 50 00 01 11 14 01 43 00 Layer 6 [ 1:main 51.187] SN: OK Layer 0 [ 4:log/main 51.187] send next Layer 6 [ 2:main/L 51.187] SN: OK L Layer 0 [13:A.ft12cemi/ft12ser 51.187] Send(018): 68 0C 0C 68 53 11 00 B0 50 00 01 11 14 01 43 00 CE 16 Layer 0 [13:A.ft12cemi/ft12ser 51.200] Read(001): E5 Layer 1 [14:A.ft12cemi/ft12cemi 51.484] No confirm, continuing Layer 0 [12:log/A.ft12cemi 51.485] send next Layer 6 [ 1:main 51.485] SN: send_more set Layer 0 [ 5:server/Server 54.196] Recv(017): 06 10 05 30 00 11 29 00 B0 60 00 01 11 14 01 43 00 Layer 8 [15:router/ConnC 54.197] found addr 0.0.1 Layer 0 [ 4:log/main 54.197] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [ 4:log/main 54.198] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 Layer 0 [12:log/A.ft12cemi 54.198] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 54.199] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 54.199] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 54.199] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 54.199] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DATA_CONNECTED_REQ serno:00 A_DeviceDescriptor_Read Type:00 E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 54.200] SN: OK Layer 0 [ 4:log/main 54.200] send next Layer 6 [ 2:main/L 54.200] SN: OK L Layer 1 [14:A.ft12cemi/ft12cemi 54.498] No confirm, continuing Layer 0 [12:log/A.ft12cemi 54.498] send next Layer 6 [ 1:main 54.499] SN: send_more set Layer 0 [ 5:server/Server 57.355] Recv(016): 06 10 05 30 00 10 29 00 B0 60 00 01 11 14 00 81 Layer 8 [15:router/ConnC 57.355] found addr 0.0.1 Layer 0 [ 4:log/main 57.355] Recv L_Data system from 0.0.1 to 1.1.20 hops: 06 T_DISCONNECT_REQ Layer 0 [ 4:log/main 57.356] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DISCONNECT_REQ Layer 0 [12:log/A.ft12cemi 57.356] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 57.357] Has Addr 1.1.20: no Layer 0 [12:log/A.ft12cemi 57.357] Has Addr 0.0.1: no Layer 0 [12:log/A.ft12cemi 57.357] Addr Check 1.1.20: yes Layer 0 [12:log/A.ft12cemi 57.358] Send L_Data system from 0.0.1 to 1.1.20 hops: 05 T_DISCONNECT_REQ E00000036: Send while data [13:A.ft12cemi] Layer 6 [ 1:main 57.358] SN: OK Layer 0 [ 4:log/main 57.358] send next Layer 6 [ 2:main/L 57.359] SN: OK L Layer 1 [14:A.ft12cemi/ft12cemi 57.656] No confirm, continuing Layer 0 [12:log/A.ft12cemi 57.656] send next Layer 6 [ 1:main 57.657] SN: send_more set
