Moinmoin@all
Ok, werde ich testen.
this.addAddress = function( address, id ) { if( address in ga_list ) { ga_list[ address ].push( id ); --> if loading finished --> reload cache } else { ga_list[ address ] = [ id ]; --> if loading finished --> update URL: thisTemplateEngine.visu.subscribe(thisTemplateEngine.getAddresses()); ??? --> reload cache } };
this.addAddress = function( address, id ) { if( address in ga_list ) { // For functions we need to iterate and check if function already present var doAdd = true; if ( typeof id === 'function' ) { // Iterate through array and check if id is function and if function string is equal for(var i = 0, size = ga_list[address].length; i < size ; i++){ var idChk = ga_list[address][i]; if ( typeof idChk === 'function' & idChk.toString() == id.toString() ) { doAdd = false; break; } } if ( doAdd ) { ga_list[ address ].push( id ); // If loading was finished, re-init cache if ( !$('.loading').hasClass('loading') ) { console.log("Added function to address " + address + " after loading"); // perform cache re-init } } else { console.log("Function already there for address " + address); } } else if ( id in ga_list[ address ] ) { console.log("ID " + id + " already there for address " + address); } else { ga_list[ address ].push( id ); if ( !$('.loading').hasClass('loading') ) { console.log("Added ID " + id + " to address " + address + " after loading"); } } } else { ga_list[ address ] = [ id ]; // If loading was finished, re-init cache if ( !$('.loading').hasClass('loading') ) { console.log("Added address " + address + " after loading"); // perform cache re-init } } };
