Hehe
Nee, das Geld geht an myonlineportal
Die haben dafür auch nen super Service.
2025/02/15 13:19:02 [error] 691#691: *29 access forbidden by rule, client: 34.XXX.XXX.XXX, server: smarthomeng, request: "POST /alexa/ HTTP/1.1", host> Feb 15 13:19:02 SmartHomeNG nginx[691]: 34.XXX.XXX.XXX forwarded for - - Request: "POST /alexa/ HTTP/1.1" - Status: 403 - Bytes sent: 146 Referrer: "-" - User Agent: "-"
auth_basic "Restricted Area: Alexa"; auth_basic_user_file /etc/nginx/.alexa;
version":"3"},{"type":"AlexaInterface","interface":"Alexa.EndpointHealth","version":"3","properties":{"supported":[{"name":"connectivity"}],"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.RangeController","version":"3","properties":{"supported":[{"name":"rangeValue"}],"proactivelyReported":false,"retrievable":true},"instance":"cfg_rollo_west-alias1","capabilityResources":{"friendlyNames":[{"@type":"asset","value":{"assetId":"Alexa.Setting.Opening"}}]},"configuration":{"supportedRange":{"minimumValue":0,"maximumValue":100,"precision":1},"unitOfMeasure":"Alexa.Unit.Percent"},"semantics":{"actionMappings":[{"@type":"ActionsToDirective","actions":["Alexa.Actions.Close"],"directive":{"name":"SetRangeValue","payload":{"rangeValue":100}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Open"],"directive":{"name":"SetRangeValue","payload":{"rangeValue":0}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Lower"],"directive":{"name":"AdjustRangeValue","payload":{"rangeValueDelta":20,"rangeValueDeltaDefault":false}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Raise"],"directive":{"name":"AdjustRangeValue","payload":{"rangeValueDelta":-20,"rangeValueDeltaDefault":false}}}],"stateMappings":[{"@type":"StatesToValue","states":["Alexa.States.Closed"],"value":0},{"@type":"StatesToRange","states":["Alexa.States.Open"],"range":{"minimumValue":1,"maximumValue":100}}]}}]},{"endpointId":"cfg_rollo_west-alias2","friendlyName":"Westrollos","description":"Rolllaeden West by SmartHomeNG","manufacturerName":"SmarthomeNG","displayCategories":["EXTERIOR_BLIND"],"cookie":{"extraDetail1":"config.beschattung.rollowest.pos"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa","version":"3"},{"type":"AlexaInterface","interface":"Alexa.EndpointHealth","version":"3","properties":{"supported":[{"name":"connectivity"}],"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.RangeController","version":"3","properties":{"supported":[{"name":"rangeValue"}],"proactivelyReported":false,"retrievable":true},"instance":"cfg_rollo_west-alias2","capabilityResources":{"friendlyNames":[{"@type":"asset","value":{"assetId":"Alexa.Setting.Opening"}}]},"configuration":{"supportedRange":{"minimumValue":0,"maximumValue":100,"precision":1},"unitOfMeasure":"Alexa.Unit.Percent"},"semantics":{"actionMappings":[{"@type":"ActionsToDirective","actions":["Alexa.Actions.Close"],"directive":{"name":"SetRangeValue","payload":{"rangeValue":100}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Open"],"directive":{"name":"SetRangeValue","payload":{"rangeValue":0}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Lower"],"directive":{"name":"AdjustRangeValue","payload":{"rangeValueDelta":20,"rangeValueDeltaDefault":false}}},{"@type":"ActionsToDirective","actions":["Alexa.Actions.Raise"],"directive":{"name":"AdjustRangeValue","payload":{"rangeValueDelta":-20,"rangeValueDeltaDefault":false}}}],"stateMappings":[{"@type":"StatesToValue","states":["Alexa.States.Closed"],"value":0},{"@type":"StatesToRange","states":["Alexa.States.Open"],"range":{"minimumValue":1,"maximumValue":100}}]}}]},{"endpointId":"cfg_lamellen_west-alias1","friendlyName":"Westlamellen","description":"Lamellenverstellung West in Prozent by SmartHomeNG","manufacturerName":"SmarthomeNG","displayCategories":[],"cookie":{"extraDetail1":"config.beschattung.lamellenwest.blindpos"},"capabilities":[{"type":"AlexaInterface","interface":"Alexa","version":"3"},{"type":"AlexaInterface","interface":"Alexa.EndpointHealth","version":"3","properties":{"supported":[{"name":"connectivity"}],"proactivelyReported":false,"retrievable":true}},{"type":"AlexaInterface","interface":"Alexa.RangeController","version":"3","properties":{"supported":[{"name":"rangeValue"}],"proactivelyReported":false,"retrievable":false}}]}]}}}
END RequestId: 54292e62-776d-44f0-8e7e-2ba4ee6e46f7
REPORT RequestId: 54292e62-776d-44f0-8e7e-2ba4ee6e46f7 Duration: 301.30 ms Billed Duration: 302 ms Memory Size: 512 MB Max Memory Used: 61 MB
const https = require('https');
exports.handler = async (event) => {
const data = JSON.stringify(event);
const options = {
hostname: process.env.SMARTHOME_HOST,
port: process.env.SMARTHOME_PORT,
path: process.env.SMARTHOME_PATH,
method: 'POST',
auth: process.env.SMARTHOME_AUTH,
headers: {
'Content-Type': 'application/json',
'Content-Length': Buffer.byteLength(data) // <-- korrigiert
console.log("requesting", data);
try {
const responseData = await new Promise((resolve, reject) => {
const req = https.request(options, (res) => {
console.log(`HTTP ${res.statusCode}`);
let body = '';
res.setEncoding('utf8');
res.on('data', (chunk) => {
body += chunk;
res.on('end', () => {
console.log("raw response:", body);
resolve({ statusCode: res.statusCode, body });
req.on('error', (err) => {
console.error("request failed", err);
reject(err);
req.write(data);
req.end();
const parsed = JSON.parse(responseData.body);
if (responseData.statusCode === 200) {
console.info("OK", JSON.stringify(parsed));
return parsed;
} else {
console.error("Failed", JSON.stringify(parsed));
throw new Error("DependentServiceUnavailableError");
} catch (err) {
console.error("Error:", err);
throw err;
[TD]2025-11-21T21:26:31.221+01:00[/TD]
[TD]2025-11-21T20:26:31.221Z - INFO raw response: {"event": {"header": {"namespace": "Alexa.Discovery", "name": "Discover.Response", "payloadVersion": "3", "messageId": "60f05652d2014849bd07570aaf25722b"}, "payload": {"endpoints": [{"endpointId": "config_lueftung", "friendlyName": "L\u00fcftung", "description": "L\u00fcftungsturbo f\u00fcr 5 min by SmartHomeNG", "manufacturerName": "SmarthomeNG", "displayCategories": ["OTHER"], "cookie": {"extraDetail1": "config.HeizungLueftung.Lueftung"}, "capabilities": [{"type": "AlexaInterface", "interface": "Alexa", "version": "3"}, {"type": "AlexaInterface", "interface": "Alexa.EndpointHealth", "version": "3", "properties": {"supported": [{"name": "connectivity"}], "proactivelyReported": false, "retrievable": true}}, {"type": "AlexaInterface", "interface": "Alexa.PowerController", "version": "3", "properties": {"supported": [{"name": "powerState"}], "proactivelyReported": false, "retrievable": true}}]}, {"endpointId": "cfg_rollo_eg", "friendlyName": "Rolll\u00e4den Erdgeschoss", "description": "Rolllaeden EG in Prozent by SmartHomeNG", "manufacturerName": "SmarthomeNG", "displayCategories": ["EXTERIOR_BLIND"], "cookie": {"extraDetail1": "config.beschattung.rolloeg.pos"}, "capabilities": [{"type": "AlexaInterface", "interface": "Alexa", "version": "3"}, {"type": "AlexaInterface", "interface": "Alexa.EndpointHealth", "version": "3", "properties": {"supported": [{"name": "connectivity"}], "proactivelyReported": false, "retrievable": true}}, {"type": "AlexaInterface", "interface": "Alexa.RangeController", "version": "3", "properties": {"supported": [{"name": "rangeValue"}], "proactivelyReported": false, "retrievable": true}, "instance": "cfg_rollo_eg", "capabilityResources": {"friendlyNames": [{"@type": "asset", "value": {"assetId": "Alexa.Setting.Opening"}}]}, "configuration": {"supportedRange": {"minimumValue": 0, "maximumValue": 100, "precision": 1},[/TD]
export const handler = async(event) => {
try {
console.log("event", event);
var myHeader = {
'Authorization': 'Basic ' + Buffer.from(process.env.SMARTHOME_AUTH, "utf-8").toString("base64"),
'Content-Length': Buffer.byteLength(JSON.stringify(event))
var myUrl = "https://" + process.env.SMARTHOME_HOST + ":" + process.env.SMARTHOME_PORT + process.env.SMARTHOME_PATH
console.log(myUrl)
const response = await fetch(myUrl, {
method: 'POST',
headers : myHeader,
body: JSON.stringify(event)
const data = await response.json();
console.log(data);
if (response.status == 200) {
return {
statusCode: response.statusCode,
body: JSON.stringify(data),
else
return {
body: response.text()
catch (error) {
console.error(error);
return {
statusCode: 500,
body: JSON.stringify(error),
2025-11-23T21:57:08.892+01:00
INIT_START Runtime Version: nodejs:24.v25 Runtime Version ARN: arn:aws:lambda:eu-west-1::runtime:9789c897924b8267853973afab7f065eaf98a441d27aa14bb62b2560df1ea5a0
INIT_START Runtime Version: nodejs:24.v25 Runtime Version ARN: arn:aws:lambda:eu-west-1::runtime:9789c897924b8267853973afab7f065eaf98a441d27aa14bb62b2560df1ea5a0 2025-11-23T21:57:09.035+01:00
2025-11-23T20:57:09.035Z - ERROR (node:2) Warning: Failed to load the ES module: /var/task/index.js. Make sure to set "type": "module" in the nearest package.json file or use the .mjs extension.
(Use `node --trace-warnings ...` to show where the warning was created)
2025-11-23T20:57:09.035Z - ERROR (node:2) Warning: Failed to load the ES module: /var/task/index.js. Make sure to set "type": "module" in the nearest package.json file or use the .mjs extension. (Use `node --trace-warnings ...` to show where the warning was created) 2025-11-23T21:57:09.038+01:00 2025-11-23T20:57:09.038Z - ERROR Init Error {"errorType":"Runtime.UserCodeSyntaxError","errorMessage":"SyntaxError: Unexpected token 'export'","name":"Runtime.UserCodeSyntaxError","stack":["/var/task/index.js:1","export const handler = async(event) => {","^^^^^^","","SyntaxError: Unexpected token 'export'"," at wrapSafe (node:internal/modules/cjs/loader:1691:18)"," at Module._compile (node:internal/modules/cjs/loader:1734:20)"," at Object..js (node:internal/modules/cjs/loader:1893:10)"," at Module.load (node:internal/modules/cjs/loader:1480:32)"," at Module._load (node:internal/modules/cjs/loader:1299:12)"," at TracingChannel.traceSync (node:diagnostics_channel:328:14)"," at wrapModuleLoad (node:internal/modules/cjs/loader:244:24)"," at cjsLoader (node:internal/modules/esm/translators:342:5)"," at ModuleWrap.<anonymous> (node:internal/modules/esm/translators:234:7)"," at ModuleJob.run (node:internal/modules/esm/module_job:377:25)"]}
