Zitat von Rasmus7700
The eg.wohnen.licht must be the switch, .wert is the value, but is it only needed to "tell" smartvisu eg.wohnen.licht.uzsu? Then it knows to use the UZSU plugin (offcourse the item must be defined as described in USZU - and installed as a plugin)
If you use no uzsu for one Item, you give an empty value ...,'',...
So when using this "mod" the commands must be list.dimmer,switch,rgb and so on - correct?
Greetings,
Hendrik
Is it same structure as earlier eith RTR?
Is it also possible to use the feature, to set the temperature or something like that inside the navigation button for etc "Kochen"?[/QUOTE]
