As far as i know the IO1 is enough (8 inputs for ringer-keys and 3 outputs for light, door-open)
I'm still unsure, as I understand it,
the IO1 is indeed for external IO, but
the IO2 is for terminating the Ethernet cable
The fact that this is not clearly mentionned in the output of the configurator is bizarre, but OK, I'll RTFM
Also, adding all components to , what I call a "basic config", I end-up with an amount of 1.778€, ouch !
It seems that the MX (for Mobotix frames) and the S (for Siedle frames) version is the same thing because the T24 fits to the Mobotix frames and the Siedle frames IMHO.
The day and night version is indicated by product number before the "11":
MX-T24M-Sec-D11 is the day version
MX-T24M-Sec-N11 is the night version
At the moment only the day version is available in the configurator on the mobotix site. I've bought the night version in december 2011. I don't know if the night version is discountinued.
Mit freundlichen Grüßen Niko Will
Logiken und Schnittstelle zu anderen Systemen: smarthome.py - Visualisierung: smartVISU - Gira TS3 - iPhone & iPad - Mobotix T24 - ekey - Denon 2313 - Russound C5 (RIO over TCP Plugin) -
Um z.B. nachträglich Siedle-Vario-Module an das T24M anzuschließen benötigt man das Modul MX-Opt-IO1, dieses Modul ist wohl beim T24S bereits "integriert".
To adopt Siedle varoi Modules you need Modul MX-OPT-IO1. This modules is already included in -S version.
I do have the N11 too, I am very surprised that it is no longer available.
Bedienung des Türöffners per KNX-Taster & Telefon
Dazu stelle ich mir vor, den Türöffnerausgang der Zusatzplatine auf einen Binäreingang und nicht direkt an den Türöffner zu legen
I find it a good idea
I've read the counter arguments, they are not applicable to my case.
Have you already implemented it ?
Is it also true for the external light ?
If yes for both, that would already provide a decent KNX integration, although it costs an extra BE.
Yes, I have also planned to connect the external light output if the T24 to a binary input. Right now my T24 is waiting for the electrician to finish the cabeling. Hopefully this will be done by the end of April!
According to my late info (subject to caution)
the IO2 is needed in case of an existing IO1 and a raw Ethernet cable (no connector, just bare wires).
the IO2 is not needed in case of an existing IO1 and an Ethernet cable terminated with a RJ45.
Can someone please, explain the "anti-theft protection", specially when no "Security door opener" is present ? Is it still posible to use it in that case ? I seem to remember that a 24VDC voltage has to be applied, but is it to lock or unlock the device ?
Answering my own question ... found in "mx_ML_T24MX_Part_1_en_120102.pdf" page 94
It looks like the "anti-theft protection" can work without the "Security door opener". A 12VDC has to be provided from an external source (outside the T24), so yet another cable. I'm still in the pre-installation phase, so much concerned about cable routing (not yet the internal workings).
It looks like one needs to read the entire manual before starting the installation (or even before buying)
Ich muss hier auch mal auf einen Fred verweisen: Klick
Hat da jemand für den letzten Teil mal einen genaueren Tipp?
Ich möchte einfach nur einen Button auf der Visu mit dem ich die Haustür öffnen kann, mehr nicht!
