Hallo NilsS,
hat geklappt.
Danke.
hat geklappt.
Danke.
C:\python24\python.exe c:\python24\LogikGen.py -d -i "%1"
C:\python24\python.exe c:\python24\LogikGen.py -d -i deine.hsl
[kogw] hsip:192.168.178.11 gwport:7003 gwsecret:intern [19952] EN[1]:$IKO$1/0/120 AN[1]:$IKO$150/0/10
C:\hslogik\5012>python LogikGen.py -g -d -i 13203_hsfusion_TEXT_Zahl_Text_mit_Dezimalstellen.hsl 13203 Looking for 13203 Config Found Config for 13203 ** Setze IKO 1/2/65 auf EN[2] ** Setze IKO 1/2/125 auf AN[1] *** Verbindung zum KO-Gateway hergestellt *** {'pItem': <__main__.HSLogikItemDummy instance at 0x02539440>, 'AA': [None, None] , 'AC': [None, False], 'EN': [None, 'Start', 0.0, '', 0.0], 'EI': 1, 'ON': [None ], 'OC': [None], 'self': <__main__.HSLogikSelfDummy instance at 0x02539418>, 'EA ': [None, '', 0.0, None, None], 'EC': [None, 1, False, False, False], 'AN': [Non e, ''], 'Timer': [[None, None]], 'SC': [None], 'SA': [None], 'OA': [None], 'SN': [None]} Fehler beim beschreiben der Variablen Traceback (most recent call last): File "LogikGen.py", line 510, in setVar if len(self.Ausgang[_vnum]['ikos']) > 0: IndexError: list index out of range ### Logik Debugger ###
EN: [None, 11.0, 80.0, 0.0, 60.0, 60.0, 65.0, 55.0, 1.0, 0.0, 70.0, 220.0, 10.0]
